    Polycarbonate build plate…. No bed heat Success!!!
    136
    24.5k
    • Whitewolfundefined
      Whitewolf
      @okercho:
      Hi there!
      After several prints I must say I'm still impressed with PC, it's the best print surface I've used so far, although is not perfect of course… here a few impressions and a question:
      • PLA and PETG (so far, the materials I've printed with) sticks perfectly... sometimes it sticks too much.
      • The Z Offset is really important and depends on the material you're printing with... for PLA I need to setup a 0.1 offset, for PETG I'm still testing, but 0'25 seems to be OK. If you're closed to the bed, you won't be able to unstick the part without breaking it...
      • I have a white and a transparent PC sheet, the white one seems to be more flat than the transparent one, and sticks more too... I will need to sand it a bit more probably.
      • Usually bending the sheet is enough to unstick the part... it starts to "crack" a bit, and then you can remove it. The problem here is that if the part is too small or too thin, the part will bend with the bed, and it's harder to remove.
      And now the question for @Whitewolf:
      After you told me about the "cup", I've been using the bulldog clips and the surface is really flat as per the probe, however, I've observed that even though the parts are not warped from the bed, the base of the part seems to be bended... and I'm thinking the problem is that even with the clips, the plastic bend the surface with cooling down, so the part is a bit bended, similarly when you've warp problems... did you observed this? Any advice?
      Cheers!
      Are you using heat with your bed? The majority of parts should easily pop off if no bed heat is used and it is properly sanded… I see many people doing things differently, different grit sand papers etc adding bed heat etc and then wondering why their results vary. I didnt start with 60 grit... i chose it because it worked better than others
      You are sanding differently, you are squishing, are you running bed heat too? Honestly this works flawlessly for me, time and time again... it is not until you introduce these other elements that things tend not to work.
        Whitewolf
        @bot:
        @okercho:
        Hi there!
        Cheers!
        I do not use PC, but PEI as a build surface, which has the "cup" and is secured with a clamp to keep it flat, and have experienced the same thing – the bottom of very large prints will "cup" in the same way that the build surface would if released from the clamps.
        I wonder if there is a way to get pieces of plastic that "cup" to be more flat by relieving the internal stresses that causes the warping? Maybe heating the pieces in an oven at controlled temperatures, while held between two precision flat plates?
        Honestly i think bed heat is the issue here, most people run PEI with a heated bed.
        I have printed objects as large as 80mil vase bottoms without any cupping…. but then again i do not use a heated bed and I am not having to squish anything to get first layer adhesion.... with the exception of a couple specialty filaments like Igus Iglidur, Nylon and Acetal POM. with those i either run a large brim with no bed heat or 55c bed heat with no brim but only on those specialty filaments, i have not had issues with 0 bed heat with any of the others that i have tested
        I also always print at the low end of temps... if these guys are running PLA for instance at 215 then they are going to get a whole different set of issues.
        • botundefined
          bot
          Heat was definitely my theory, as well. If Okercho responds positively that he was using bed heat, then I will consider that the primary suspected culprit.
          *not actually a robot
          • DjDemonDundefined
            DjDemonD
            @Whitewolf:
            @DjDemonD:
            This is why these surfaces are generally bonded with 3M 468 adhesive to the aluminium/glass substrate. Otherwise they warp too.
            Only problem with that is you would need a mic6 plate underneath to be effective.
            Also it would remove one of the key elements that make working with PC build plates easy and that is the ability to remove plates and flex to pop the part off and you would end up with some situations where parts were very difficult to remove
            My current printbite surface is bonded to a machined tooling plate. Or I'd use glass.
            I've had a sample of 3mm thick PEI which deformed as the bed heated up.
            I haven't seen the effect you are describing in prints myself so a I apologise if I assumed this was the PC deforming under heating.
            www.precisionpiezo.co.uk
              Whitewolf
              @bot:
              He has done many things differently in preperation of his plate and the way he prints. I did a lot of testing before posting this thread… from starting with 120 grit paper on down till i settled on 60 grit and wet sanding.
              I tried all kinds of bed temps from 0 all the way up to 120c, i tried all kinds of filaments and different z offsets for every filament.... i even moved hotend temps up and down to see the results.
              I can tell you from experience, i had parts that were impossible to remove and needed sanding just to get the filament off. I had parts that removed too easily etc... every variable gave different results.
              If he has done things right there should not be more than a little twist of the part or a little tap with a scraper to get the part off (yes i have even removed 200mm single wall vases without breaking the part just by flexing the plate but flexing is usually not required for most parts only about 10% of the time if done right)
              If people want to venture off and do things differently then they will experience the same issues i experienced before finding what works and what doesnt.
              The point of me sharing the advice and thread was so others could skip past all that and get on with printing.
                Whitewolf
                Here is my x carriage printed on this very plate with Taulman Guidl!ne (PETG)
                One photo i gave a slight angle so you can see the surface, the other is direct on so you can see it is completely flat
                  Whitewolf
                  @DjDemonD:
                  @Whitewolf:
                  @DjDemonD:
                  That is the problem, it does deform if bed heat is used, you also get difficult to remove parts if heat is used… the only temp that I have found that can be used is up to 55c but this should only be done if required with a select few filaments.
                  My rule of thumb is no heat unless i experience warping then ill try a brim if that doesnt work then ill set bed temp up to 55c but i have only had to do this with a select few specialty engineering filaments... so if someone finds themselves having different results then they need to ask themselves what they are doing differently, did they follow my advice to a T or did they venture off the path and do things a little differently
                  • okerchoundefined
                    okercho
                    I'm not trying to do things differently. If I did something in a different way is because I didn't understand it correctly, or because my DIY skills and tools are not the best for the job…
                    I'm not using heat bed since I'm using PC as build plate, also I'm only having "cupping problems" in the bottom of the parts with PETG, a material I didn't use a lot before (because I had warping problems) and which I'm still struggling with... With PLA I'm not having problems at all, nor for removing, nor for sticking, although is true that I din't find the right point yet, where there is not "elephant foot", I know I'm still squishing PLA a bit.
                    For PETG I tried different Z offsets, and I had a mix of results, sometimes I wasn't able to remove the part (and I broke it trying to remove it) because I was too close (0'20 offset) to the bed, and sometimes having problems with the circles in the first layer because I was too far (0'25 offset), apart from the fact that I'm having problems with the temperature and flow for this material, but that's another story.
                    Additionally I have 2 PC sheets, one transparent (at least, it was transparent at the beginning) and another one white. The transparent one is "cupped" (not sure about the word, but you all know what I mean), and with the bulldog clips well positioned, the bed seems really flat, you can press and the sheet won't move down in any point, and the probe says the surface is quite well leveled, however, when I remove the clips, the cup is more visible than at the beginning, and I can see the bottom of the part is "cupped" too when I remove it successfully. The white one is perfectly flat, but as I had a problem when I tried to remove one piece, I couldn't use it until today, when I sanded it again. PETG anyway is a material that makes a lot of force when cooling down, I used blue painter tape and it ripped out the tape from the bed when cooling...
                    @Whitewolf, I'm sorry if you felt like I'm criticizing you, I'm not, I truly appreciate what you did sharing this with us, and trust me, this is the best surface I've ever used (even if apparently I didn't follow the instructions :P), but you've been using it for a long time meanwhile I'm still learning how to use it, and I just ask to take advantage of your experience, to try not to fail in the same ways you failed in the past, anda I'm just trying to share my experience from a newbie point of view, sharing my failures, my successes, what I did and how, so I can receive advice and others can learn from me, same I'm trying to learn from you and others in this forum.
                    Regards
                    Okercho
                    Custom Prusa i3 Hephestos with Duet Wi-Fi
                    E3d V6 with Bondtech BMG DirectDrive and PrecisionPiezo Sensor
                    Rebuilding Hypercube Evolution
                    • botundefined
                      bot
                      The convex surface I describe is only on LARGE surface area prints – like 200 mm diameter flat circles, or large rectangular areas. Small prints like the ones which you (Whitewolf) show do not exhibit any convex bottom surface. Also, it does sound very similar to what Okercho is describing: the print is flat when adhered to the surface, the surface is flat when clamped (or bonded) to the tooling plate, but when the print is removed, the bottom surface sometimes reveals a convex condition.
                      At first, I too suspected heat -- perhaps the differential of surface temperature from the middle of the bed to the outer edge causes a differential contraction rate when printing/cooling. However, on printers with different surfaces, but which exhibit less even heating on the heat bed, I do not observe this phenomenon -- only on the printers which I run which have a convex/concave (depending on which way you look at the piece) print surface that has been clamped down do I observe this.
                      • DjDemonDundefined
                        DjDemonD
                        This surface from what I read seems to behave like a surface I was testing for someone on reprap. 55 degrees is all it takes for difficult filaments anything more or any squash down on the first layer with abs especially and you won't get it off. The surface I tried was only very thin so I bonded it to glass and an abs part, as it contracted, held so well to the surface it cracked the surface.
                        This explains to me anyway why printbite works the way it does it only sticks at high temps so it releases at fairly high temps too. Not the best adhesion, but enough and with the convenience of being able get parts off fairly easily. But it's not $15 a sheet and isn't available more or less anywhere.
                          Whitewolf
                          Theres just a couple of things here, issues that you reported a few posts up about part removal. You sanded your plate with 120 yes you started with a lower grit but you finished with 120.
                          When i started this project it was with 120 and parts were sticking too well. When i dry sanded the sanding was not consistent and different edges of the part would stick differently. I settled on the combination of water and 60 grit which gave me the best balance of part removal and adhesion.
                          When the build plate eventually gets a sheen to it like found with 120 grit i find that its time to sand again because stuff starts sticking too well.
                          PETG is easy to print on this plate, if you are not using bed heat and your nozzle temp (what is your nozzle temp?) is in the lower range and you are experiencing warping then i suspect either a bad brand or bad roll.
                          The photos i provided above and in many photos before it are PETG.
                          When your clips are on and you do a mesh bed compensation what does the center of your bed say compared to the outside edges of your bed I am just curious if there is still a little cup in your bed, coupled with a bad filament
                          Here is some other examples, the pink single wall is PLA as you can see there is little to no squish. The clear one is PETG it is also the photo i provided above of the completed part without cupping. The white one is igus iglidur which easily warps like ABS which is why you see the brim but even after cooling none of these parts have that issue which is why i suspect other variables at play here. Nylon is the only filament that has given me a rough time with this plate
                          Sorry if i got frusterated, I just felt like i was pretty detailed in the methods that i found worked before ever posting this thread then i see people venturing off doing things a little differently then wondering why they experience different results. Results that i myself experienced until i found what worked.
                          • botundefined
                            bot
                            We're not talking about lack of adhesion while printing – we're talking about effects AFTER the part is removed from the build surface... nobody is attacking your idea.
                              Whitewolf
                              I wasnt saying they were sorry if it came off that way. I am not the best at expression through text.
                              I made the mistake of addressing a couple of his issues in a single post i guess is where the miscommunication is coming from.
                              In his post he was having issues with part removal
                              I was adressing that as one of the issues with my comments about proper sanding technique. If you read back a few posts you will see he ventured off the path a bit which is why he is experiencing this.
                              The second issue i was addressing is exactly what you state regarding after the part is removed. And again I am not experiencing these issues although the largest i have printed is about 80mm in both x and y directions.
                              I suspected heat at first because there are only two situations that i see too great of adhesion one is improper sanding and two is heat on filaments that shouldnt have heat so naturally i thought that must be the source of his cupping as well.
                              So that is why i asked next for the readings of his heaightmap and also suspect bad filament because PETG is easy to print with and his results are far different by his description. please keep in mind i am slowly typing from a phone… i didnt see you and djs replies till after i had finished posting.
                              There are a few others using this build plate that have had success and not reported this issue and no i cannot take credit for this, i was just exploring sanding black PC because my clear PC Flesk3d build plate did not work with the IR sensor
                              And for the year that i was printing with the Fleks3d build plate i did not see this effect nor did i read about any of their other customers reporting this issue.
                                Whitewolf
                                Okercho what size parts are you experiencing this cupping with?
                                  Whitewolf
                                  Okercho I apologize if i came off harsh during my frusteration. I try my best to express properly through text. I am a bit rough around the edges when it comes to social situations.
                                  I believe this might be a filament issue as there is others in another thread who have difficulties with PETG as well. My ignorance of only ever using premium PETG products made me short sighted on this.
                                  If you could share your readings from the heightmap and the size parts you are experiencing this cupping with it will help narrow it down.
                                  Also when you get a chance "wet" sand your PC with 60 grit and you will see better performance with part removal.
                                  • okerchoundefined
                                    okercho
                                    Hi there,
                                    I think that my "lost in translation" came from the wet sand thing, as in spanish the sand paper I bought is called "Papel de lija al agua" (water sandpaper), and as I never heard about "wet sanding" I thought I was doing the right thing xD.
                                    Anyway, after looking some manuals, I think I know what I should do, and I will use 60 grit sand paper (I need to check at home, but I think I have 40, 80 and 120, as those came with the tool… anyway I've bought at amazon some 60 grit, will get them tomorrow). So if I understood it correctly, I should just use the 60 grit, a bit of water (with a spray), and the movement should be straight lines instead of circles. Is that correct?
                                    Regarding PETG, I have two brands, one is PrimaSelect and the other one is 3DCPI (my favorite spanish brand for PLA, the best one I've used so far) , but I've only used the 3DCPI with the PC surface. I'm thinking about testing rigid.ink PETG too... (any opinions about it? What brand are you using?). My problems with PETG, apart from the removal issue (that will be addressed with the wet sanding) is that sometimes it seems is under extruded and sometimes over extruded (so some big layers seems to be peeling off and some little layers are "fat"), I've been playing with the flow but results are a bit random... also the parts are not strong (PETG its supposed to be stronger than PLA, but in some test I've been doing with PETG and PLA for the same design, durability of my parts printed in PETG are less than 1% of the same part printed in PLA), and tend to loose bits when removing it (so poor layer adhesion between the first and the second layer). I'm printing PETG at 245 with no heated bed, no fan, 40mm/s speed (first layer at 25mm/s) and 0'25mm offset from the bed (I'm using DjDemonD piezo sensor, so is the real offset).
                                    About the heightmap, here is a capture of the output after using the right side of the cup and the bulldog clips:
                                    And the part I was printing was this:
                                    The diameter is around 50mm, I will take some pictures when I get home, but as far as I remember, I broke a bit the first layer during removal and the bottom wasn't perfectly flat even though there wasn't warp at all from the surface, and the part was cool when I removed it (so no deformation due to still warm plastic). It's not the only one that came out that way (some others don't, same plastic and options) but was the smaller one.
                                    Regards
                                    Okercho
                                      Whitewolf
                                      So by the looks of that height map you still have a cup in the bed. also the front spring could be lowered a little to improve.
                                      do a mesh map of your bed without the PC, i would like to see it…. my aluminum bed has a permananet warp in it.... i wonder if you might have something similar but bowed up in the middle.
                                      Your parts definitely should not be breaking when being removed. I hope you will order something like Taulman TechG (Preferred) or RigidInk PETG if taulman isnt available in your area... this way will elliminate the filament variables and we can get on with calibrating your machine correctly.
                                      You are correct Water, i just wet it and sand to a paste and wet a few more times repeating the process this gets the most even results because PC is a difficult to sand surface, you wont be able to damage the surface and yes i do circular motions.
                                        Whitewolf
                                        When you take the clips off do the edges of the PC raise up a little off the bed?
                                          Whitewolf
                                          For the sake of always being on the same page we will refer to cupping as middle of plate upward and edges curling downward. and warping as the middle being down and the edges curling up
                                          • okerchoundefined
                                            okercho
                                            I've ordered some PETG and ASA (did you tried it?) samples from rigid.ink, and the 60grit sand paper will arrive tomorrow, let see how much the post takes from UK to Spain. I will do the testing and come back when I get home…
                                            Thanks!
                                            Okercho
