DWC 3.1.1
posso fare m122 versione senza dwc3.1.1
lo ripete ciclo for nest una chiamata indirizzo diverso dall'attuale . scusatemi
difetti scheda improbabile
difetto ssd comprata nuova ieri pari alla vecchia
mi rimane la procedura ma identica alla vostra consigliata
problemi sistema operativo ,preciso originale .
chiedo aiuto se avete un caso analogo. grazie sempre gentilissimi -
When connected to USB terminal, send M122 and share the results here so we can see what it says about the SD card.
PRIMA DELL AGGIORNAMENTO
M122
=== Diagnostics ===RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later
Board ID: 08DGM-917NK-F23T0-6JTD0-3S46T-TGA0F
Used output buffers: 3 of 24 (16 max)
Static ram: 23460
Dynamic ram: 72904 of which 0 recycled
Never used RAM 15716, free system stack 189 words
Tasks: NETWORK(ready,221) HEAT(blocked,309) MAIN(running,452) IDLE(ready,19)
Owned mutexes: WiFi(NETWORK) HTTP(MAIN)
Last reset 00:02:07 ago, cause: power up
Last software reset at 2021-02-17 13:39, reason: User, GCodes spinning, available RAM 15680, slot 2
Error status: 0x00
Aux0 errors 71,71,71
MCU temperature: min 32.1, current 35.6, max 36.0
Supply voltage: min 11.3, current 11.4, max 11.5, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 62571, standstill, SG min/max not available
Driver 1: position 62571, standstill, SG min/max not available
Driver 2: position 62571, standstill, SG min/max not available
Driver 3: position 0, standstill, SG min/max not available
Driver 4: position 0, standstill, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2021-03-11 20:14:51
Cache data hit count 156303538
Slowest loop: 7.39ms; fastest: 0.20ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.7ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is ready with "M122 " in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is assembling a command in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 29.58ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.25
WiFi MAC address 84:0d:8e:b3:ae:3e
WiFi Vcc 3.42, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 24912
WiFi IP address 192.168.178.105
WiFi signal strength -74dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
Socket states: 0 2 0 0 0 0 0 0
- WiFi -
DOPO AGGIORNAMENTO
20:18:53M122
Used output buffers: 7 of 24 (10 max)
Static ram: 23460
Never used RAM 15716, free system stack 199 words
Tasks: NETWORK(ready,245) HEAT(blocked,307) MAIN(running,466) IDLE(ready,19)
Last reset 00:00:23 ago, cause: power up
Error status: 0x00
Aux0 errors 18,18,18
MCU temperature: min 32.0, current 35.1, max 35.5
Date/time: 2021-03-11 20:18:50
Cache data hit count 27845843
Slowest loop: 14.50ms; fastest: 0.20ms
=== Storage ===
SD card longest read time 0.9ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
=== Network ===
Slowest loop: 28.05ms; fastest: 0.00ms
Responder states: HTTP(0) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
WiFi flash size 4194304, free heap 25680
Socket states: 4 4 0 0 0 0 0 0
- WiFi -
E' UTILE PER CAPIRE?
@luca-Massimiliano ECCO NON HA AGGIORNATO LA WWW E' STATA ESPLOSA
What URL are you using to reach the web interface?
Try connecting to just the bare IP address.
We're sorry but Duet Web Control does not work properly without JavaScript enabled. Please enable it to continue.
NON DOVREBBE FUNZIONARE? CON JAVA FUNZIONA
ORA OK , MANCA IL SECONDO RISCALDATORE , SONO NOMINITA 0 E 1 ANCHE REPETIER LI NOMINA COSI' E NON SETE LA TEMPERATURA DEL PRIMO RISCALDATORE . HO RISOLTO GRAZIE A TE LA VERSIONE TE NE SONO GRATO MA NON CAPISCO PERCHE' FUNZIONA SOLO CON JAVA.
1 IL PRIMO RISCALDATORE ASSENE
2 PERCHE' JAVA ? -
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M308 S1 P"e0temp" Y"thermistor" T100000 B4388 ; configure sensor 1 as thermistor on pin e0temp
M308 S2 P"e1temp" Y"thermistor" T100000 B4388 ; configure sensor 2 as thermistor on pin e1temp
M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H2 S280 ; set temperature limit for heater 2 to 280C -
Post the full contents of your config.g
Java is required for it to work. That's just the way it's made.
SCUSA AMICO , NON HO CAPITO COSA DEVO FARE
; generated by RepRapFirmware Configuration Tool v3.2.2 on Wed Jan 20 2021 16:02:24 GMT+0100 (Ora standard dell’Europa centrale); General preferences
M550 P"TATONA" ; set printer name
M665 R165.29 L334 B130 H501.5 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M540 PBE:EF:DE:AD:FE:ED ; set custom MAC address
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z-0.1 S1 ; set minimum Z; Endstops
M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop; Z-Probe
M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H10 F120 T2400 ; set Z probe type to bltouch and the dive height + speeds
M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
G31 P500 X11 Y0 Z2 ; set Z probe trigger value, offset and trigger height
M557 R130 S20 ; define mesh grid; Heaters
M143 H2 S280 ; set temperature limit for heater 2 to 280C; Fans
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
M563 P1 S"1" D0 H1 F0 ; define tool 1
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings
m501; Miscellaneous
M501 ; load saved parameters from non-volatile memory -
@luca-Massimiliano said in DWC 3.1.1:
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0CYou only have one tool defined, so only one tool will show in the web interface.
You have the heater configured, but it needs to be associated with a tool to be controlled.
