Heigh error after calibrating
probe firmware
2.7k
    fcwilt @TristanKoeln
    @TristanKoeln said in Heigh error after calibrating:
    Startcode:
    M98 P"/macros/PLA_Offset" ;set z probe offsets
    G29 S1 ;load heighmap
    @Stephen6309 i add the macro thing xD
    Adjusting the probe Z trigger height is a curious way to make such an adjustment.
    The probe Z trigger height should be a constant that only varies with temperature perhaps.
    If you wish to tweak the Z height when printing different materials you may want to use the "baby steps" setting instead - see M290.
    You can, if you wish, make use of the filament handling feature of DWC to specify different filaments at the start of a print and obtain different Z height "tweaks" using M290 based on the selected filament.
    undefined 1 Reply Last reply 14 Mar 2021, 12:32 Reply Quote 0
      TristanKoeln @fcwilt
      @fcwilt thx for you advice, but first i want that my printer prints something befor i will realy start tweaking out some thing, right now my problem is that the nozzel is allways 1-2 mm to high
      undefined 1 Reply Last reply 14 Mar 2021, 12:36 Reply Quote 0
        OK that should be easy to correct.
        One thing you need to remember is that before creating a height map with G29 S0 and before loading the height map with G29 S1 you need to perform a G1 to move the probe to the center of the bed and then do a single G30 to set the Z=0 datum.
        And of course for the Z probe to work properly it's Z trigger height value (in G31) needs to be set to the correct value.
        undefined 1 Reply Last reply 14 Mar 2021, 16:32 Reply Quote 0
          TristanKoeln
          @fcwilt all of that is done see in the homeZ and the trigger hiegh is calibrated with :
          Move the nozzel to the middle
          G30
          than moving nozzel down till it hits the bed
          G92 Z0
          G1 Z10
          G30 S-1
          undefined 1 Reply Last reply 14 Mar 2021, 13:40 Reply Quote 0
            G30
            G92 Z0
            G1 Z10
            G30 S-1
            That calibration looks fine.
            However homeZ.g looks a bit wonky.
            I've re-posted it here using the </> tag:
            ; homez.g
            ; called to home the Z axis
            G91 ; relative positioning
            G1 H2 Z10 F6000 ; lift Z relative to current position
            G1 H1 Z-500 F3000 ;Go down till endstop
            G1 H2 Z10 F6000
            G1 X200 Y200 F4000 ;go to midle
            G30 ; move Z down until the endstop is triggered
            G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
            ;G91 ; relative positioning
            ;G1 Z10 F100 ; lift Z relative to current position
            G90 ; absolute positioning
            This line, which occurs after the G30, may be the cause of your problems:
            On my printer, running firmware 3.2.2, after a G30 the Z position is the probe dive height (the H parameter in M558) plus the Z trigger height (the Z parameter in G31).
            But the G92 is telling the firmware that the Z position is 0.
            Perhaps that is correct for your firmware but it would cause a problem with mine.
              TristanKoeln
              @fcwilt with the G92 Z(dive heigh+triger high)
              is still the same problem
              undefined 2 Replies Last reply 14 Mar 2021, 14:33 Reply Quote 0
                After you performed the calibration routine you posted did you go back and update the G31 command with the correct Z trigger height as reported by the G30 S-1?
                  TristanKoeln
                  @fcwilt jup its 3.760
                  undefined 1 Reply Last reply 14 Mar 2021, 14:36 Reply Quote 0
                    Since the G30 leaves Z at dive height + trigger height setting it again to the same value with G92 is redundant.
                    It doesn't hurt but isn't needed.
                      Are you still running the "PLA" macro?
                      If so what does it look like.
                        TristanKoeln
                        @fcwilt
                        G31 X-31.7 Y3,16 Z3,760 P25
                        M291 P"PLA Offset" S0 T5
                        undefined 1 Reply Last reply 14 Mar 2021, 14:50 Reply Quote 0
                          @fcwilt
                          And that is the height reported by your calibration routine?
                            TristanKoeln
                            @fcwilt ya
                              fcwilt
                              Recall that before creating a height map with G29 S0 or before loading the height map with G29 S1 you need to position the probe to the center of the bed and do a single G30 to set the Z=0 datum.
                              Having set the Z trigger height to the value as reported by your calibration routine did you go back and re-create the height map using the new value?
                              Are you also setting the Z=0 datum when loading the new height map?
                              I mentioned that changing the Z trigger height to accommodate different filaments was not a good approach - one reason being is that it will mess up setting the Z=0 datum which may cause the height map to not work right.
                                TristanKoeln
                                @fcwilt i reprobed everything still same problem, could it be something with the zmin stop and the prob are on 2 diff heights? if yes what would be the solution
                                  fcwilt
                                  I've re-posted your files using the </> tag - it saves everyone the trouble of downloading your files.
                                  Would you look at them and verify they are your current files?
                                  ; generated by RepRapFirmware Configuration Tool v3.2.1 on Mon Jan 18 2021 17:44:49 GMT+0100 (Mitteleuropäische Normalzeit)
                                  M550 P"BIGCREATOR" ; set printer name
                                  M552 S1 ;Tun Network ON
                                  M569 P3 S0 ; physical drive 3 goes forwards
                                  M569 P4 S1 ; physical drive 4 goes forwards
                                  M584 X0 Y1 Z2:4 E3 ; set drive mapping
                                  M350 X16 Y16 Z16:16 E16 I1 ; configure microstepping with interpolation
                                  M92 X80.00 Y100.00 Z405:405.00 E750.00 ; set steps per mm
                                  M566 X1800.00 Y1800.00 Z120.00:120.00 E500.00 ; set maximum instantaneous speed changes (mm/min)
                                  M203 X36000.00 Y36000.00 Z200.00:200.00 E500.00 ; set maximum speeds (mm/min)
                                  M201 X1000.00 Y1000.00 Z400.00:400.00 E500.00 ; set accelerations (mm/s^2)
                                  M906 X1200 Y1200 Z1000:1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
                                  M84 S30 ; Set idle timeout
                                  M208 X0 Y0 Z-10 S1 ; set axis minima
                                  M208 X440 Y440 Z400 S0 ; set axis maxima
                                  M574 Z1 S1 P"!zstop+!e1stop" ; configure active-high endstop for low end on Z via pin zstop
                                  M558 P9 C"^zprobe.in" H5 F120 T5000 ; BLTouch connected to Z probe IN pin
                                  M950 S0 C"exp.heater3" ; create servo/gpio 0 on heater 3 pin on expansion connector
                                  M98 P"/macros/NORMAL_Offset" ; set z probe offsets
                                  M280 P0 S10 ; send control signal to BLTouch through servo/gpio 0
                                  ;G31 P500 X0 Y0 Z25 ; set Z probe trigger value, offset and trigger height
                                  M557 X10:390 Y10:390 S38:38 ; define mesh grid
                                  M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
                                  M308 S1 P"e1temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as PT1000 on pin e0temp
                                  M950 F0 C"fan0" Q0 ; create fan 0 on pin fan0 and set its frequency
                                  ;M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
                                  M950 F1 C"fan1" Q0 ; create fan 1 on pin fan1 and set its frequency
                                  ;M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
                                  M950 F2 C"fan2" Q0 ; create fan 2 on pin fan2 and set its frequency
                                  ;M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
                                  M563 P0 S"WaterColledHead" D0 H1 F-1 ; define tool 0
                                  G28 ; home
                                  ; bed.g
                                  G28 ;home
                                  G29 S1 ; probe the bed and enable compensation
                                  M280 P0 S90 ; retractProbe
                                  ; homez.g
                                  G1 H2 Z10 F6000
                                  ; homeall.g
                                  ; called to home all axes
                                  ;DUAL Z
                                  M584 Z2:4
                                  M280 P0 S90
                                  G1 H1 X-405 Y-405 F5000 ; move quickly to X and Y axis endstops and stop there (first pass)
                                  G1 H2 X5 Y5 F6000 ; go back a few mm
                                  G1 H1 X-405 Y-405 F360 ; move slowly to X and Y axis endstops once more (second pass)
                                  M98 Phomez.g ; move Z down stopping at the endstop
                                  G92 Z10 ; set Z position to axis minimum (you may want to adjust this)
                                  ;G90 ; absolute positioning
                                  undefined 1 Reply Last reply 14 Mar 2021, 17:11 Reply Quote 0
                                    Stephen6309 @fcwilt
                                    @fcwilt I adjust the Z offset so I don't have to remember to do baby steps on every print. Currently I only change the filament when I run out on the spool.
                                    undefined 1 Reply Last reply 14 Mar 2021, 16:47 Reply Quote 0
                                      fcwilt @Stephen6309
                                      @Stephen6309 said in Heigh error after calibrating:
                                      As I said changing the Z trigger height may cause the height map to not work correctly.
                                      And as I said you can use the filament management feature of DWC to allow you to select different filament types and make any adjustments desired to things like extruder temp, extrusion multiplier, baby step settings and more.
                                      You don't have to do it for every print - it will happen automatically if your "print start" code invokes the the command needed to trigger the changes specified by the current filament.
                                      Here is an example of a filament configuration file. Every filament type you enter into the DWC filament management feature will have it's own configuration file.
                                      M221 S100 D0 ; set extrusion multiplier
                                      G10 S200 R0 ; set extruder temps
                                      M140 S60 R0 ; set bed temps
                                      Here are the commands you would place into your "print start" code that will invoke the configuration file for the currently selected filament type.
                                      T0 ; select tool 0 so extruder commands below will work
                                      M703 ; configure selected filament
                                      So once you select a filament type it will remain selected and every print will run the commands you have entered into the configuration file for that filament type.
                                      undefined 1 Reply Last reply 14 Mar 2021, 17:01 Reply Quote 0
                                        Stephen6309 @fcwilt
                                        @fcwilt In my slicer's start gcode, I call the macros, then home, then G32 which does a G29 S1 or S0 depending on if it finds heightmap.csv. Never had a problem with the heightmap working correctly.
                                          @fcwilt
                                          @fcwilt said in Heigh error after calibrating:
                                          G28 ; home
                                          ; bed.g
                                          G28 ;home
                                          ; homez.g
                                          G1 H2 Z10 F6000
                                          ; homeall.g
                                          ;DUAL Z
                                          M584 Z2:4
                                          M280 P0 S90
                                          yaa its my current
                                          undefined 1 Reply Last reply 14 Mar 2021, 17:31 Reply Quote 0
                                          19 out of 59
