Delta z axis position is wrong 3.2.2
Firmware installation
468
    manpowre
    I've been knocking myself today as I can't seem to figure this one out.
    I installed a duet3d 2 1.04 board into my Flsun QQ-S delta printer and configured it from a kossel config file and started fine tuning the setup. I got the x+y motors to home until they hit the end-stops, but the z axis doesnt move at all.
    I noticed that the machine status says x=0, y=0, z=220. I guess Z should be 0 too as this is a delta printer.
    The only place I could find a 220 reference when starting the printer is the M665 R104.3 L215 B104 H220 command. The last parameter is 220. and the Z axis gets set to this value when firmware starts up.
    I did try to set a G92 at the end of the file but that didnt help -->"G92 X0 Y0 Z0"
    For some reason the interface is also weird, it seems like it stops loading. It could mabye have to do with the M665 command and the weird Z position when firmware loads up ?
    Heres the config.g file:
    M550 P"qq-spro" ; set printer name
    M665 R104.3 L215 B104 H220 ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
    M551 P"pi" ; set password
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S1 ; enable FTP
    M586 P2 S1 ; enable Telnet
    M569 P0 S0 ; physical drive 0 goes backwards
    M569 P2 S0 ; physical drive 2 goes backwards
    M92 X79.30 Y79.30 Z79.30 E95.70 ; set steps per mm
    M566 X1200.00 Y1200.00 Z1200.00 E6000.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X18000.00 Y18000.00 Z18000.00 E6000.00 ; set maximum speeds (mm/min)
    M201 X2000.00 Y2000.00 Z2000.00 E2000.00 ; set accelerations (mm/s^2)
    M906 X1200 Y1200 Z1200 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 Z0 S1 ; set minimum Z
    M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
    M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
    M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
    M558 P5 C"^zprobe.in" H5 F600 T9000 ; set Z probe type to switch and the dive height + speeds
    G31 P25 X-2 Y-2 Z20 ; set Z probe trigger value, offset and trigger height
    M557 R100 S40 ; define mesh grid
    M106 P1 S1 H1 T38 ; set fan 1 value. Thermostatic control is turned on
    M950 F2 C"fan1" Q500 ; create fan 2 on pin fan1 and set its frequency
    M106 P2 S1 H1:0 T38 ; set fan 2 value. Thermostatic control is turned on
    ; Custom settings
    ; M591 D0 C3 P2 E6.0 ;This is the command for filament monitoring using an optical on/off switch
    M579 X1.012 Y0.9871
    M564 H0 ;allow to axis to be moved before homing
      manpowre
      I did swap Z and X wiring including endstops to see if the Z motor were actually moving.. and it did move just like x and y motors.. just that when X motor came into the Z slot on the board the X motor didnt move either.
        Can you post the results of M122 and M98 P"config.g"?
        What URL are you using to reach DWC? Have you tried a hard refresh of the page? Clear browser cache?
          Veti
          @manpowre said in Delta z axis position is wrong 3.2.2:
          does your ui version match your firmware? i think you are running an old ui version
            manpowre
            I was initially thinking it might be the browser, as I use firefox, but then changed to chrome and Edge and the same thing happened.I use http://192.168.2.237 to access the web interface.
            I had to run these 2 commands through YAT as the web interface disconnects constantly too.. The wifi firmware is updated to 1.25 as it didnt update with the 3.2.2 package. so I did that separately.
            thanks for taking a look at this with me 🙂
            M122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
            Board ID: 08DGM-917NK-F2MS4-7JTD0-3SN6T-KGU0H
            Used output buffers: 1 of 24 (12 max)
            Static ram: 23460
            Dynamic ram: 72480 of which 56 recycled
            Never used RAM 16084, free system stack 187 words
            Tasks: NETWORK(ready,413) HEAT(blocked,314) MAIN(running,404) IDLE(ready,20)
            Owned mutexes: USB(MAIN)
            Last reset 00:00:22 ago, cause: power up
            Last software reset time unknown, reason: User, GCodes spinning, available RAM 16084, slot 2
            Error status: 0x00
            Aux0 errors 0,0,0
            MCU temperature: min 37.2, current 37.4, max 37.6
            Supply voltage: min 1.3, current 1.3, max 1.4, under voltage events: 0, over voltage events: 0, power good: no
            Driver 0: position 32355, ok, SG min/max not available
            Driver 1: position 32355, ok, SG min/max not available
            Driver 2: position 32355, ok, SG min/max not available
            Driver 3: position 0, ok, SG min/max not available
            Driver 4: position 0, ok, SG min/max not available
            Driver 5: position 0
            Driver 6: position 0
            Driver 7: position 0
            Driver 8: position 0
            Driver 9: position 0
            Driver 10: position 0
            Driver 11: position 0
            Cache data hit count 29264375
            Slowest loop: 4.54ms; fastest: 0.13ms
            === Storage ===
            Free file entries: 10
            SD card longest read time 0.2ms, write time 0.0ms, max retries 0
            === MainDDARing ===
            === AuxDDARing ===
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is ready with "M122" in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            Daemon is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 201.80ms; fastest: 0.10ms
            HTTP sessions: 0 of 8
            - WiFi -
            Network state is active
            Failed messages: pending 0, notready 0, noresp 1
            WiFi firmware version 1.25
            WiFi MAC address 8c:aa:b5:d5:70:a5
            WiFi Vcc 3.35, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 24304
            WiFi IP address 192.168.2.237
            WiFi signal strength -42dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
            ok
            M98 P"config.g"
            HTTP is enabled on port 80
            FTP is enabled on port 21
            TELNET is enabled on port 23
            Error: Pin 'fan1' is not free
            Error: Fan number 2 not found
            ok
              manpowre
              I decided to update to latest firmware to see. still getting the buttons on the web interface to collapse. The wifi part is compatible with 1.25 so that didnt get updated.
              M115
              FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3beta2 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-03-10 13:24:09
              M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3beta2 running on Duet WiFi 1.02 or later
              Used output buffers: 1 of 24 (13 max)
              Static ram: 21568
              Dynamic ram: 74340 of which 0 recycled
              Never used RAM 18508, free system stack 186 words
              Tasks: NETWORK(notifyWait,218) HEAT(delaying,310) MAIN(running,405) IDLE(ready,20)
              Owned mutexes: WiFi(NETWORK) USB(MAIN)
              Last reset 00:03:54 ago, cause: software
              Error status: 0x00
              Aux0 errors 0,0,0
              MCU temperature: min 40.0, current 40.5, max 40.9
              Supply voltage: min 1.3, current 1.4, max 1.4, under voltage events: 0, over voltage events: 0, power good: no
              Cache data hit count 268341907
              Slowest loop: 5.33ms; fastest: 0.14ms
              === Storage ===
              === MainDDARing ===
              === AuxDDARing ===
              Segments left: 0
              === Network ===
              Slowest loop: 199.89ms; fastest: 0.09ms
              - WiFi -
              WiFi signal strength -44dBm, mode 802.11n, reconnections 0, sleep mode modem
              ok
              M98 P"config.g"
              ok
                manpowre
                And i updated the web interface as the instructions here
                https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Updating_DuetWebControl_files
                and new web interface.. and the collapse is gone and I see the updated one.
                now back to my original problem.
                the Z axis reports 220 in status area for Machine position while x and y is 0.
                undefined undefined 2 Replies Last reply 16 Mar 2021, 09:47 Reply Quote 0
                  jay_s_uk @manpowre
                  @manpowre the Z in the status window is the height not the Z tower.
                  That implies the nozzle is at the centre of the bed, 220mm away from the build surface
                    droftarts administrators @manpowre
                    @manpowre As @jay_s_uk says, the web interface reports the nozzle position in X, Y and Z cartesian coordinates, not the position of each tower, on a Delta. So this is normal and correct.
                    If the Z axis isn't moving at all, check that you have the jumpers on the second Z motor pin header. See the wiring diagram here: https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
                    Otherwise, as you've already tested the Z motor on another axis and it works, and tested another working motor on the Z axis and it doesn't work, it's possible that the motor driver has failed. Check both sides of the board around the to see if there's any obvious damage, or if the pins of the motor connectors are not soldered (occasionally happens). Post a picture if you're not sure.
                    Finally, the Z axis is close to the mounting hole; check that it's not shorting on the back of the board across to any mounting screws.
                    If it does look like the stepper driver has failed, please let me know when and where you bought it from.
                    Finally (again) you could move the Z axis onto the spare driver 4 (labelled E1). In config.g, add M569 P4 S1 and change M584 to M584 X0 Y1 Z4 E3. This should get you going. Though if it's a warranty, you'll be better off exchanging the board.
                    Let me know how you get on.
                      manpowre
                      @droftarts thank you very much for excellent explanation. it was the missing 2x jumper. I came home from work and connected the 2 jumpers and all 3 motors home successfully. Yesterday I had several issues updating the software was one including web interface, wifi firmware and not to mention the upgrade process from 2.x reprap to 3.x reprap that has to go through 3.0 to get to 3.2. During work today I was thinking mabye I could try to use the last stepper driver instead. didnt know if that would work, as you confirmed my thoughts are in the same direction if the z driver wouldnt work.
                      thanks.. the response I got here sorted me out.. now off to configuring this to work with correct dimensions.
                      7 out of 10
