    BLTouch not Triggering
    Third-party add-ons
    4.7k
      Can you provide the results of sending M122 and M98 P"config.g" in the console?
      Your config looks correct and your wiring sounds correct, but let's make sure you're on RRF3 to match your config.
      Failing to trigger usually means there is a bad connection on the white wire. Either in the wiring itself or perhaps internal to the BLTouch.
      Mac3D-FPVundefined 1 Reply Last reply Reply Quote 0
      • Mac3D-FPVundefined
        Mac3D-FPV @Phaedrux
        What version BLTouch do you have? It is typically printed on the PCB visible from the outside of the BLTouch.
        brewchesterundefined 1 Reply Last reply Reply Quote 0
        • brewchesterundefined
          brewchester @Mac3D-FPV
          @Mac3D-FPV said in BLTouch not Triggering:
          Version 3.1 - I believe I got it from Matterhackers.
            brewchester
            Here's the M122 @Phaedrux :
            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet Ethernet 1.02 or later
            Board ID: 0JD0M-9P6M2-NWNS4-7J1F8-3SN6N-KU23K
            Used output buffers: 1 of 24 (18 max)
            Static ram: 23460
            Dynamic ram: 72736 of which 40 recycled
            Never used RAM 15844, free system stack 193 words
            Tasks: NETWORK(ready,160) HEAT(blocked,308) MAIN(running,453) IDLE(ready,20)
            Owned mutexes: HTTP(MAIN)
            Last reset 03:32:54 ago, cause: software
            Last software reset at 2021-03-16 12:04, reason: User, GCodes spinning, available RAM 15844, slot 1
            Error status: 0x00
            Aux0 errors 0,0,0
            MCU temperature: min 16.3, current 18.6, max 19.0
            Supply voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0, over voltage events: 0, power good: yes
            Driver 0: position 0, standstill, SG min/max not available
            Driver 1: position 0, standstill, SG min/max not available
            Driver 2: position 0, standstill, SG min/max not available
            Driver 3: position 0, standstill, SG min/max not available
            Driver 4: position 0, standstill, SG min/max not available
            Driver 5: position 0
            Driver 6: position 0
            Driver 7: position 0
            Driver 8: position 0
            Driver 9: position 0
            Driver 10: position 0
            Driver 11: position 0
            Date/time: 2021-03-16 15:37:48
            Slowest loop: 14.55ms; fastest: 0.22ms
            === Storage ===
            Free file entries: 10
            SD card longest read time 3.9ms, write time 0.0ms, max retries 0
            === MainDDARing ===
            === AuxDDARing ===
            Segments left: 0
            Movement lock held by null
            HTTP is ready with "M122 and M98 P"config.g"" in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            Daemon is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 10.93ms; fastest: 0.02ms
            HTTP sessions: 2 of 8
            Interface state active, link 100Mbps full duplex
            HTTP is enabled on port 80
            FTP is disabled
            TELNET is disabled
            Error: Heater 7 not found
            Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
            3/16/2021, 3:37:49 PM	M122 and M98 P"config.g"
            Static ram: 23460
            Error status: 0x00
            Aux0 errors 0,0,0
            === Storage ===
            === MainDDARing ===
            === AuxDDARing ===
            Segments left: 0
            === Network ===
            FTP is disabled
            TELNET is disabled
              Phaedrux Moderator @brewchester
              @brewchester said in BLTouch not Triggering:
              Is the deploy and retract commands working? M401 and M402?
                brewchester @Phaedrux
                @Phaedrux said in BLTouch not Triggering:
                Yes they are.
                  Can you post a photo of the wiring at the board? Just the other day someone had connected the white wire to the PanelDue port rather than the Z probe port... never hurts to have a second pair of eyes.
                      Mac3D-FPV @brewchester
                      @brewchester Just checking to best sure. BLTouch version 3.1, at least for me, worked out of the box (after adjusting the mounting height). Earlier versions required cutting a trace on the PCB to operate on 3.3V logic; this was not required for the v3.1.
                      Here are my BLTouch settings (I am on firmware version 3.1.1), if it helps:
                      M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
                      M558 P9 C"^zprobe.in" H5 F90 T10800 A10 S0.005 ; set Z probe type to bltouch and the dive height + speeds probe up to 5 times until 2 consecutive readings are within 0.005, if none average of 5
                      G31 P500 X67.5 Y-11.5 Z2.946 ; set Z probe trigger value, offset and trigger height
                      M557 X70:280 Y15:255 S30 ; define mesh grid
                      The mounting specs (for the pin height relative to the tip of the nozzle) for the BLTouch, if I recall correctly, changed with the v3.1, compared to earlier 2.X versions. You might want to double check the antclabs manuals (available at www.antclabs.com) to verify your retracted pin height is within that specified for the v3.1 ). I have mine at 3.3mm above the nozzle tip - in the middle of the acceptable range.
                        Thanks... I haven't let it drive to the bed yet and only have been using my hand to try and trigger the touch. The height shouldn't matter at this point correct?
                          Mac3D-FPV
                          You are correct, the height would not matter at that point.
                            Yes they are.
                            Error: Heater 7 not found This error message is a bit confusing then.
                            Could you change from that heater 7 pin to heater 3/pin 8 on the expansion header? Then change the reference to exp.heater7 to exp.heater3 and send M98 P"config.g" again to see if it's still complaining about heater 7.
                            • Vetiundefined
                              Veti
                              if deploy and retract are working then the servo part of the bltouch is working.
                              the trigger signal is the problem.
                                Yes they are.
                                I've done this a few times and it has the same affect. I've tried 3, 5, and 7 and it still won't trigger.
                                • Vetiundefined
                                  Veti
                                  if you have revision 1.04 of the duet you can try chaning the trigger logic
                                  using
                                  M280 P0 S140
                                  and
                                  M280 P0 S150
                                    brewchester @Veti
                                    @Veti said in BLTouch not Triggering:
                                    M280 P0 S150
                                    Where would I put those commands? I ran them and they don't do anything. Well, it comes up green, but that's it.
                                      The commands are for the BLTouch so you just send them once.
                                      There is this page from antclabs that you could try.
                                      https://www.antclabs.com/logic
                                        Phaedrux Moderator @Veti
                                        Yes, just wondering why it's complaining about heater 7. I don't think it's references in config.g other than in his M950 for the bltouch.
                                          Is it because I added the line:
                                          M307 H7 A-1 C-1 D-1
                                            Ah ok. I guess that would have been added after you shared the config.g above.
