    Core XYU Z Movement Issue
    2.0k
      firmware version? Duet board type?
      pcsentinelundefined 1 Reply Last reply Reply Quote 0
        ;M669 K5 ; switch to CoreXY mode
        M669 K1 X1:1:0:0 Y1:-1:0:1 Z0:0:1:0 U0:0:0:1
        M669 K5 should work for corexyu. Why did you switch to a custom matrix?
        • pcsentinelundefined
          pcsentinel @Phaedrux
          Duet 2
          Firmware 2.05.1
            Because there is a fault with K5 that is not corrected until V3. I do not really want to go to V3 yet.
            https://forum.duet3d.com/topic/20164/g30-g32-issues-on-duet-wifi-corexyu-with-inductive-probe/7?_=1612371745630
              dc42 administrators @pcsentinel
              @pcsentinel said in Core XYU Z Movement Issue:
              I have just started to work towards dual printing, but the issue I have just discovered is that when X is active then Z movement is as you would expect, however when U is active and you try and change Z then the Z Carriage moves as expected but at the same time the U carriage is moved towards its home location.
              Are you sure you mjean Z and not Y? What is the "Z carriage"?
                pcsentinel
                Hi DC42, following further tests, it seems to happen with both Y and Z instructions. So with the attached video, The active tool is Tool 1 (U) and I have sent a G1 Z25. The U Carriage moves back to Home and the Z Carriage moves down . If you then send a U-1 from the console. the U moves back to its original location and 1 left.IMG_3633.mp4
                When Tool 0 is active (X) then all works properly.
                  What that homing move shown in the video?
                  Can you pot your homing files and any tool change files?
                    pcsentinel
                    The homing move was not called, that just occurs when you do a Z or Y move, that's the whole issue. The tool files are empty.
                    If I make Tool 0 o r Tool 2 active (which does not exist I know), then Z and Y moves act as expected. This only occurs when Tool 1 is active
                    • hackinistratorundefined
                      hackinistrator
                      why do you have v axis defined ?
                        pcsentinel @hackinistrator
                        @hackinistrator Because I am using the same logic as worked out in https://forum.duet3d.com/topic/16375/core-xyu-or-xyuv/25?_=1615925048500
                        Which means (as far as I understand) you have 4 motors for a core XYU all of which need to move independently to achieve XY or UY movement.
                        As I've said above, All X Y U Z movement works absolutely fine when T0 is the active tool, than anomaly only happens when T1 is active.
                        hackinistratorundefined 1 Reply Last reply Reply Quote 0
                          hackinistrator @pcsentinel
                          @pcsentinel i think you are making a mess .
                          for dual carriage (coreXY) printer , if you have 2 motors for each carriage , then its XYUV .
                          if the second carriage connected to a single motor then its XYU .
                          your matrix defined as XYU , but drive mapping its XYUV .
                          how is the second carriage actually connected ?
                            @hackinistrator Sorry, but I think you are wrong, please see: the link from above. Also the firmware code from the Duet is as follows:
                            case KinematicsType::coreXYU:
                            	// Core XYU is like CoreXY with an additional U axis controlled by the U and V motors
                            	inverseMatrix(0, 1) = 1.0;
                            	inverseMatrix(1, 0) = 1.0;
                            	inverseMatrix(1, 1) = -1.0;
                            	inverseMatrix(1, 3) = 1.0;
                            	inverseMatrix(1, 4) = -1.0;
                            	inverseMatrix(3, 4) = 1.0;
                            	inverseMatrix(4, 4) = 0.0;		// V can't be commanded directly
                            	break;
                            case KinematicsType::coreXYUV:
                            	// CoreXYUV is a dual CoreXY setup
                            	inverseMatrix(4, 3) = 1.0;
                            	inverseMatrix(4, 4) = -1.0;
                            	break;
                            i.e. a core XYUV effectively has two XY carriages whereas a Core XYU has 2 heads mounted on a single Y carriage.
                            I am guessing I have 1 setting wrong somewhere that is causing this issue. Do you have a Core XYU machine, if so maybe you could post the config.g so that I can do a comparison.
                            Rushmere3Dundefined hackinistratorundefined 2 Replies Last reply Reply Quote 0
                            • Rushmere3Dundefined
                              Rushmere3D @pcsentinel
                              @pcsentinel
                              Can you post some pictures of your machine?
                              Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
                                @pcsentinel please tell hoy many motors connected to your second carriage .
                                its possible to make coreXYUV with single gantry , if 2 motors control second carriage .
                                  @hackinistrator There are4 motors controlling the XYU carriage. please see my post above which shows you that the firmware defines that as being core XYU
                                    hackinistrator
                                    then its core XYUV , your m669 is wrong .
                                      @hackinistrator 4 motors:
                                      break;
                                        pcsentinel @Rushmere3D
                                        @Rushmere3D Hi, please see the video linked above and below.
                                          hackinistrator
                                          you defined custom matrix , not just K5 or K8 . your m669 is wrong .
                                          if you have 4 motors for XYUV
                                          matrix should be something like that :
                                          M669 X1:1:0:0:0   Y1:-1:0:1:-1 Z0:0:1:0:0 U0:0:0:1:1 V1:-1:0:1:-1
                                            pcsentinel
                                            I will look at the matrix, but I am failing to understand the relationship to the actual issue, which is that when Tool 0 is active then everything works fine, but when Tool 1 is active then the U is parked for any Y or Z moves.
                                            To prove it, here is a video taken with Tool 0 active.x1.mp4
