    BLTouch not Triggering
    Third-party add-ons
    4.7k
      Phaedrux Moderator @brewchester
      @brewchester said in BLTouch not Triggering:
      @Phaedrux said in BLTouch not Triggering:
      Error: Heater 7 not found
      Is the deploy and retract commands working? M401 and M402?
      Yes they are.
      Error: Heater 7 not found This error message is a bit confusing then.
      Could you change from that heater 7 pin to heater 3/pin 8 on the expansion header? Then change the reference to exp.heater7 to exp.heater3 and send M98 P"config.g" again to see if it's still complaining about heater 7.
      brewchesterundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti
        if deploy and retract are working then the servo part of the bltouch is working.
        the trigger signal is the problem.
        • brewchesterundefined
          brewchester @Phaedrux
          Yes they are.
          I've done this a few times and it has the same affect. I've tried 3, 5, and 7 and it still won't trigger.
          • Vetiundefined
            Veti
            if you have revision 1.04 of the duet you can try chaning the trigger logic
            using
            M280 P0 S140
            and
            M280 P0 S150
              brewchester @Veti
              @Veti said in BLTouch not Triggering:
              M280 P0 S150
              Where would I put those commands? I ran them and they don't do anything. Well, it comes up green, but that's it.
                The commands are for the BLTouch so you just send them once.
                There is this page from antclabs that you could try.
                https://www.antclabs.com/logic
                  Phaedrux Moderator @Veti
                  Yes, just wondering why it's complaining about heater 7. I don't think it's references in config.g other than in his M950 for the bltouch.
                    Is it because I added the line:
                    M307 H7 A-1 C-1 D-1
                      Ah ok. I guess that would have been added after you shared the config.g above.
                        I removed that line and re-ran M122... heater7 issue isn't there anymore. Still no luck on the trigger though. Tried the logic that antclabs suggests but same results.
                          brewchester
                          So... also, the Z-Probe always reads as "0" no matter what. Same on either of the pins I try. Is there a way I can test the signal with a multimeter? To see if the BLT is sending a signal to the board? Then, if it is, I couldn't imagine the board being bad, but then again stranger things have happened to me.
                            The way the BLtouch triggers and then immediately resets means you won't usually catch a glimpse of the z-probe status changing in the web interface, so that's not a reliable indicator of it working. The static test during a G30 move is the only way to really know.
                            I don't think it will make a differene but you can try removing the ^ from the pin name C"^zprobe.in"
                            Having a second bltouch to test with might be a good sanity check.
                              Just purchased one from Amazon. Fingers crossed that does the trick. I'm doubtful though because this was working just fine with my other board, but I get it, it's usually the easy things that wind up being the issue.
                                brewchester
                                Welp... as always, you guys are right. Must have had a short in the original wire because I got the new BLT and just by replacing the harness did it start to work. Let this be another lesson to everyone... if your BLtouch doesn't work, get some new wires.
                                the-bigundefined 1 Reply Last reply Reply Quote 1
                                • the-bigundefined
                                  the-big @brewchester
                                  @brewchester I’m have same problem after updating from RRF 2.2 to 3.3
                                  Can’t hame z.
                                  What solve your problem?
