Solved Bed leveling going to wrong side.
config overrride g: Is it right?
; config-override.g file generated in response to M500 at 2021-03-15 22:42
; Heater model parameters
M307 H0 R0.315 C510.587:510.587 D7.27 S1.00 V23.6 B0
M307 H1 R3.445 C151.950:151.950 D6.86 S1.00 V23.8 B0
; Workplace coordinates
G10 L2 P1 X0.00 Y0.00 Z0.00
G10 L2 P2 X0.00 Y0.00 Z0.00
G10 L2 P3 X0.00 Y0.00 Z0.00
G10 L2 P4 X0.00 Y0.00 Z0.00
G10 L2 P5 X0.00 Y0.00 Z0.00
G10 L2 P6 X0.00 Y0.00 Z0.00
G10 L2 P7 X0.00 Y0.00 Z0.00
G10 L2 P8 X0.00 Y0.00 Z0.00
G10 L2 P9 X0.00 Y0.00 Z0.00
M486 S-1 -
@esobreiro if your bed homes front right, this X maximum and Y minimum. So you need to change your Y endstop from maximum to minimum. Change Y endstop to:
M574 Y1 S1 P"!ystop"
However, changing this may show other problems. Have you checked your CoreXY motors go the correct way when commanded? See https://duet3d.dozuki.com/Wiki/Test_axes_or_motors_individually
Please post your homing files as well. When you change the Y endstop you'll also need to change the direction of the homing move.
Actually this isn't too bad. The A B motors are in the back, so it's just a 180 degree flip of a corexy. The "front" of the machine is arbitrary, so as long as the 0,0 point is the front left and the X Y movement directions are correct your coordinate system will be correct.
Corexy can be tricky.
Go through this document. It has tests for movement to make sure things are setup correctly for corexy.
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter
@droftarts i tried but was not good...
@Phaedrux following my homing files:
homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Mar 15 2021 16:16:13 GMT-0300 (Horário Padrão de Brasília)
G91 ; relative positioning
G1 H1 X305 Y305 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X305 ; home X axis
G1 H1 Y305 ; home Y axis
G1 X-5 Y-5 F6000 ; go back a few mm
G1 H1 X305 F360 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y305 ; then move slowly to Y axis endstop
G90 ; absolute positioning
G1 X310 Y22 F6000 ; go to first bed probe point and home Z X-155 Y-75 F6000
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning
; homex.g
; called to home the X axis
G1 H1 X325 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 X-5 F6000 ; go back a few mm
G1 H1 X325 F360 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z-5 F6000 ; lower Z again
; homey.g
; called to home the Y axis
G1 H1 Y325 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y-5 F6000 ; go back a few mm
G1 H1 Y325 F360 ; move slowly to Y axis endstop once more (second pass)
; homez.g
; called to home the Z axis
G1 X-155 Y-75 F6000 ; go to first probe point ???
;G90 ; absolute positioning -
@esobreiro said in Bed leveling going to wrong side.:
When you change the Y endstop to be at the minimum side, you must then also change the direction of your Y homing moves from positive to negative. (and your back off moves from negative to positive)
@Phaedrux said in Bed leveling going to wrong side.:
-X should move to the left, +X to the right. -Y to the front, +Y to the back.
Is this how it's moving?
@Phaedrux Thanks again.
I did that because of this problem... I just revert and no success.
Now its homed at X:60 Y:30 with same behaivour.Best regards,
Erick
https://forum.duet3d.com/topic/14971/vcore-pro-core-xy-the-x-and-y-axis-home-issue/4?_=1616004568765
Take a look at this post it will lay out what you'll need to do to get the coordinate system correct.
but....
-y=backOk, that's a starting point.
Go through this test:
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
It will help you figure out what needs to change. It's likely that either one of the motors need a direction of rotation change and/or the motor plugs swapped. It will help you figure out which.
Not so fast...
After following the belt schema now, I have half bed and the following errors:
G32
Warning: Skipping grid point (36.0, 36.0) because Z probe cannot reach it
Warning: Skipping grid point (66.0, 36.0) because Z probe cannot reach it
Warning: Skipping grid point (96.0, 36.0) because Z probe cannot reach it
Warning: Skipping grid point (126.0, 36.0) because Z probe cannot reach it
Warning: Skipping grid point (156.0, 36.0) because Z probe cannot reach it
Warning: Skipping grid point (186.0, 36.0) because Z probe cannot reach it
Warning: Skipping grid point (216.0, 36.0) because Z probe cannot reach it
Warning: Skipping grid point (246.0, 36.0) because Z probe cannot reach it
Warning: Skipping grid point (276.0, 36.0) because Z probe cannot reach it
Warning: Skipping grid point (276.0, 66.0) because Z probe cannot reach it
Warning: Skipping grid point (246.0, 66.0) because Z probe cannot reach it
Warning: Skipping grid point (216.0, 66.0) because Z probe cannot reach it
Warning: Skipping grid point (186.0, 66.0) because Z probe cannot reach it
Warning: Skipping grid point (156.0, 66.0) because Z probe cannot reach it
Warning: Skipping grid point (126.0, 66.0) because Z probe cannot reach it
Warning: Skipping grid point (96.0, 66.0) because Z probe cannot reach it
Warning: Skipping grid point (66.0, 66.0) because Z probe cannot reach it
Warning: Skipping grid point (36.0, 66.0) because Z probe cannot reach it
Warning: Skipping grid point (36.0, 96.0) because Z probe cannot reach it
Warning: Skipping grid point (66.0, 96.0) because Z probe cannot reach it
Warning: Skipping grid point (96.0, 96.0) because Z probe cannot reach it
Warning: Skipping grid point (126.0, 96.0) because Z probe cannot reach it
Warning: Skipping grid point (156.0, 96.0) because Z probe cannot reach it
Warning: Skipping grid point (186.0, 96.0) because Z probe cannot reach it
Warning: Skipping grid point (216.0, 96.0) because Z probe cannot reach it
Warning: Skipping grid point (246.0, 96.0) because Z probe cannot reach it
Warning: Skipping grid point (276.0, 96.0) because Z probe cannot reach it -
G31 P500 X180 Y100 Z1.5
Is your probe really x180 and Y100 away from your nozzle tip?
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
Downgrading the firmware... and test....
I revert the firmware from 3.2 to 2.05.1 and everything is working fine. Thank you!
