    Duet3 Mini Stalling mid print
    724
    • WILD9undefined
      WILD9 @dc42
      @dc42 Thanks, in this case is VIN the 24V PSU as opposed to the separate 5V feeding the Duet/SBC?
      • WILD9undefined
        WILD9
        OK, Ordered a new PSU. Fingers crossed.
        • WILD9undefined
          WILD9
          No Luck, replacement Meanwell PSU installed and still coming back to occasionally find the printer stopped mid print.
          Latest M122:
          M122
          RepRapFirmware for Duet 3 Mini 5+ version 3.2.2 running on Duet 3 Mini5plus WiFi (SBC mode)
          Board ID: K1UT9-Z196U-D65J0-40KML-NY03Z-7ZF9S
          Used output buffers: 1 of 40 (10 max)
          Static ram: 98732
          Dynamic ram: 102268 of which 24 recycled
          Never used RAM 44192, free system stack 200 words
          Tasks: Linux(blocked,120) HEAT(blocked,315) CanReceiv(blocked,947) CanSender(blocked,372) CanClock(blocked,363) TMC(blocked,106) MAIN(running,519) IDLE(ready,20) AIN(blocked,272)
          Owned mutexes: HTTP(MAIN)
          Last reset 00:00:43 ago, cause: software
          Last software reset at 2021-03-16 08:05, reason: User, GCodes spinning, available RAM 44124, slot 2
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a
          Error status: 0x00
          Aux0 errors 0,0,0
          Aux1 errors 0,0,0
          Supply voltage: min 0.0, current 1.3, max 24.0, under voltage events: 1, over voltage events: 0, power good: no
          Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 33, reads 485, writes 9, timeouts 586, DMA errors 0, failedOp 0x6f
          Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 33, reads 483, writes 9, timeouts 588, DMA errors 0, failedOp 0x06
          Driver 2: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 33, reads 482, writes 9, timeouts 588, DMA errors 0, failedOp 0x41
          Driver 3: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 31, reads 467, writes 9, timeouts 603, DMA errors 0, failedOp 0x72
          Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 29, reads 484, writes 9, timeouts 587, DMA errors 0, failedOp 0x01
          Driver 5: position 0, assumed not present
          Driver 6: position 0, assumed not present
          Date/time: 2021-03-16 08:06:07
          Cache data hit count 114694806
          Slowest loop: 1.38ms; fastest: 0.09ms
          === Storage ===
          Free file entries: 10
          SD card 0 not detected, interface speed: 0.0MBytes/sec
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters = 0 -1, chamberHeaters = -1 -1
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty.
          === Filament sensors ===
          Extruder 0 sensor: no data received
          === CAN ===
          Messages queued 343, send timeouts 341, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
          === SBC interface ===
          State: 4, failed transfers: 0
          Last transfer: 4ms ago
          RX/TX seq numbers: 1654/1654
          SPI underruns 0, overruns 0
          Number of disconnects: 0, IAP RAM available 0x10eec
          Buffer RX/TX: 0/0-0
          === Duet Control Server ===
          Duet Control Server v3.2.2
          Code buffer space: 4096
          Full transfers per second: 38.93
          Maximum length of RX/TX data transfers: 3100/796
            droftarts administrators @WILD9
            @WILD9 said in Duet3 Mini Stalling mid print:
            That M122 report is interesting because it says the current voltage is 1.3V. If it says that, you can test the actual voltage with a multimeter as see if that’s true.
            WILD9undefined 1 Reply Last reply Reply Quote 0
            • Serbitarundefined
              Serbitar
              is your m122 being done automatically? (i.e. when powerloss is detected?)
                May be related to this https://forum.duet3d.com/topic/22031/duet-3-mini-5-vin-under-voltage-issues-in-sbc-mode/7. In summary, we have a few instances of what appear to be spurious under-voltage detection, always with the voltage being recorded as 0.0, and so far always when in SBC mode not standalone mode.
                • WILD9undefined
                  WILD9 @droftarts
                  @droftarts The duet controls my 24Vin it seems to have turned the relay off here hence the 1.3v reading but during printing I'm at 24v The same failures occur with the relay bypassed and Im now on my second 24V PSU.
                  @Serbitar No, that last one was manually run ~5 minutes after the print stopped but before I had taken any action to restart things.
                  @dc42 Thanks I will keep an eye on this, is there anything I can do to help with logging etc as I seem to have this occurring quite frequently at the moment.
                  • WILD9undefined
                    WILD9
                    Another failure so another m122 with the console messages precursing it:
                    8/03/2021, 08:42:37	m122
                    Used output buffers: 1 of 40 (13 max)
                    Static ram: 98732
                    Dynamic ram: 95896 of which 60 recycled
                    Never used RAM 50528, free system stack 124 words
                    Tasks: Linux(ready,77) HEAT(blocked,297) CanReceiv(blocked,947) CanSender(blocked,358) CanClock(blocked,362) TMC(blocked,106) MAIN(running,438) IDLE(ready,20) AIN(blocked,264)
                    Owned mutexes: Telnet(MAIN)
                    Last reset 15:36:04 ago, cause: power up
                    Last software reset at 2021-03-17 13:46, reason: User, none spinning, available RAM 44124, slot 1
                    Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a
                    Error status: 0x00
                    Aux0 errors 0,0,0
                    Aux1 errors 0,0,0
                    Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 4, over voltage events: 0, power good: yes
                    Driver 0: position -13134, ok, SG min/max 0/4, read errors 0, write errors 0, ifcnt 21, reads 18144, writes 0, timeouts 5, DMA errors 0, failedOp 0x06
                    Driver 1: position -6070, ok, SG min/max 0/18, read errors 0, write errors 0, ifcnt 21, reads 18148, writes 0, timeouts 1, DMA errors 0, failedOp 0x06
                    Driver 2: position 2057, standstill, SG min/max 0/6, read errors 0, write errors 0, ifcnt 20, reads 18148, writes 0, timeouts 1, DMA errors 0, failedOp 0x72
                    Driver 3: position 0, standstill, SG min/max 14/14, read errors 0, write errors 0, ifcnt 21, reads 18147, writes 0, timeouts 3, DMA errors 0, failedOp 0x6f
                    Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 19, reads 18149, writes 0, timeouts 0, DMA errors 0
                    Date/time: 2021-03-18 08:42:37
                    Slowest loop: 57.64ms; fastest: 0.09ms
                    === Storage ===
                    DMs created 83, maxWait 0ms, bed compensation in use: mesh, comp offset -0.147
                    === MainDDARing ===
                    Scheduled moves 554, completed moves 553, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                    === AuxDDARing ===
                    Heater 0 is on, I-accum = 0.2
                    Heater 1 is on, I-accum = 0.4
                    Segments left: 0
                    Movement lock held by HTTP
                    HTTP* is idle in state(s) 1 0, running macro
                    Telnet* is doing "M122" in state(s) 0
                    File* is idle in state(s) 0
                    Queue* is idle in state(s) 0
                    Extruder 0 sensor: ok
                    === CAN ===
                    Messages queued 1148, send timeouts 1148, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
                    Last transfer: 1ms ago
                    RX/TX seq numbers: 1256/35183
                    Buffer RX/TX: 2736/632-4080
                    HTTP:
                    Buffered code: G1 H1 X-305 Y-305 F240 ; move slowly to X and Y axis endstops once more (second pass)
                    Buffered code: G90 ; absolute positioning
                    Buffered code: G1 X3 Y300 F6000 ; go to first bed probe point and home Z
                    Buffered code: G30 ; home Z by probing the bed
                    ==> 152 bytes
                    Executing macro 0:/macros/Safety Home, started by M98 P"0:/macros/Safety Home"
                    > Next stack level
                    File:
                    Buffered code: G1 X75.475 Y162.206 E243.68582
                    Buffered code: G1 X151.794 Y238.525 E248.68940
                    Buffered code: G1 X152.582 Y238.525 E248.72595
                    Buffered code: G1 X75.475 Y161.418 E253.78122
                    Buffered code: G1 X75.475 Y160.629 E253.81777
                    Buffered code: G1 X153.371 Y238.525 E258.92473
                    Buffered code: G1 X154.159 Y238.525 E258.96128
                    Buffered code: G1 X75.475 Y159.841 E264.11994
                    Buffered code: G1 X75.475 Y159.052 E264.15649
                    Buffered code: G1 X154.948 Y238.525 E269.36683
                    Buffered code: G1 X155.736 Y238.525 E269.40339
                    Buffered code: G1 X75.475 Y158.264 E274.66543
                    Buffered code: G1 X75.475 Y157.475 E274.70198
                    Buffered code: G1 X156.525 Y238.525 E280.01571
                    Buffered code: G1 X157.313 Y238.525 E280.05226
                    Buffered code: G1 X75.475 Y156.687 E285.41769
                    Buffered code: G1 X75.475 Y155.898 E285.45424
                    Buffered code: G1 X158.102 Y238.525 E290.87136
                    Buffered code: G1 X158.890 Y238.525 E290.90791
                    Buffered code: G1 X75.475 Y155.110 E296.37672
                    Buffered code: G1 X75.475 Y154.322 E296.41328
                    Buffered code: G1 X159.678 Y238.525 E301.93378
                    Buffered code: G1 X160.467 Y238.525 E301.97033
                    Buffered code: G1 X75.475 Y153.533 E307.54253
                    Buffered code: G1 X75.475 Y152.745 E307.57908
                    Buffered code: G1 X161.255 Y238.525 E313.20298
                    Buffered code: G1 X162.044 Y238.525 E313.23953
                    Buffered code: G1 X75.475 Y151.956 E318.91511
                    Buffered code: G1 X75.475 Y151.168 E318.95166
                    Buffered code: G1 X162.832 Y238.525 E324.67894
                    Buffered code: G1 X163.621 Y238.525 E324.71549
                    Buffered code: G1 X75.475 Y150.379 E330.49446
                    ==> 1504 bytes
                    Code buffer space: 2104
                    Full transfers per second: 35.55
                    Maximum length of RX/TX data transfers: 3108/1608
                    File /opt/dsf/sd/gcodes/Front Mid_0.3mm_PETG_CR10_2h15m.gcode is selected, processing
                    ok
                    18/03/2021, 08:40:30	m122
                    Used output buffers: 1 of 40 (11 max)
                    Static ram: 98732
                    Tasks: Linux(ready,77) HEAT(blocked,297) CanReceiv(blocked,947) CanSender(blocked,358) CanClock(blocked,362) TMC(blocked,106) MAIN(running,519) IDLE(ready,20) AIN(blocked,264)
                    Last reset 15:33:56 ago, cause: power up
                    Error status: 0x00
                    Aux0 errors 0,0,0
                    Aux1 errors 0,0,0
                    Supply voltage: min 0.0, current 24.0, max 24.1, under voltage events: 4, over voltage events: 0, power good: yes
                    Driver 0: position 10866, standstill, SG min/max 0/36, read errors 0, write errors 2, ifcnt 21, reads 59697, writes 55, timeouts 433, DMA errors 0, failedOp 0x6f
                    Driver 1: position 17930, standstill, SG min/max 0/50, read errors 0, write errors 2, ifcnt 21, reads 52724, writes 55, timeouts 7405, DMA errors 0, failedOp 0x6a
                    Driver 2: position 57, standstill, SG min/max 0/24, read errors 1, write errors 2, ifcnt 20, reads 40721, writes 53, timeouts 19408, DMA errors 0, failedOp 0x72
                    Driver 3: position 0, standstill, SG min/max 0/42, read errors 0, write errors 2, ifcnt 21, reads 41378, writes 52, timeouts 18751, DMA errors 0, failedOp 0x72
                    Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 2, ifcnt 19, reads 60139, writes 45, timeouts 0, DMA errors 0
                    Date/time: 2021-03-18 08:40:30
                    Slowest loop: 176.39ms; fastest: 0.07ms
                    === Storage ===
                    DMs created 83, maxWait 47646562ms, bed compensation in use: mesh, comp offset -0.147
                    === MainDDARing ===
                    Scheduled moves 550, completed moves 550, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                    === AuxDDARing ===
                    Segments left: 0
                    === CAN ===
                    Messages queued 504335, send timeouts 504332, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
                    RX/TX seq numbers: 62260/30651
                    Buffer RX/TX: 2736/216-4080
                    File:
                    ==> 1504 bytes
                    Code buffer space: 2520
                    Full transfers per second: 35.60
                    18/03/2021, 08:39:12	Warning: VIN under-voltage event (0.0V)
                    18/03/2021, 08:39:12	Error: G0/G1: insufficient axes homed
                    18/03/2021, 08:32:13	Height map loaded from file heightmap.csv
                    18/03/2021, 08:29:22	T:26.5 /240.0 T0:26.5 /240.0 B:26.7 /80.0
                    the relevant log lines:
                    2021-03-18 08:39:13 Error: G0/G1: insufficient axes homed
                    2021-03-18 08:39:13 Warning: VIN under-voltage event (0.0V)
                    Unlike @serbitar I notice I have no
                    xxxx Print auto-paused due to low voltage
                    line in my logs which I can see in which I can see in Serbitars logs
                    I'm now trying to look into a simple way to log the Vout of the PSU directly during prints
                      Thanks, I think this is the same as https://forum.duet3d.com/topic/22031/duet-3-mini-5-vin-under-voltage-issues-in-sbc-mode/7 which has been reported by several users, so nothing to do with your PSU. The fact that the VIN reading is always 0.0 when it occurs confirms that. What I really need is a way of triggering this issue reliably so that I can test possible fixes. Please look at my most recent post in that thread.
                      • WILD9undefined
                        WILD9 @dc42
                        @dc42 Thanks, I will move over to that thread for discussion
