    Duet3 Mini Stalling mid print
    686
      T3P3Tony administrators
      @WILD9 you mention that the PSU is controlled from the Duet. can you temporarily remove that. That way if the reset of the duet is resetting the PSU then that part of the issue will stop happening, the Duet will remain powered and you can get the M122 report.
      WILD9undefined 1 Reply Last reply Reply Quote 0
      • WILD9undefined
        WILD9 @T3P3Tony
        @T3P3Tony Yes good idea, I will do that now.
        • WILD9undefined
          WILD9
          OK,luckily this failed again sooner rather than later, printer is currently in the failed state M122 below. I got the voltage warning again despite bypassing the relay for 24v.
          SBC uptime shows no reboot there and no low voltage events in the syslog so doesn't look like the 5v psu (powers the sbc and duet) has been interrupted at all.
          for reference the above event occurred at ~11:10 am 06/03/21
          does this look like 24V PSU failure?
          M122
          RepRapFirmware for Duet 3 Mini 5+ version 3.2.2 running on Duet 3 Mini5plus WiFi (SBC mode)
          Board ID: K1UT9-Z196U-D65J0-40KML-NY03Z-7ZF9S
          Used output buffers: 1 of 40 (10 max)
          Static ram: 98732
          Dynamic ram: 102152 of which 140 recycled
          Never used RAM 44192, free system stack 150 words
          Tasks: Linux(ready,79) HEAT(blocked,297) CanReceiv(blocked,947) CanSender(blocked,358) CanClock(blocked,362) TMC(blocked,106) MAIN(running,519) IDLE(ready,20) AIN(blocked,264)
          Owned mutexes: HTTP(MAIN)
          Last reset 02:40:49 ago, cause: power up
          Last software reset at 2021-03-04 18:11, reason: User, none spinning, available RAM 44160, slot 1
          Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a
          Error status: 0x00
          Aux0 errors 0,0,0
          Aux1 errors 0,0,0
          Supply voltage: min 0.0, current 23.8, max 24.0, under voltage events: 1, over voltage events: 0, power good: yes
          Driver 0: position 9138, standstill, SG min/max 0/48, read errors 0, write errors 0, ifcnt 22, reads 65137, writes 22, timeouts 34, DMA errors 0, failedOp 0x06
          Driver 1: position 21161, standstill, SG min/max 0/50, read errors 0, write errors 0, ifcnt 22, reads 64966, writes 22, timeouts 205, DMA errors 0, failedOp 0x01
          Driver 2: position 111, standstill, SG min/max 0/18, read errors 0, write errors 0, ifcnt 22, reads 65116, writes 22, timeouts 54, DMA errors 0, failedOp 0x72
          Driver 3: position 0, standstill, SG min/max 0/44, read errors 0, write errors 0, ifcnt 22, reads 64947, writes 22, timeouts 223, DMA errors 0, failedOp 0x06
          Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 18, reads 65175, writes 18, timeouts 0, DMA errors 0
          Driver 5: position 0, assumed not present
          Driver 6: position 0, assumed not present
          Date/time: 2021-03-06 11:17:48
          Slowest loop: 1416.05ms; fastest: 0.07ms
          === Storage ===
          Free file entries: 10
          SD card 0 not detected, interface speed: 0.0MBytes/sec
          DMs created 83, maxWait 8190255ms, bed compensation in use: mesh, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 4712, completed moves 4712, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
          === AuxDDARing ===
          Bed heaters = 0 -1, chamberHeaters = -1 -1
          Heater 0 is on, I-accum = 0.5
          Heater 1 is on, I-accum = 0.4
          Segments left: 0
          Movement lock held by null
          Telnet is idle in state(s) 0
          File* is doing "G1 X114.337997 Y256.683014 E1.985030" in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty.
          === CAN ===
          Messages queued 86709, send timeouts 86706, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
          === SBC interface ===
          State: 4, failed transfers: 0
          Last transfer: 4ms ago
          RX/TX seq numbers: 16041/16041
          SPI underruns 0, overruns 0
          Number of disconnects: 0, IAP RAM available 0x10eec
          Buffer RX/TX: 832/2136-0
          === Duet Control Server ===
          Duet Control Server v3.2.2
          File:
          Buffered code: G1 X114.338 Y256.683 E1.98503
          Buffered code: G1 X114.092 Y256.974 E1.99703
          Buffered code: G1 X112.048 Y254.929 E2.08820
          Buffered code: G1 X112.048 Y255.466 E2.10511
          Buffered code: G1 X113.892 Y257.310 E2.18737
          Buffered code: G1 X113.744 Y257.698 E2.20047
          Buffered code: G1 X112.048 Y256.002 E2.27611
          Buffered code: G1 X112.047 Y256.538 E2.29302
          Buffered code: G1 X113.663 Y258.154 E2.36507
          Buffered code: G1 X113.663 Y258.521 E2.37665
          Buffered code: G1 X113.698 Y258.725 E2.38318
          Buffered code: G1 X112.047 Y257.074 E2.45680
          Buffered code: G1 X112.047 Y257.610 E2.47371
          Buffered code: G1 X116.116 Y261.679 E2.65516
          Buffered code: G1 X116.384 Y261.411 E2.66712
          Buffered code: G1 X115.579 Y260.606 E2.70300
          Buffered code: G1 X115.683 Y260.629 E2.70636
          Buffered code: G1 X116.146 Y260.637 E2.72095
          Buffered code: G1 X116.652 Y261.143 E2.74353
          Buffered code: G1 X116.920 Y260.875 E2.75545
          Buffered code: G1 X116.465 Y260.419 E2.77577
          Buffered code: G1 X117.033 Y260.550 F10800.000
          Buffered code: G1 F1200.000
          Buffered code: G1 X117.264 Y260.381 E2.78382
          Buffered code: G1 X117.573 Y260.113 E2.79529
          Buffered code: G1 X117.857 Y259.821 E2.80705
          Buffered code: G1 X118.089 Y259.539 E2.81786
          Buffered code: G1 X118.012 Y259.255 E2.82658
          ==> 1324 bytes
          Code buffer space: 1960
          Full transfers per second: 35.01
          Maximum length of RX/TX data transfers: 3088/1456
          File /opt/dsf/sd/gcodes/Full_Mining_Rig_Set_PETG_CR10_8h24m.gcode is selected, processing
            dc42 administrators @WILD9
            @WILD9 said in Duet3 Mini Stalling mid print:
            The under-voltage event and the timeouts writing to the drivers suggest that VIN power was lost briefly.
            • WILD9undefined
              WILD9
              This post is deleted!
              • WILD9undefined
                WILD9 @dc42
                @dc42 Thanks, in this case is VIN the 24V PSU as opposed to the separate 5V feeding the Duet/SBC?
                • WILD9undefined
                  WILD9
                  OK, Ordered a new PSU. Fingers crossed.
                  • WILD9undefined
                    WILD9
                    No Luck, replacement Meanwell PSU installed and still coming back to occasionally find the printer stopped mid print.
                    Latest M122:
                    M122
                    Static ram: 98732
                    Dynamic ram: 102268 of which 24 recycled
                    Never used RAM 44192, free system stack 200 words
                    Tasks: Linux(blocked,120) HEAT(blocked,315) CanReceiv(blocked,947) CanSender(blocked,372) CanClock(blocked,363) TMC(blocked,106) MAIN(running,519) IDLE(ready,20) AIN(blocked,272)
                    Last reset 00:00:43 ago, cause: software
                    Last software reset at 2021-03-16 08:05, reason: User, GCodes spinning, available RAM 44124, slot 2
                    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a
                    Error status: 0x00
                    Aux0 errors 0,0,0
                    Aux1 errors 0,0,0
                    Supply voltage: min 0.0, current 1.3, max 24.0, under voltage events: 1, over voltage events: 0, power good: no
                    Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 33, reads 485, writes 9, timeouts 586, DMA errors 0, failedOp 0x6f
                    Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 33, reads 483, writes 9, timeouts 588, DMA errors 0, failedOp 0x06
                    Driver 2: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 33, reads 482, writes 9, timeouts 588, DMA errors 0, failedOp 0x41
                    Driver 3: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 31, reads 467, writes 9, timeouts 603, DMA errors 0, failedOp 0x72
                    Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 29, reads 484, writes 9, timeouts 587, DMA errors 0, failedOp 0x01
                    Date/time: 2021-03-16 08:06:07
                    Cache data hit count 114694806
                    Slowest loop: 1.38ms; fastest: 0.09ms
                    === Storage ===
                    === MainDDARing ===
                    === AuxDDARing ===
                    Heater 1 is on, I-accum = 0.0
                    Segments left: 0
                    File is idle in state(s) 0
                    === Filament sensors ===
                    Extruder 0 sensor: no data received
                    === CAN ===
                    Messages queued 343, send timeouts 341, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
                    RX/TX seq numbers: 1654/1654
                    Buffer RX/TX: 0/0-0
                    Code buffer space: 4096
                    Full transfers per second: 38.93
                    Maximum length of RX/TX data transfers: 3100/796
                      droftarts administrators @WILD9
                      That M122 report is interesting because it says the current voltage is 1.3V. If it says that, you can test the actual voltage with a multimeter as see if that’s true.
                      • Serbitarundefined
                        Serbitar
                        is your m122 being done automatically? (i.e. when powerloss is detected?)
                          May be related to this https://forum.duet3d.com/topic/22031/duet-3-mini-5-vin-under-voltage-issues-in-sbc-mode/7. In summary, we have a few instances of what appear to be spurious under-voltage detection, always with the voltage being recorded as 0.0, and so far always when in SBC mode not standalone mode.
                          • WILD9undefined
                            WILD9 @droftarts
                            @droftarts The duet controls my 24Vin it seems to have turned the relay off here hence the 1.3v reading but during printing I'm at 24v The same failures occur with the relay bypassed and Im now on my second 24V PSU.
                            @Serbitar No, that last one was manually run ~5 minutes after the print stopped but before I had taken any action to restart things.
                            @dc42 Thanks I will keep an eye on this, is there anything I can do to help with logging etc as I seem to have this occurring quite frequently at the moment.
                            • WILD9undefined
                              WILD9
                              Another failure so another m122 with the console messages precursing it:
                              8/03/2021, 08:42:37	m122
                              Used output buffers: 1 of 40 (13 max)
                              Static ram: 98732
                              Dynamic ram: 95896 of which 60 recycled
                              Never used RAM 50528, free system stack 124 words
                              Tasks: Linux(ready,77) HEAT(blocked,297) CanReceiv(blocked,947) CanSender(blocked,358) CanClock(blocked,362) TMC(blocked,106) MAIN(running,438) IDLE(ready,20) AIN(blocked,264)
                              Owned mutexes: Telnet(MAIN)
                              Last reset 15:36:04 ago, cause: power up
                              Last software reset at 2021-03-17 13:46, reason: User, none spinning, available RAM 44124, slot 1
                              Error status: 0x00
                              Aux0 errors 0,0,0
                              Aux1 errors 0,0,0
                              Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 4, over voltage events: 0, power good: yes
                              Driver 0: position -13134, ok, SG min/max 0/4, read errors 0, write errors 0, ifcnt 21, reads 18144, writes 0, timeouts 5, DMA errors 0, failedOp 0x06
                              Driver 1: position -6070, ok, SG min/max 0/18, read errors 0, write errors 0, ifcnt 21, reads 18148, writes 0, timeouts 1, DMA errors 0, failedOp 0x06
                              Driver 2: position 2057, standstill, SG min/max 0/6, read errors 0, write errors 0, ifcnt 20, reads 18148, writes 0, timeouts 1, DMA errors 0, failedOp 0x72
                              Driver 3: position 0, standstill, SG min/max 14/14, read errors 0, write errors 0, ifcnt 21, reads 18147, writes 0, timeouts 3, DMA errors 0, failedOp 0x6f
                              Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 19, reads 18149, writes 0, timeouts 0, DMA errors 0
                              Date/time: 2021-03-18 08:42:37
                              Slowest loop: 57.64ms; fastest: 0.09ms
                              === Storage ===
                              DMs created 83, maxWait 0ms, bed compensation in use: mesh, comp offset -0.147
                              === MainDDARing ===
                              Scheduled moves 554, completed moves 553, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                              === AuxDDARing ===
                              Heater 0 is on, I-accum = 0.2
                              Segments left: 0
                              Movement lock held by HTTP
                              HTTP* is idle in state(s) 1 0, running macro
                              Telnet* is doing "M122" in state(s) 0
                              File* is idle in state(s) 0
                              Queue* is idle in state(s) 0
                              Extruder 0 sensor: ok
                              === CAN ===
                              Messages queued 1148, send timeouts 1148, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
                              Last transfer: 1ms ago
                              RX/TX seq numbers: 1256/35183
                              Buffer RX/TX: 2736/632-4080
                              HTTP:
                              Buffered code: G1 H1 X-305 Y-305 F240 ; move slowly to X and Y axis endstops once more (second pass)
                              Buffered code: G90 ; absolute positioning
                              Buffered code: G1 X3 Y300 F6000 ; go to first bed probe point and home Z
                              Buffered code: G30 ; home Z by probing the bed
                              ==> 152 bytes
                              Executing macro 0:/macros/Safety Home, started by M98 P"0:/macros/Safety Home"
                              > Next stack level
                              File:
                              Buffered code: G1 X75.475 Y162.206 E243.68582
                              Buffered code: G1 X151.794 Y238.525 E248.68940
                              Buffered code: G1 X152.582 Y238.525 E248.72595
                              Buffered code: G1 X75.475 Y161.418 E253.78122
                              Buffered code: G1 X75.475 Y160.629 E253.81777
                              Buffered code: G1 X153.371 Y238.525 E258.92473
                              Buffered code: G1 X154.159 Y238.525 E258.96128
                              Buffered code: G1 X75.475 Y159.841 E264.11994
                              Buffered code: G1 X75.475 Y159.052 E264.15649
                              Buffered code: G1 X154.948 Y238.525 E269.36683
                              Buffered code: G1 X155.736 Y238.525 E269.40339
                              Buffered code: G1 X75.475 Y158.264 E274.66543
                              Buffered code: G1 X75.475 Y157.475 E274.70198
                              Buffered code: G1 X156.525 Y238.525 E280.01571
                              Buffered code: G1 X157.313 Y238.525 E280.05226
                              Buffered code: G1 X75.475 Y156.687 E285.41769
                              Buffered code: G1 X75.475 Y155.898 E285.45424
                              Buffered code: G1 X158.102 Y238.525 E290.87136
                              Buffered code: G1 X158.890 Y238.525 E290.90791
                              Buffered code: G1 X75.475 Y155.110 E296.37672
                              Buffered code: G1 X75.475 Y154.322 E296.41328
                              Buffered code: G1 X159.678 Y238.525 E301.93378
                              Buffered code: G1 X160.467 Y238.525 E301.97033
                              Buffered code: G1 X75.475 Y153.533 E307.54253
                              Buffered code: G1 X75.475 Y152.745 E307.57908
                              Buffered code: G1 X161.255 Y238.525 E313.20298
                              Buffered code: G1 X162.044 Y238.525 E313.23953
                              Buffered code: G1 X75.475 Y151.956 E318.91511
                              Buffered code: G1 X75.475 Y151.168 E318.95166
                              Buffered code: G1 X162.832 Y238.525 E324.67894
                              Buffered code: G1 X163.621 Y238.525 E324.71549
                              Buffered code: G1 X75.475 Y150.379 E330.49446
                              ==> 1504 bytes
                              Code buffer space: 2104
                              Full transfers per second: 35.55
                              Maximum length of RX/TX data transfers: 3108/1608
                              File /opt/dsf/sd/gcodes/Front Mid_0.3mm_PETG_CR10_2h15m.gcode is selected, processing
                              ok
                              18/03/2021, 08:40:30	m122
                              Used output buffers: 1 of 40 (11 max)
                              Static ram: 98732
                              Tasks: Linux(ready,77) HEAT(blocked,297) CanReceiv(blocked,947) CanSender(blocked,358) CanClock(blocked,362) TMC(blocked,106) MAIN(running,519) IDLE(ready,20) AIN(blocked,264)
                              Last reset 15:33:56 ago, cause: power up
                              Error status: 0x00
                              Aux0 errors 0,0,0
                              Aux1 errors 0,0,0
                              Supply voltage: min 0.0, current 24.0, max 24.1, under voltage events: 4, over voltage events: 0, power good: yes
                              Driver 0: position 10866, standstill, SG min/max 0/36, read errors 0, write errors 2, ifcnt 21, reads 59697, writes 55, timeouts 433, DMA errors 0, failedOp 0x6f
                              Driver 1: position 17930, standstill, SG min/max 0/50, read errors 0, write errors 2, ifcnt 21, reads 52724, writes 55, timeouts 7405, DMA errors 0, failedOp 0x6a
                              Driver 2: position 57, standstill, SG min/max 0/24, read errors 1, write errors 2, ifcnt 20, reads 40721, writes 53, timeouts 19408, DMA errors 0, failedOp 0x72
                              Driver 3: position 0, standstill, SG min/max 0/42, read errors 0, write errors 2, ifcnt 21, reads 41378, writes 52, timeouts 18751, DMA errors 0, failedOp 0x72
                              Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 2, ifcnt 19, reads 60139, writes 45, timeouts 0, DMA errors 0
                              Date/time: 2021-03-18 08:40:30
                              Slowest loop: 176.39ms; fastest: 0.07ms
                              === Storage ===
                              DMs created 83, maxWait 47646562ms, bed compensation in use: mesh, comp offset -0.147
                              === MainDDARing ===
                              Scheduled moves 550, completed moves 550, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                              === AuxDDARing ===
                              Segments left: 0
                              === CAN ===
                              Messages queued 504335, send timeouts 504332, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
                              RX/TX seq numbers: 62260/30651
                              Buffer RX/TX: 2736/216-4080
                              File:
                              ==> 1504 bytes
                              Code buffer space: 2520
                              Full transfers per second: 35.60
                              18/03/2021, 08:39:12	Warning: VIN under-voltage event (0.0V)
                              18/03/2021, 08:39:12	Error: G0/G1: insufficient axes homed
                              18/03/2021, 08:32:13	Height map loaded from file heightmap.csv
                              18/03/2021, 08:29:22	T:26.5 /240.0 T0:26.5 /240.0 B:26.7 /80.0
                              the relevant log lines:
                              2021-03-18 08:39:13 Error: G0/G1: insufficient axes homed
                              2021-03-18 08:39:13 Warning: VIN under-voltage event (0.0V)
                              Unlike @serbitar I notice I have no
                              xxxx Print auto-paused due to low voltage
                              line in my logs which I can see in which I can see in Serbitars logs
                              I'm now trying to look into a simple way to log the Vout of the PSU directly during prints
                                Thanks, I think this is the same as https://forum.duet3d.com/topic/22031/duet-3-mini-5-vin-under-voltage-issues-in-sbc-mode/7 which has been reported by several users, so nothing to do with your PSU. The fact that the VIN reading is always 0.0 when it occurs confirms that. What I really need is a way of triggering this issue reliably so that I can test possible fixes. Please look at my most recent post in that thread.
                                • WILD9undefined
                                  WILD9 @dc42
                                  @dc42 Thanks, I will move over to that thread for discussion
