Power consumption of total electronics and motors
405
    Dan1990
    Good evening,
    I performed the calculation to figure out the power consumption of my printer and I am not sure if I am correct.
    My PSU at the moment is 24V and 25 A non - name brand. I would like to change it to Meanwell and I wonder what size of PSU will be most suitable for me.
    My setup:
    Duet 3 HC
    5 motors - e3d High Torque Motor - 1.62 A
    1 motor - e3d compact but powerful - 1.62 A
    Hot end - E3D V6 - 40W heater - 1.6 A
    Hotend fan - no data for PC but so I assume is around 0.1A
    Blower fan - no-name from Aliexpres - 0.1A
    So, the sum of all current is 11.52A. Taking into consideration that the motors are not running on full power, therefore the PC will be lower.
    I reckon that the Meanwell 350.4W 24V 14.6A LRS-350-24 will be enough but I will appreciate a second opinion.
    Thanks
    Dan
    undefined 1 Reply Last reply 18 Mar 2021, 20:54 Reply Quote 0
      droftarts administrators @Dan1990
      @Dan1990 No heated bed? That's usually the biggest current draw.
      undefined 1 Reply Last reply 18 Mar 2021, 20:58 Reply Quote 0
        Dan1990 @droftarts
        @droftarts
        The heated bed is powered from the mains.
          That looks ok. When the heated bed is AC powered you can get away with a much smaller PSU. Meanwell has some nice passive units in the 200-300 watt range that work really well.
            theruttmeister
            More than enough.
            Remember that the current values you are using for the motors are peak, for sizing a PSU you want to be using RMS (kinda)
            Last time I bothered actually using a meter to check (and I admit it was a very long time ago) a RAMPS based printer with a ~40w heater (hand wound, so the ~ is doing a lot of work), was only drawing 70W at the wall in normal operation.
            Over a sample size of over a thousand printers that I am familiar with, 24v 200W Meanwell PSU was never insufficient.
            Maybe if you were running a Duet 3HC with big NEMA23's and really driving stuff hard...
            IIRC, even tested a 100W PSU... worked just fine. But the price difference was small enough that we kept the 200W.
            Isolate, substitute, verify.
              I power my little Delta printer with no heated bed with a laptop PSU; 19V @ 3.42A = 64.98 watts!
                Dan1990
                Thank you for all your replies! Now I am sure 🙂 Have a good weekend
                  The motors will draw far less current than you are assuming. See https://duet3d.dozuki.com/Wiki/Choosing_the_power_supply. A 5A PSU would likely be sufficient.
                  2 out of 8
