    One axis will not calibrate
    363
    • thunderboltcutterundefined
      thunderboltcutter
      I am getting a spam error when trying to post M122 output to the forum. Is there a work around?
      • fcwiltundefined
        fcwilt @thunderboltcutter
        @thunderboltcutter said in One axis will not calibrate:
        Change the file extension to .g perhaps?
        thunderboltcutterundefined 1 Reply Last reply Reply Quote 0
          thunderboltcutter @fcwilt
          @fcwilt
          I am going break things up into a few posts to see what's getting caught by the filter.
          ~~M98 P"config.g"
          HTTP is enabled on port 80
          FTP is enabled on port 21
          TELNET is enabled on port 23~~
            thunderboltcutter
            M122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet WiFi 1.02 or later
            Board ID: 08DLM-996RU-N85S4-7JTDL-3SN6R-1S9VR
            Used output buffers: 1 of 20 (19 max)
            Static ram: 28380
            Dynamic ram: 95820 of which 0 recycled
            Exception stack ram used: 420
            Never used ram: 6452
            Task NETWORK ready, free stack 324
            Task HEAT blocked, free stack 1256
            Task MAIN running, free stack 3624
              Phaedrux Moderator @thunderboltcutter
              For some reason my Y axis will not respond to changes in the config.g file. When I print a calibration cube that side always comes out the same.
              What exactly does this mean? I'm not sure what you're describing. Photo of the results? What are you expecting to happen? What are you trying to change?
                I've given you a few upvotes, so hopefully it won't bug you about spam as much. Might also help to take a pause for 10 minutes and try and create a single post again with all the copy and paste. Multiple posts in rapid succession is likely to trigger it.
                • fcwiltundefined
                  fcwilt @Phaedrux
                  @Phaedrux said in One axis will not calibrate:
                  I learn something new everyday.
                    thunderboltcutter
                    No matter what I do with the y axis variable when printing a calibration cube I get 20.55mm from that side.
                    Using setting like this yields the same results:
                    M92 X90.36 Y88.78 Z2151.90
                    M92 X90.36 Y91.0 Z2151.90
                    M122
                    Static ram: 28380
                    Last reset 05:29:33 ago, cause: power up
                    Last software reset at 2021-03-18 20:25, reason: User, spinning module GCodes, available RAM 6588 bytes (slot 3)
                    Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
                    Error status: 0
                    Free file entries: 10
                    SD card longest block write time: 0.0ms
                    MCU temperature: min 25.5, current 25.5, max 25.8
                    Supply voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0, over voltage events: 0
                    Date/time: 2021-03-19 15:06:44
                    Slowest loop: 7.60ms; fastest: 0.08ms
                    Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                    Bed compensation in use: none
                    Heater 0 is on, I-accum = 0.8
                    Heater 1 is on, I-accum = 0.4
                    Segments left: 0
                    Movement lock held by null
                    http is ready with "M122 " in state(s) 0
                    telnet is idle in state(s) 0
                    file is idle in state(s) 0
                    serial is idle in state(s) 0
                    aux is idle in state(s) 0
                    daemon is idle in state(s) 0
                    queue is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 200.85ms; fastest: 0.01ms
                    HTTP sessions: 2 of 8
                    - WiFi -
                    Network state is running
                    Failed messages: pending 3, notready 0, noresp 3
                    WiFi firmware version 1.25
                    WiFi MAC address f4:cf:a2:69:48:de
                    WiFi Vcc 3.33, reset reason Turned on by main processor
                    WiFi flash size 4194304, free heap 23104
                    WiFi IP address 192.168.1.82
                    WiFi signal strength -56dBm, reconnections 0, sleep mode unknown
                    === Expansion ===
                    • fcwiltundefined
                      Where did you get those values? They are a bit unusual.
                      Perhaps you could restore the X and Y values to the theoretical values and using...
                      M579 X1.0 Y1.0 Z1.0 ; scaling (values are determined by measuring test object)
                      to scale the size of the objects printed? Values of 1.0, as shown, produce no scaling.
                        Phaedrux Moderator @fcwilt
                        @fcwilt said in One axis will not calibrate:
                        Looks like the solid doodle uses MXL belts and 17 tooth pulleys for an approximate steps per mm of 88.
                        http://www.soliforum.com/topic/2671/solidoodle-belt-and-pulley-specs-belt-replacement-guide/page/2/
                        https://tomhorsley.com/hardware/solidoodle/solidoodle-calibration.html
                        Can I get you to update your firmware?
                        Upload this zip file to the system tab in DWC.
                        Don't extract it first.
                        • fcwiltundefined
                          fcwilt @Phaedrux
                          Never heard of MXL belts or 17 tooth pulleys - new facts to stuff into my old brain.
                          One thing I don't quite understand is why the X and Y steps/mm (whatever they actually should be) would in practice be different.
                          What is the source of the variation between X and Y?
                            Well Solid Doodle made some funny choices. (MXL, 17 tooth, etc) so who knows what else is funky in there. Product of the times I suppose.
                            As for why they would be so different here in this case and why the steps per mm isn't having an effect, I wonder if it's something mechanical. Slippage or something. Loose grub screw?
