    How is the “Height Map” Used?
    4.5k
    • tmeryhewundefined
      tmeryhew @Phaedrux
      • tmeryhewundefined
        tmeryhew
          Ok so your homeall is using endstop homing for Z instead of the probe.
          This section
          G1 H1 Z-305 F360
          G90
          G92 Z0
          Should be replaced by
          G90 ; absolute position
          G1 X150 Y150 F6000 ; move probe to bed center
          G30 ; probe the bed
          But you haven't shown us your config.g yet, so I'm not actually sure you have a probe configured. What probe do you have? Does it work?
          https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
          tmeryhewundefined 1 Reply Last reply Reply Quote 0
          • tmeryhewundefined
            tmeryhew @Phaedrux
            @Phaedrux
            ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Mar 19 2021 21:41:05 GMT-0700 (MST)
            G90                                                ; send absolute coordinates...
            M83                                                ; ...but relative extruder moves
            M550 P"Genesis"                                    ; set printer name
            M551 P"shatner1"                                   ; set password
            M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
            M586 P0 S1                                         ; enable HTTP
            M586 P1 S0                                         ; disable FTP
            M586 P2 S0                                         ; disable Telnet
            M569 P0 S0                                         ; physical drive 0 goes backwards
            M569 P1 S0                                         ; physical drive 1 goes backwards
            M569 P2 S1                                         ; physical drive 2 goes forwards
            M569 P3 S0                                         ; physical drive 3 goes backwards
            M584 X0 Y1 Z2 E3                                   ; set drive mapping
            M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
            M92 X80.00 Y80.00 Z400.00 E105.00                  ; set steps per mm
            M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
            M203 X12000.00 Y12000.00 Z240.00 E1200.00          ; set maximum speeds (mm/min)
            M201 X800.00 Y800.00 Z800.00 E250.00               ; set accelerations (mm/s^2)
            M906 X1200 Y1200 Z1200 E1200 I30                   ; set motor currents (mA) and motor idle factor in per cent
            M84 S30                                            ; Set idle timeout
            M208 X0 Y0 Z0 S1                                   ; set axis minima
            M208 X300 Y220 Z300 S0                             ; set axis maxima
            M574 X1 S1 P"^xstop"                               ; configure active-high endstop for low end on X via pin ^xstop
            M574 Y1 S1 P"^ystop"                               ; configure active-high endstop for low end on Y via pin ^ystop
            M574 Z1 S1 P"^zstop"                               ; configure active-high endstop for low end on Z via pin ^zstop
            M950 S0 C"exp.heater3"                             ; create servo pin 0 for BLTouch
            M558 P9 C"^zprobe.in" H5 F240 T12000               ; set Z probe type to bltouch and the dive height + speeds
            G31 P500 X-45 Y-7 Z2.345                            ; set Z probe trigger value, offset and trigger height
            M557 X15:215 Y15:195 S20                           ; define mesh grid
            M308 S0 P"bedtemp" Y"thermistor" T98801 B4185      ; configure sensor 0 as thermistor on pin bedtemp
            M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
            M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
            M140 H0                                            ; map heated bed to heater 0
            M143 H0 S100                                       ; set temperature limit for heater 0 to 100C
            M308 S1 P"e0temp" Y"thermistor" T98801 B4185       ; configure sensor 1 as thermistor on pin e0temp
            M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
            M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
            M143 H1 S250                                       ; set temperature limit for heater 1 to 250C
            M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
            M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
            M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
            M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
            M563 P0 D0 H1 F0                                   ; define tool 0
            G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
            G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
            M501                                               ; load saved parameters from non-volatile memory
            T0                                                 ; select first too
              @tmeryhew said in How is the “Height Map” Used?:
              Ok looks like you have a bltouch. If it's working, you should be able to change the homeall as I indicated above, and it should start using the probe to home Z, and with your slicer start gcode it should home XYZ and then generate a new heightmap and it should be active during the print.
              • tmeryhewundefined
                tmeryhew
                ; homeall.g
                ; called to home all axes
                G91 ; relative positioning
                G1 H2 Z5 F12000 ; lift Z relative to current position
                G1 H1 X-305 Y-225 F3600 ; move quickly to X and Y axis endstops and stop there (first pass)
                G1 H2 X5 Y5 F12000 ; go back a few mm
                G1 H1 X-305 Y-225 F360 ; move slowly to X and Y axis endstops once more (second pass)
                G90 ; absolute positioning
                G1 X150 Y110 F6000 ; move probe to bed center
                G30 ; probe the bed
                ;G91 ; relative positioning
                ;G1 Z5 F200 ; lift Z relative to current position
                ;G90 ; absolute positioning
                • tmeryhewundefined
                  tmeryhew
                  And to clarify, yes it appears to be working. I can definitely generate a height map. Are there other things I should be looking for to confirm its working?
                  Other than obviously not crashing into the bed.
                    The best way to test is to print a first layer test print twice. Once with G29 in the start gcode, and again with G29 S0 in the start gcode to disable it.
                    Something like this file works well.
                    bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
                    I think the missing piece of the puzzle in your case was not using the probe to home z.
                    tmeryhewundefined 2 Replies Last reply Reply Quote 1
                    • tmeryhewundefined
                      tmeryhew @Phaedrux
                      @Phaedrux thank you so much. You guys really know your stuff. I'll go ahead and work on this right now.
                      How can I save/export all of my settings as a JSON once I have it dialed in?
                        Phaedrux Moderator @tmeryhew
                        You can back up the .g files in the /sys folder of your SD card.
                        From DWC, go to the system tab, there is a check box above the list of files, click it to select all the files, then right click on the file list area and select "Download as zip" to save all the files there as a zip file on your computer.
                        Then if you ever needed to restore the configuration to that point you could upload that zip file again to the system tab. Or extract it and upload a particular file you want.
                        tmeryhewundefined 1 Reply Last reply Reply Quote 1
                        • tmeryhewundefined
                          tmeryhew @Phaedrux
                          I've gone in and made the changes you describe. I am running the file you sent as we speak. I sent M122 and this was the result.
                          Should my "comp offset" be 0.000? Does this mean anything?
                            No the important thing is that it indicates the mesh is loaded.
                            It should be moving the Z axis to compensate for the surface of the bed now.
                            • tmeryhewundefined
                              tmeryhew @Phaedrux
                              @Phaedrux so when I run the test print the second time with G29 S0, should it still probe the bed? Because that is what it's doing right now.
                              • fcwiltundefined
                                fcwilt @tmeryhew
                                Yes G29 S0 probes the bed.
                                G29 by itself first looks for a file mesh.g - if found the file is executed.
                                If the file is not found then G29 behaves just like G29 S0 and probes the bed creating the height map.
                                Some folks create a height map with every print.
                                Others, like me, have a separate macro for creating the height map when desired.
                                That height map is then simply loaded using G29 S1 at the start of every print.
                                Your printer - your choice.
                                  Sorry I should have said G29 S2 to clear the heightmap.
                                  https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_G29_Mesh_bed_probe
                                  • tmeryhewundefined
                                    tmeryhew
                                    This first one is with the start code set to G29 S2.
                                    This second picture is when I had it set to G29.
                                      And when it had G29 did it actually probe the bed surface?
                                      • tmeryhewundefined
                                        tmeryhew @Phaedrux
                                        @Phaedrux Yes it did. It just seems like it performed worse with the mesh compensation on...
                                          Ok, let's work on improving your BLtouch performance.
                                          Let's try changing that to this
                                          M558 P9 C"^zprobe.in" H4 F120 T6000 R0.5 A10
                                          It may take slightly longer to perform the G29 but the results should be more accurate.
                                          You should also go through this again and remeasure your trigger height and XY offsets for G31.
