Solved Resume print
@dc42 would you mind copy and pasting your pause and resume codes?
@GT1Za said in Resume print:
; Pause macro file if state.currentTool != -1 M83 ; relative extruder moves G1 E-4 F2500 ; retract 4mm G91 ; relative moves G1 Z5 F5000 ; raise nozzle 5mm G90 ; absolute moves G1 X0 Y85 F10000 ;M106 S0
; Resume macro file G1 R1 X0 Y0 Z2 F5000 ; move to 2mm above resume point G1 R1 X0 Y0 Z0 ; lower nozzle to resume point if state.currentTool != -1 M83 ; relative extruder moves G1 E4 F2500 ; undo the retraction
@dc42 I have tried to use your script but im still battling with the same issue.
In short, whats happeing is that when I pause, the print head moves to the front right of the bed as it should. I can then do the filament change or whatever is required, but when I resume the print, the print head moves in a diagonal motion to where it left, but often it hasnt reached the required height before it starts passing over the model and knocks it off the bed.
Is there a way to get the print head to only move to the Z height and not xy?
Alternatively on the pause to remain at its current (or slightly raised height) rather than it lowering to the normal starting z position?For info there is the pause and resume:
Pause:
; pause.g
; called when a print from SD card is paused
; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed May 06 2020 11:04:16 GMT+0200 (South Africa Standard Time)
G1 E-2 F3600 ; retract 2mm of filament
G91 ; relative positioning
G1 Z5 F360 ; lift Z by 5mm
G90 ; absolute positioning
G1 X0 Y0 F6000 ; go to X=0 Y=0Resume:
; resume.g
; called before a print from SD card is resumed
G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move
G1 R1 X0 Y0 Z0 ; go back to the last print move
G1 E2 F3600 ; extrude 2mm of filament -
Can you post your config.g? Do you have other tool offsets?
@Phaedrux here is the config. Left out the networking part
M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1
M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
M208 X-5:205 Y0:200 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
M92 X80.00 Y80.00 Z400.00 E408 ; set steps per mm
M566 X500.00 Y500.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X12000.00 Y12000.00 Z300.00 E3600.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z900 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X0 Y-22.5 Z-2.5 S1 ; set axis minima
M208 X500 Y500 Z500 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; set endstops controlled by probe; Z-Probe
M558 P9 H5 F120 T6000 A2 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-30.8 Y0 Z2.55 ; set Z probe trigger value, offset and trigger height
M557 X15:445 Y15:445 S20 ; define mesh grid; Heaters
M305 P0 T100000 B4138 R2200 ; set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4138 R2200 ; set thermistor + ADC parameters for heater 1
M106 P0 S1 I0 F500 H1 T30 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C -
I don't see anything unusual in there, unless you've got something in the homing files or start gcode?
@Phaedrux I really dont think its the start code haha... but for safety sake here it is:
G28
G92 E0 ;Reset Extruder
G1 Z2.0 F3000 ;Move Z Axis up
G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
G1 Z2.0 F3000 ;Move Z Axis up -
@Phaedrux @dc42
Sorry guys I thought maybe a video to show this is the easiest.As you can see, when you hit resume, the nozzle drops from the correct height to resume, to x0 y0 z0 and then starts moving to go back to the resume point. This almost always knocks the print off the bed... How do I correct that?
@GT1Za Is the video supposed to be only 3 seconds long? Though it looks like it's moving at a diagonal.
Again, I ask what firmware version are you using? Send M115.
@Phaedrux sorry I missed you asking for the firmware.
The video was only 3 seconds because the forum will only allow a 4mb upload.Firmware is 2.02RC5
Firmware is 2.02RC5
I would suggest updating your firmware first. There were some issues in that time frame for resuming.
Download this zip file, and in DWC, upload it to the system tab. Don't extract it first.
@Phaedrux the reason I havent done this is because, well as you can see im not the greatest at firmware. My understanding is that most of the code for the config etc has changed? If I upload this wont it break my existing?
No, 2.05 won't require changes to your config. RRF3 would require changes.
@Phaedrux Firmware Version: 2.05.1 (2020-02-09b1)
haha fingers crossed! Thanks for the help, Ill report back as soon as I get a chance to test
@Phaedrux thanks I can confirm updating the firmware fixed the issue
