    Resume print
    1.1k
    • GT1Zaundefined
      GT1Za @Phaedrux
      @Phaedrux here is the config. Left out the networking part
      M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1
      M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
      M208 X-5:205 Y0:200 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
      M92 X80.00 Y80.00 Z400.00 E408 ; set steps per mm
      M566 X500.00 Y500.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z300.00 E3600.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z900 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X0 Y-22.5 Z-2.5 S1 ; set axis minima
      M208 X500 Y500 Z500 S0 ; set axis maxima
      M558 P9 H5 F120 T6000 A2 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-30.8 Y0 Z2.55 ; set Z probe trigger value, offset and trigger height
      M557 X15:445 Y15:445 S20 ; define mesh grid
      M305 P0 T100000 B4138 R2200 ; set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4138 R2200 ; set thermistor + ADC parameters for heater 1
      M106 P0 S1 I0 F500 H1 T30 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
        I don't see anything unusual in there, unless you've got something in the homing files or start gcode?
        • GT1Zaundefined
          GT1Za
          @Phaedrux I really dont think its the start code haha... but for safety sake here it is:
          G28
          G92 E0 ;Reset Extruder
          G1 Z2.0 F3000 ;Move Z Axis up
          G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
          G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
          G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
          G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
          • GT1Zaundefined
            GT1Za
            S5 V2.mp4
            @Phaedrux @dc42
            Sorry guys I thought maybe a video to show this is the easiest.
            As you can see, when you hit resume, the nozzle drops from the correct height to resume, to x0 y0 z0 and then starts moving to go back to the resume point. This almost always knocks the print off the bed... How do I correct that?
            G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move
            G1 R1 X0 Y0 Z0 ; go back to the last print move
            M83 ; relative extruder moves
            G1 E2 F3600 ; extrude 2mm of filament
              Phaedrux Moderator @GT1Za
              @GT1Za Is the video supposed to be only 3 seconds long? Though it looks like it's moving at a diagonal.
              Again, I ask what firmware version are you using? Send M115.
              GT1Zaundefined 1 Reply Last reply Reply Quote 0
              • GT1Zaundefined
                GT1Za @Phaedrux
                @Phaedrux sorry I missed you asking for the firmware.
                The video was only 3 seconds because the forum will only allow a 4mb upload.
                Firmware is 2.02RC5
                  @GT1Za said in Resume print:
                  Firmware is 2.02RC5
                  I would suggest updating your firmware first. There were some issues in that time frame for resuming.
                  Download this zip file, and in DWC, upload it to the system tab. Don't extract it first.
                  • GT1Zaundefined
                    GT1Za @Phaedrux
                    @Phaedrux the reason I havent done this is because, well as you can see im not the greatest at firmware. My understanding is that most of the code for the config etc has changed? If I upload this wont it break my existing?
                      No, 2.05 won't require changes to your config. RRF3 would require changes.
                      GT1Zaundefined 2 Replies Last reply Reply Quote 0
                      • GT1Zaundefined
                        GT1Za @Phaedrux
                        @Phaedrux Firmware Version: 2.05.1 (2020-02-09b1)
                        haha fingers crossed! Thanks for the help, Ill report back as soon as I get a chance to test
                        • GT1Zaundefined
                          GT1Za @Phaedrux
                          @Phaedrux thanks I can confirm updating the firmware fixed the issue
