    Simplify3D - new version and worthy upgrade
    37
    4.9k
    • Dougal1957undefined
      Dougal1957
      It seems to be a free upgrade as well so happy days
      • okerchoundefined
        okercho
        I saw that now bridging seems to work much better, doing what cura/slic3r do instead of trying to bridge at 45 degrees… which resulted in crappy bridges xD. I've downloaded it, I will try it soon, after reviewing all stuff and importing my settings...
        Okercho
        Custom Prusa i3 Hephestos with Duet Wi-Fi
        E3d V6 with Bondtech BMG DirectDrive and PrecisionPiezo Sensor
        Rebuilding Hypercube Evolution
          They didn't sign the Windows Installer file for version 4. I'm not impressed.
            deckingman
            I wonder if they fixed the purge logic. When I tried it, they seemed to think that it was good idea to purge the filament after a tool was finished with, rather than before. So when you switched filament, it would purge some of the filament you had just finished with, then change to the new filament and start printing. I couldn't convince them that you need to purge the new filament through before you start using it, which is one of the (many) reasons I gave up and got a refund.
            • Yonkimanundefined
              Yonkiman
              @deckingman:
              Do you remember which version of S3D you were using? I hadn't tried switching tools until 3.1.1, but didn't have the problem you described. In fact all I had S3D do when it changed tools was send a change tool command to the firmware. All the purging, retraction, etc. behavior was done by the Duet's tfreeX.g and tpostX.g scripts.
              Public Service Announcement regarding 4.0: I posted on the S3D forum that while it looks like you can use 3.1 and 4.0 independently (they are installed in separate folders), they share the same mysterious "database", so if you reset (delete) all the profiles 4.0 "imported" from 3.1 (which according to some is a good idea), you'll find all your 3.1 profiles deleted as well. And I still haven't been able to get them back - apparently they are not stored in the factory files as I thought they were.
                deckingman
                No can't remember which version it was. It must have been about year ago I'd guess. The other biggy for me was that I had to jump through all sorts of hoops to try and get it to cope with 3 extruders - never did get it sorted and gave up in the end.
                • kraegarundefined
                  kraegar
                  @Yonkiman:
                  @deckingman:
                  Pretty sure all of that sits in the registry, and only exists as a FF / FFF when exported. So there's no undelete.
                  • Whitewolfundefined
                    Whitewolf
                    @deckingman:
                    That is one of their strengths… you should give it another look. Especially the new multi tool control... you could have one extruder printing with completely different slicer settings or even have one tool print different parts of the print with different slicer settings... it is really flexible now.
                      deckingman
                      @Whitewolf:
                      @deckingman:
                      Sorry, got my fingers burnt once so reluctant to try again. Prusa Slic3r works well for me ad does everything I want so I'll stick with what I'm familiar with.
                      Edit. Dual colour worked reasonably well but 3 or more colours used to be a nightmare even though their marketing blurb said how good it was. Have you actually tried printing a 3, 4 or 5 colour object?
                        Whitewolf
                        I do not have a multi color printer, and I have not yet had a chance to play around with their new ability to slice different areas of the part differently. The new version is a free upgrade you should log into your account and let us know how it handles it.
                          deckingman
                          @Whitewolf:
                          I don't have an account - I cancelled the order and got a refund. Without wishing to cause any offence, it does rather seem that you've been sucked in by S3D's marketing blurb. In my experience what they claim to be possible/good and what the software is actually capable of are two different things - at least when it comes to multi colour/multi part printing. I'll wait until I see some positive feedback from someone who is using it with a mixing 5 colour hot end but I don't have time to go through that process myself.
                            Whitewolf
                            I wasnt saying that its great, thats why i was saying you should let us know but if you dont have an account dont waste the money… obviously from the posts in this thread ive never been pleased with S3D as a company many frusterations with complete lack of support or bug fixes for a paid product. Though i do like the product worlds better than Cura.
                            When i made the switch to S3D a couple years ago i never looked back because i had much better results but it is far from perfect and good luck getting them to fix any of those imperfections with their canned answers and non support... they are almost as bad as XYZ support.
                            This is why i will be checking out Prusa Slicer for me personally as per DJs recommendation but i wont be cancelling S3d because people in our makerspace use it and its easier when working with someone from there to use the same slicer.
                              Dougal1957
                              Also the new KissSlicer is meant to be brilliant and well worth a look (It is still in Beta but can be got by going to http://www.kisslicertalk.com/viewtopic.php?f=6&t=1902
                              Micheal Hackney of Sublime Layers is raving about it attm and I totally respect the work he does.
                              Doug
                                Whitewolf
                                @Dougal1957:
                                Doug
                                Preload sounds like it might be similar to pressure advance?
                                Definitely will check it out, i am focused on improving bowden flexible filament prints at the moment and it appears to have some nice features for doing so.
                                  Dougal1957
                                  Yes I think you could be right the only issue that Micheal has pointed out is that documentation is still a little lacking but that will come in time after all it is still a beta product tho Micheal has been testing it for 9 months now so he has seen it develop and has a pretty good understanding of it by now.
                                  • tomasfundefined
                                    tomasf
                                    @dc42:
                                    Same for the macOS installer, so users can't just double-click the installer. Seems pretty unprofessional.
                                      Dougal1957
                                      Yep I found that as well I have it on both my Mac and Win7 64 bit boxes
                                        Whitewolf
                                        Yeah thats what they like to do…. even to this day with the new release they deny that parimeters not being effected by bridge settings is a bug... in the new release its become a new "feature" to check a box that allows bridging of parimeters.... before then it was very difficult to get a decent bridge with S3D regardless of all the complaints nothing was ever done about it until years later
                                        • percarundefined
                                          percar
                                          Although there are some bug with s3d it is still one of the better slicers out there.
                                          • briangilbertundefined
                                            briangilbert
                                            I'm struggling to find how to access some of the new features though 😕
                                            Co-creator of the Zesty Nimble direct drive extruder
