    0:/firmware/PanelDueFirmware.bin not found
    Firmware installation
    • ianborgundefined
      ianborg
      I'm trying to update the firmware on my display.
      I'm running duet2 wifi with firmware 3.3 beta 2
      when i issue M997 S4 I receive the message.
      0:/firmware/PanelDueFirmware.bin Not found
      I was under the impressions the firmware was pulled from the sys folder?
      any suggestions?
      • alankilianundefined
        alankilian
        There is some information in THIS thread about how to upgrade and get that folder created for you.
        It talks about a different board, but I think the process is the same.
        • pkosundefined
          pkos
          Yep. Make sure you have the newest DWC - assuming all works well, it should upload the firmware to that folder - since as of 3.3 - that's where the firmware should be in.
          If not, with the new DWC, you can select that folder and upload there manually.
          Voron 2.4 (Duet 3 6HC + 3HC standalone), Voron SW (Duet 3 mini 5+ standalone), Voron Trident (Duet 3 mini 5+ standalone), Voron 0.1
          ianborgundefined 1 Reply Last reply Reply Quote 0
          • ianborgundefined
            ianborg @pkos
            @pkos @alankilian I'm on 3.2.2 which I believe is the latest. I don't seem to have access or the ability to get into the firmware folder from the WC. I ended up enabling FTP and saw the folder firmware was there, i FTP uploaded it and then it worked.
            thanks for the reply and info.
            • pkosundefined
              pkos
              Then just for future reference 😉
              I will assume here you downloaded the firmware from the github repo.
              As a part of the files there, you have a file called: DuetWebControl-SD-3.3b2.zip
              That should help you out 😉
