    Duet Wifi BLTouch wiring
    4.1k
    • Eman74undefined
      Eman74
      I'm in the middle of a BLTouch nightmare... and I keep banging my head over it...
      My BLTouch is original latest version 3.1
      I updated to RRF 3 (lost a lot of time to get all axis and endstop working but all seems good a part from the BLTouch)
      here is my config.g related (deployprobe and retracct are standard..):
      M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
      M558 P9 C"^zprobe.in" H5 F100 T3000            ; BLTouch connected to Z probe IN pin, free up MOD pin
      M950 S0 C"exp.heater7"                         ; servo/gpio 0 is Z probe MOD pin tried also duex.pwm5 and !exp.heater7 without success
      M280 P0 S10                                    ; send control signal to BLTouch through servo/gpio 0
      G31 P25 X28 Y-61 Z0    		                   ; BLTouch set offset
      M557 X50:350 Y50:350 S50                       ; define mesh grid
      My Troubleshooting:
      1. Double-checked wiring and tested connectivity with a tester;
      2. verified jumper presence on duex 5
      3. verified led on heater7 is switched on when I start the system
      4. replaced BLTouch with another perfectly working on my cartesian printer with duet wifi and the behaviour is the same erroneous one, it does lights on and blink red without passing the switch-on test
      5. tried other heaters on the duex with same result...
      NOTE: I have 3 Z motors configured and working on Drive 5:6:7 (M584 X0 Y1 Z5:6:7 E3)
      Any help would be really appreciated I followed all documents but somewhere something is just not right and I know it shouldn't be a huge thing cause I tried with another surely working one and it does the same thing so it's a config matter somewhere...
      Emanuele
        Phaedrux Moderator @Eman74
        @Eman74 probably best to start your own thread to keep things clear. It's hard to remember who said what about their setup.
        What pin specifically are you using for the orange/yellow wire?
        What Duet board?
        Eman74undefined 2 Replies Last reply Reply Quote 0
        • Eman74undefined
          Eman74 @Phaedrux
          @Phaedrux sure it's a duet wifi with a duex5 I'm going to start a thread thank you
          Emanuele
          • Eman74undefined
            Eman74 @Phaedrux
            @Phaedrux I just tried but it prevents me from posting new topics... it seems the same issue there was this morning...
            Emanuele
            Phaedruxundefined 1 Reply Last reply Reply Quote 2
              @Eman74 Try again after a few minutes.
              • Agniusmundefined
                Agniusm
                Received my probe today which came V3.1. My duet board is V1.02
                All working good.
                Wired as per tutorial:
                Probe VCC to expansion slot 5V on Duet
                Probe GND and Servo GND to Z Probe GND on duet
                Probe Signal to Z_PROBE_IN on Duet
                Probe Servo to expansion slot Heater7(PWM5) on Duet
                Used all the code in the first post.
                Thank you for help
                • Agniusmundefined
                  Agniusm
                  Just not to create another topic. I have this issue where after print, on the next print BLTouch does not deploy. I have to switch printer off, then back on for it to start working again. Is this a known issue or is there a fix for it?
                  • JayJayundefined
                    JayJay
                    @Agniusm
                    setup a macro to re-set the probe...
                    M280 P0 S160 ;Re-Set the Probe BL Touch
                    Agniusmundefined 2 Replies Last reply Reply Quote 0
                      Phaedrux Moderator @Agniusm
                      @Agniusm Please share your current config.g, homeall.g, homez.g, deployprobe.g, retractprobe.g, and slicer start and end gcode. And refresh me on which firmware version you are using.
                      • Agniusmundefined
                        Agniusm @JayJay
                        @JayJay thanks. Is this how its supposed to be used, the probe? I mean do all of them needs reseting or just on certain boards or on certain firmwares?
                        @Phaedrux i have not made changes since using inductuon probe so my homing gcode is the same and slicer start and end script was not changed. Maybe i just need to call reset macro in my slicer end script like suggested above.
                          Well it's not a bad idea to send the reset command at startup and the beginning of your homeall just in case, but it shouldn't really be necessary if the probe is working.
                          Agniusmundefined 1 Reply Last reply Reply Quote 0
                          • Agniusmundefined
                            Agniusm @JayJay
                            @JayJay BTW do i need I1 parameter if i am without Duex?
                              dc42 administrators @Agniusm
                              @Agniusm said in Duet Wifi BLTouch wiring:
                              If you are using RRF3 then no.
                              • Agniusmundefined
                                Agniusm @dc42
                                @dc42 no, i am on 1.22.6. I have inserted and now it works fine
                                • Agniusmundefined
                                  Agniusm @Phaedrux
                                  @Phaedrux
                                  Added M280 P0 S160 I1 to my home all and on slicer's end gcode.
                                  Still does not work.
                                  Homing when restarted works, lead screw axis compensation works, bed compensation works.
                                  I have no idea why after a print it does not drop the pin...
                                    Photos of your setup? Maybe we can spot something.
