Solved Z-Offset changes suddenly during first layer
Can you post your homeall, slicer start gcode, etc and your tool change files?
It's all distributed over a bunch of macros, I've compiled them into one file each for easier reading:
homeall:
; homeall.g ; called to home all axes ;M98 P"homey.g" ; Home Y first, so that a head that is currently in one of the tool docks home correctly G91 ; relative positioning G1 Z5 F1000 H2 ; lift Z relative to current position G1 H1 Y-400 F10000 ; move quickly to Y axis endstop and stop there (first pass) G1 Y5 F10000 ; go back a few mm G1 H1 Y-400 F360 ; move slowly to Y axis endstop once more (second pass) G90 ; absolute positioning ;M98 P"homex.g" ; Home X G91 ; relative positioning ;M564 H0 G1 Z5 F1000 H2 ; lift Z relative to current position G1 H1 X400 F10000 ; move quickly to X axis endstop and stop there (first pass) G1 X-5 F10000 ; go back a few mm G1 H1 X400 F360 ; move slowly to X axis endstop once more (second pass) G90 ; absolute positioning ;check if any tool is undocked ;not relevant here, the issue at hand happens no matter if this code was executed or not if sensors.gpIn[0].value = 0 || sensors.gpIn[1].value = 0 ;|| sensors.gpIn[2].value = 0 || sensors.gpIn[3].value = 0 echo "Not all tools docked, docking tool before homing!" M98 P"/macros/Toolchanging/Advanced/DockUnknownToolEmergency" ;M98 P"homec.g" ; Home C (ToolHead) if sensors.gpIn[0].value = 0 || sensors.gpIn[1].value = 0 ;|| sensors.gpIn[2].value = 0 || sensors.gpIn[3].value = 0 M291 S1 T5 P"Please return tool to dock before homing coupler" R"Can't home coupler" abort G91 M400 M913 C60 ; C MOTOR TO 60% CURRENT G1 H2 C-300 F10000 G92 C0 G90 M400 M913 C100 ; C MOTORS TO 100% CURRENT ;M98 P"/macros/Toolchanging/Coupler - Unlock" ; open coupler if !move.axes[3].homed ;abort if C is not homed abort M564 S0 G90 G1 C120 F50000 M564 S1 ;M98 P"homez.g" ; Home Z if sensors.gpIn[0].value = 0 || sensors.gpIn[1].value = 0 ;|| sensors.gpIn[2].value = 0 || sensors.gpIn[3].value = 0 M291 S1 T5 P"Please return tool to dock before homing Z" R"Can't home Z" abort G91 ; relative positioning G90 ; absolute positioning G1 X0 Y0 F15000 ; go to first probe point G30 ; home Z by probing the bed G1 X400 Y-400 F15000 ; Park
slicer start: (Cura 4.8)
M190 S{material_bed_temperature_layer_0} ;Wait for bed to reach temp before proceeding G10 P{initial_extruder_nr} S{material_print_temperature_layer_0} R{material_print_temperature_layer_0} ;M98 P"/macros/Misc/PrePrintCalibrate" ;M98 P"/macros/Misc/Lights/On" M42 P1 S255 ;M98 P"/macros/Toolchanging/Advanced/HomeIfNotHomed" if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed || !move.axes[3].homed G28 T-1 G32 T{initial_extruder_nr} M109 S{material_print_temperature_layer_0} ;Wait for extruder to reach temp before proceeding
Note on the start code: Cura ALWAYS inserts a T command first before your start code, which makes zero sense with a toolchanger that can't home with a tool attached. So there's a gcode post-processor in palce that removes that initial T command and my start code contains the relevant T after homing and bed probing.
tpre0
; tpre0.g ; called before tool 0 is selected ;M98 P"/macros/Toolchanging/Advanced/HomeIfNotHomed" if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed || !move.axes[3].homed G28 ;WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! ;if you are using non-standard length hotends ensure the bed is lowered enough BEFORE undocking the tool! G91 G1 Z10 F3000 G90 M400
tpost0
; tpost0.g ; called after tool 0 has been selected M703 ;restore filament settings M564 S0 ; allow movement outside the normal limits ;M98 P"/macros/Toolchanging/Coupler - Unlock" ; unlock Coupler if !move.axes[3].homed ;abort if C is not homed abort M564 S0 G90 G1 C120 F50000 M564 S1 ;M98 P"/macros/Toolchanging/Advanced/MoveToDock/T0" M564 S0 G90 G53 G1 X-80 Y100 F25000 ; Move in front of dock at safe Y G53 G1 Y145 F25000 ; Quickly move in G53 G1 Y153.4 F3000 ; Slowly approach final Y position ;M98 P"/macros/Toolchanging/Coupler - Lock" ; close Coupler if !move.axes[3].homed ;abort if C is not homed abort M564 S0 G90 G1 C230 F50000 M564 S1 ;heatup M116 P0 ;M98 P"/macros/Toolchanging/Advanced/MoveToDock/MoveOut" M564 S0 G91 G1 Y-80 F10000 G90 M400 ;wait for toolchange moves to finish if sensors.gpIn[0].value = 1 echo "Tool 0 is not loaded correctly, aborting..." M98 P"/macros/Toolchanging/Advanced/HandleToolchangeFault" ;M208 Y66 ; set Y max for this tool M564 S1 ; apply the normal limits again ;M98 P"/macros/Toolchanging/Advanced/PrimeBrush" if state.currentTool < 0 echo "Can't Prime & Brush, no tool selected!" M99 if heat.heaters[tools[state.currentTool].heaters[0]].current > heat.coldExtrudeTemperature M564 S0 G90 G53 G1 X-150 Y100 F25000 ; Move in front of brush at safe Y G53 G1 Y145 F25000 ; Quickly move in G53 G1 Y155 F3000 ; Slowly approach final Y position M83 G1 E10 F300 G10 G91 G1 Y-20 F25000 ; start of brush G1 Y-20 F20000 G1 Y20 F20000 G1 Y-20 F20000 G1 Y20 F20000 G1 Y-20 F20000; end of brush G1 Y-50 F25000 G1 X10 F25000 G90 M564 S1 else echo "Skipping Prime & Brush due to unheated tool" M106 R1 ; restore print cooling fan speed
tfree:
; tfree0.g ; called when tool 0 is freed G10 ;retract some G91 G1 Z4 F3000 ; drop the bed G90 M400 M564 S0 ; allow movement outside the normal limits ;M98 P"/macros/Toolchanging/Advanced/MoveToDock/T0" M564 S0 G90 G53 G1 X-80 Y100 F25000 ; Move in front of dock at safe Y G53 G1 Y145 F25000 ; Quickly move in G53 G1 Y153.4 F3000 ; Slowly approach final Y position ;M98 P"/macros/Toolchanging/Coupler - Unlock" ; open coupler if !move.axes[3].homed ;abort if C is not homed abort M564 S0 G90 G1 C120 F50000 M564 S1 ;M98 P"/macros/Toolchanging/Advanced/MoveToDock/MoveOut" M564 S0 G91 G1 Y-80 F10000 G90 M400 ;wait for toolchange moves to finish if sensors.gpIn[0].value = 0 echo "Tool 0 is not docked correctly, aborting..." M98 P"/macros/Toolchanging/Advanced/HandleToolchangeFault" M106 P2 S0 ; fan off M564 S1 ; apply the normal limits again
As you can see, the tool pickup happens in tpost, because that way I can heat up the tool while it's still docked. My tools have their nozzles blocked while docked by some piece of silicone sheet under them, so I want to heat them up while they can't ooze.
The t1 files look the same as the t0 ones, just with different pickup locations of course. Note: the issue also happens with single tool prints, it does not appear to be tool change related.
@Diamondback said in Z-Offset changes suddenly during first layer:
What do you have in your filament specific config?
Only other thing I can think of is that there is a problem with the coordinate system and the 0,0 points for the actual bed amd where it thinks the bed is on the mesh don't match. If you catch my meaning.
For example this:
M207 S0.6 F3000 Z0.0 ;firmware retraction settings for PETG M302 S220 R220 ;Cold extrusion settings
Different values for different filaments of course, but overall just these settings.
Is there any chance I can debug potential offsets of what mesh bed is doing vs what it should do?
Most direct way is to print a first layer test print once with it enabled and once with it disabled. You should be able to tell if it's working as expected or not.
bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
Can you post the results of M122 just for the sake of completeness?
I'm trying to print a dual color print atm and while the first layer worked fine, it's now really squishing things and digging through already printed filament on the following layers...
Here's an M122 while printing:
=== Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later + DueX5 Board ID: 08DGM-917NK-F2MS4-7J9F2-3S86N-TYTWF Used output buffers: 3 of 24 (21 max) === RTOS === Static ram: 23460 Dynamic ram: 75220 of which 80 recycled Never used RAM 13320, free system stack 95 words Tasks: NETWORK(ready,161) HEAT(blocked,308) DUEX(blocked,31) MAIN(running,378) IDLE(ready,20) Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:19:11 ago, cause: software Last software reset at 2021-03-24 02:28, reason: User, GCodes spinning, available RAM 13980, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x10 Aux0 errors 0,0,0 MCU temperature: min 30.5, current 35.4, max 35.8 Supply voltage: min 23.7, current 24.1, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: position -12343, ok, SG min/max 0/1023 Driver 1: position 6131, ok, SG min/max 0/1023 Driver 2: position 4549, standstill, SG min/max 0/511 Driver 3: position 46000, ok, SG min/max 0/1023 Driver 4: position 0, standstill, SG min/max 0/1023 Driver 5: position 0, standstill, SG min/max not available Driver 6: position 0, standstill, SG min/max not available Driver 7: position 0, ok, SG min/max 0/1023 Driver 8: position 0, ok, SG min/max 0/1023 Driver 9: position 0, ok, SG min/max 0/1023 Driver 10: position 0 Driver 11: position 0 Date/time: 2021-03-24 02:48:11 Cache data hit count 1315166420 Slowest loop: 139.34ms; fastest: 0.17ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 1.7ms, write time 212.2ms, max retries 0 === Move === DMs created 83, maxWait 85022ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 18369, completed moves 18330, hiccups 29, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.1 Heater 1 is on, I-accum = 0.4 === GCodes === Segments left: 1 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 X-23.903 Y-16.126 E0.0159" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 213.79ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.25 WiFi MAC address b4:e6:2d:52:f2:a9 WiFi Vcc 3.43, reset reason Power up WiFi flash size 4194304, free heap 26848 WiFi IP address 192.168.1.31 WiFi signal strength -59dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0 === DueX === Read count 14, 0.73 reads/min
I'm trying to let it run through, maybe the printed part gives some hints...
@Diamondback
Your Z motors are on the DUEX5, maybe you have some problem with the board connector? Interference or bad contact.
To evaluate it, you could trade places with Coupler and Extruders. -
Yes, the three Z motors are on the Duex. I have been running this specific Z setup since about a year (with just a single fixed hotend rather than toolchanging) with no issues, so I would rule out any "design" issues.
However, I will check all the connectors again, that could certainly be an issue. -
My Moai print completed overnight and there are various distinct issues:
- It appears that after a really clean first layer (I watched that live) the Z is not dropping enough in the next layers, the first mm or so it really squishes the filament into the previous layer. After 5 or so layers, it works fine, probably because it finally adjusted to the "wrong" Z.
- The squish only happens on T0. T1 is not affected. That's in line with another dual color print from a few days ago where the same issue showed.
- In addition, any other layer than the first shows a weird Y axis offset. First layer is ok, everything after that not so much.
To me it appears that for some reason, the tool offsets are not used correctly...
I'm calibrating my tool offsets in X, Y and Z with the E3D vernier scale print.
Here's a scan of the underside of the Moai.
What you can see here is the following:- The thin green line indicates the normal outer perimeters (3 lines à 0.3mm for copper, 3 lines à 0.4mm for dark grey) I watched these lines lay down during the first layer and they were as good as I can hope for
- Everything past the green line is filament that squished down from the following layers, it wasn't there when the first layer finished.
- There is no meaningful offset in X or Y between the two filaments in the first layer, while later in the print there is
Squished first layers
Offset in Y (see the gap next to the ear)
Filament being squished out the front
@Diamondback
Does the gap reflect your y-offset, but in the wrong direction?
I've just started with dual tool stuff and was surprised to read that eg. for copy mode the offsets have reversed signs.
Meaning, the X-axis left from center gets a positive offset (although it's on the lower side), the U axis is on the right off the center and has a neg. offset.
Not sure about Z offset, but if you've set your offsets wrong, it would explain a lot. (but not the Random factor) -
What surprises me is that the E3D offset calibration print works perfectly fine in terms of X/Y calibration. (In case you don't know that, it's basically a vernier scale that you print and then you can easily see what offsets there are currently)
Looks like this:
And of course that the X/Y offsets work fine for the first layer...
@Diamondback why not use TAMV? much easier for nozzle X/Y calibration https://github.com/HaythamB/TAMV
@jay_s_uk Yea that's supposed to be the next step, but I really think something is fundamentally wrong with my setup and the vernier print should work just fine for getting things to print in a useful manner.
I mean, even single extruder prints don't work due to the Z issue... -
Have you checked that the 8 screws that hold the bed assembly to the linear rail slider are tight? I was getting wildly varying height maps, and the reason turned out to be loose screws.
EDIT: I see from an earlier post that you gave 3 Z motors, so it is not an E3D TC and the above probably doesn't apply.
@dc42 Yep, custom motion system, will check all the Z mountings anyway, good idea
I've just printed a portion of the Moai with switched extruders, so what was previously printed by T0 is now T1 and vice versa.
Observations:
- T0 Z-Offset worked for about 3/4 of its layer, then it blocked the nozzle, I let it continue because T0 was the accents so no huge harm
- T1 Z-Offset is spot on, first layer consistently looks as good as it used to look before the toolchanging hardware
- T1 following layers are all perfectly aligned in X, Y and Z, this makes me think that my motion system itself is fine (ie no huge Z backlash issues or head positional issues)
- T0 following layers show the known problem, not aligned properly, squishing in all directions...
This leads me to the following possible causes:
- T0 tool is somehow broken or damaged and behaves differently than what is expected
- T0 offsets are being messed with in software somehow
Oh wow, I think i finally figured out what's going on. At least something that is going on.
My hotend holder is deforming under the pressure from the extruder... This tilts the whole hotend, moving the nozzle in Y and Z.
I just noticed this very extremely when going from first to second layer, the first layer is fairly slow (30m/s) and the second is twice as fast.
The higher speed deformed the holder a lot more, giving an explanation for the perfect first layer and then the sudden issue with layer 2.I'm not sure yet why it would cause issues during the first layer as it still sometimes does, but right now I'm printing beefier holders and then see if that helps.
T1 was also less affected since it's using a 0.4mm nozzle vs the 0.3mm on T0...Fingers crossed that this is purely a hardware issue on my side and no obscure firmware thing
Yea, I think this was indeed the problem. After installing much stronger parts for the hotend holder, the nozzle does not dive anymore. (Btw these weren't stupidly small parts or bad filament, they were printed in carbon fiber reinforced nylon, which is much stiffer than anything else I have around, so that really wasn't on my radar...)
