    Duet 3 Mini 5+ VIN under-voltage issues in SBC mode
    120
    7.3k
    • WILD9undefined
      WILD9
      6ish hours of simulation so far with no issues
        droftarts administrators @WILD9
        @WILD9 I ran simulations for 8 hours last night, with no issues. Still trying to track this issue down.
        • lodgerundefined
          lodger
          I have come down this morning to find a stalled print. Here is my M122,
          m122
          RepRapFirmware for Duet 3 Mini 5+ version 3.2.2 running on Duet 3 Mini5plus WiFi (SBC mode)
          Board ID: XJDX9-1296U-D65J0-40KMJ-4K03Z-7J6X6
          Used output buffers: 1 of 40 (18 max)
          Static ram: 98732
          Dynamic ram: 95844 of which 64 recycled
          Never used RAM 50576, free system stack 122 words
          Tasks: Linux(ready,99) HEAT(blocked,297) CanReceiv(blocked,947) CanSender(blocked,358) CanClock(blocked,362) TMC(blocked,75) MAIN(running,476) IDLE(ready,20) AIN(blocked,264)
          Owned mutexes: HTTP(MAIN)
          Last reset 17:19:34 ago, cause: software
          Last software reset at 2021-03-19 15:58, reason: User, none spinning, available RAM 50808, slot 1
          Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a
          Error status: 0x00
          Aux0 errors 0,0,0
          Aux1 errors 0,0,0
          Supply voltage: min 0.0, current 24.2, max 24.3, under voltage events: 2, over voltage events: 0, power good: yes
          Driver 0: position 16355, standstill, SG min/max 0/428, read errors 0, write errors 1, ifcnt 223, reads 13005, writes 43, timeouts 17110, DMA errors 0, failedOp 0x71
          Driver 1: position 2458, standstill, SG min/max 0/410, read errors 0, write errors 1, ifcnt 223, reads 30107, writes 43, timeouts 7, DMA errors 0, failedOp 0x6f
          Driver 2: position 63048, standstill, SG min/max 0/44, read errors 0, write errors 1, ifcnt 189, reads 29631, writes 32, timeouts 494, DMA errors 0, failedOp 0x71
          Driver 3: position 0, standstill, SG min/max 0/30, read errors 0, write errors 1, ifcnt 188, reads 29889, writes 32, timeouts 235, DMA errors 0, failedOp 0x01
          Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 155, reads 30130, writes 27, timeouts 0, DMA errors 0
          Driver 5: position 0, assumed not present
          Driver 6: position 0, assumed not present
          Date/time: 2021-03-20 09:18:05
          Slowest loop: 178.10ms; fastest: 0.08ms
          === Storage ===
          Free file entries: 10
          SD card 0 not detected, interface speed: 0.0MBytes/sec
          DMs created 83, maxWait 11368610ms, bed compensation in use: mesh, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 190766, completed moves 190766, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
          === AuxDDARing ===
          Bed heaters = 0 -1, chamberHeaters = 2 -1
          Segments left: 0
          Movement lock held by null
          Telnet is idle in state(s) 0
          File* is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Queue* is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty.
          === CAN ===
          Messages queued 561364, send timeouts 561361, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 15
          === SBC interface ===
          State: 4, failed transfers: 0
          Last transfer: 3ms ago
          RX/TX seq numbers: 42328/42328
          SPI underruns 0, overruns 0
          Number of disconnects: 0, IAP RAM available 0x10eec
          Buffer RX/TX: 0/0-0
          === Duet Control Server ===
          Duet Control Server v3.2.2
          Code buffer space: 4096
          Full transfers per second: 36.40
          Maximum length of RX/TX data transfers: 5108/1664.
            @lodger, was that a print or a simulation?
            Please can you try the firmware at https://www.dropbox.com/sh/6203euyyobllic5/AABTHIbn7F_maK9p-oy7vq3Ea?dl=0 with the same file to see if it happens again.
            lodgerundefined 2 Replies Last reply Reply Quote 0
            • lodgerundefined
              lodger @dc42
              @dc42 Hi,
              Yes it was a print. I will just put the kettle on and update and print. It was a 10 hour print so i may not get back to you till tomo.
              Edit:: I have updated and run a Similator of the same file. Without problems !
              Just running the print now .
              • lodgerundefined
                lodger @dc42
                @dc42 Mornings.
                The print completed . with no under voltage triggers at all. I will try print something else and report if i get any more problems
                  dc42 administrators @lodger
                  @lodger said in Duet 3 Mini 5+ VIN under-voltage issues in SBC mode:
                  @dc42 Mornings.
                  Thanks for the update.
                  Anyone else having this problem and happy to use beta firmware, feel free to try the firmware that I linked to above. It's compatible with DWC 3.3beta2.
                  • Serbitarundefined
                    Serbitar
                    I have put my machine back into SBC mode running the linked beta firmware.
                    It completed a 12h print over night, print queue has shorter jobs for the next few days. I will update if there are any under voltage detection issues.
                      dc42 administrators @Serbitar
                      @Serbitar, thanks for the update.
                      • Serbitarundefined
                        Serbitar
                        Not fixed i'm afraid
                        Mar 24 19:21:32 DuetControlServer[3177]: Print auto-paused due to low voltage
                        Mar 24 19:21:32 DuetControlServer[3177]: [warn] VIN under-voltage event (0.0V)
                        m122
                        RepRapFirmware for Duet 3 Mini 5+ version 3.3beta2+1 running on Duet 3 Mini5plus WiFi (SBC mode)
                        Board ID: W4ZW4-V296U-D65J0-40KM0-LR03Z-H6928
                        Used output buffers: 1 of 40 (32 max)
                        Static ram: 99720
                        Dynamic ram: 98408 of which 24 recycled
                        Never used RAM 45552, free system stack 88 words
                        Tasks: Linux(ready,145) HEAT(notifyWait,299) CanReceiv(notifyWait,943) CanSender(notifyWait,358) CanClock(delaying,340) TMC(notifyWait,109) MAIN(running,310) IDLE(ready,20) AIN(notifyWait,260)
                        Last reset 21:38:59 ago, cause: software
                        Last software reset at 2021-03-23 21:38, reason: User, none spinning, available RAM 46528, slot 2
                        Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a
                        Error status: 0x00
                        Aux0 errors 0,0,0
                        Aux1 errors 0,0,0
                        Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 3, over voltage events: 0, power good: yes
                        Driver 0: position -5573, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 19, reads 5889, writes 9, timeouts 17, DMA errors 0, failedOp 0x01
                        Driver 1: position -6035, standstill, SG min/max 0/44, read errors 0, write errors 0, ifcnt 20, reads 5906, writes 9, timeouts 0, DMA errors 0
                        Driver 2: position 8601, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 19, reads 5906, writes 9, timeouts 0, DMA errors 0
                        Driver 3: position 0, standstill, SG min/max 0/256, read errors 0, write errors 0, ifcnt 22, reads 5906, writes 9, timeouts 0, DMA errors 0
                        Driver 4: position 0, standstill, SG min/max 0/210, read errors 0, write errors 0, ifcnt 22, reads 5906, writes 9, timeouts 0, DMA errors 0
                        Driver 5: position 0, standstill, SG min/max 0/2, read errors 0, write errors 0, ifcnt 22, reads 5906, writes 9, timeouts 0, DMA errors 0
                        Driver 6: position 0, standstill, SG min/max 2/2, read errors 0, write errors 0, ifcnt 22, reads 5906, writes 9, timeouts 0, DMA errors 0
                        Date/time: 2021-03-24 19:22:01
                        Slowest loop: 1.95ms; fastest: 0.13ms
                        === Storage ===
                        DMs created 83, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000
                        === MainDDARing ===
                        Scheduled moves 467805, completed moves 467805, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
                        === AuxDDARing ===
                        Bed heaters = 0 -1, chamberHeaters = -1 -1
                        Heater 0 is on, I-accum = 0.0
                        Heater 1 is on, I-accum = 0.5
                        Segments left: 0
                        File* is doing "G1 X-68.586998 Y-74.568001 E0.009290" in state(s) 0
                        === Filament sensors ===
                        Extruder 0 sensor: ok
                        Extruder 1 sensor: ok
                        === CAN ===
                        Messages queued 266, send timeouts 266, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                        Last cancelled message type 30 dest 127
                        Last transfer: 5ms ago
                        RX/TX seq numbers: 65096/65096
                        Number of disconnects: 0, IAP RAM available 0x11578
                        Buffer RX/TX: 1776/3288-0
                        Duet Control Server v3.3-b2
                        File:
                        Buffered code: G1 X-68.587 Y-74.568 E0.00929
                        Buffered code: G1 X-67.933 Y-73.726 E0.01535
                        Buffered code: G1 X-67.168 Y-72.475 E0.02112
                        Buffered code: G1 X-66.365 Y-70.761 E0.02725
                        Buffered code: G1 X-65.747 Y-68.922 E0.02792
                        Buffered code: G1 X-67.640 Y-69.345 E0.02792
                        Buffered code: G1 X-69.429 Y-69.963 E0.02725
                        Buffered code: G1 X-70.754 Y-70.594 E0.02112
                        Buffered code: G1 X-71.659 Y-71.156 E0.01535
                        Buffered code: G1 X-72.167 Y-71.554 E0.00929
                        Buffered code: G1 X-72.601 Y-72.094 E0.00997
                        Buffered code: G1 X-75.105 Y-70.343 E0.04398
                        Buffered code: G1 X-74.694 Y-69.718 E0.01078
                        Buffered code: G1 X-74.473 Y-69.112 E0.00928
                        Buffered code: G1 X-74.219 Y-68.077 E0.01535
                        Buffered code: G1 X-74.028 Y-66.623 E0.02111
                        Buffered code: G1 X-73.992 Y-64.730 E0.02725
                        Buffered code: G1 X-74.175 Y-62.799 E0.02792
                        Buffered code: G1 X-75.733 Y-63.955 E0.02792
                        Buffered code: G1 X-77.116 Y-65.248 E0.02725
                        Buffered code: G1 X-78.069 Y-66.363 E0.02112
                        Buffered code: G1 X-78.668 Y-67.244 E0.01535
                        Buffered code: G1 X-78.970 Y-67.814 E0.00929
                        Buffered code: G1 X-79.146 Y-68.484 E0.00997
                        Buffered code: G1 X-82.146 Y-67.903 E0.04398
                        Buffered code: G1 X-82.025 Y-67.165 E0.01077
                        Buffered code: G1 X-82.070 Y-66.521 E0.00929
                        Buffered code: G1 X-82.258 Y-65.472 E0.01535
                        Buffered code: G1 X-82.675 Y-64.066 E0.02112
                        Buffered code: G1 X-83.413 Y-62.322 E0.02725
                        Buffered code: G1 X-84.365 Y-60.633 E0.02792
                        Buffered code: G1 X-85.318 Y-62.322 E0.02792
                        ==> 1512 bytes
                        Code buffer space: 1660
                        Full transfers per second: 47.08
                        Codes per second: 17.66
                        Maximum length of RX/TX data transfers: 5884/1664
                        File /opt/dsf/sd/gcodes/eggGears-2and6_0.08mm_PETG_ENDER3_6h50m.gcode is selected, processing
                        • ukwebbundefined
                          ukwebb
                          Just to add another voice, I and also getting this same issue.
                          Last night, 70% and 5 hours into a print it just stopped, and displayed VIN undervoltage event (0.0v) and then Insufficient axis homed
                          My setup is based around a coreXY machine, with a dedicated meanwell 5v 5a psu for the pi, and a meanwell 24v 6amp supply for the printer, the hot bed is 240v
                          Also, this hasn't happed until recently - i think after i did an apt update. so it was probably fine on 3.1 but not 3.2
                          lodgerundefined 1 Reply Last reply Reply Quote 0
                          • lodgerundefined
                            lodger @ukwebb
                            @ukwebb Have you tried the beta DC24 posted above.
                            ukwebbundefined 1 Reply Last reply Reply Quote 0
                              @Serbitar said in Duet 3 Mini 5+ VIN under-voltage issues in SBC mode:
                              Please can you run M115 to confirm the build date of the firmware you are using.
                              Serbitarundefined 1 Reply Last reply Reply Quote 0
                              • Serbitarundefined
                                Serbitar @dc42
                                FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.3beta2+1 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2021-03-19 18:26:13
                                • Serbitarundefined
                                  Serbitar
                                  After the previous failure I dropped the SPI rate to 2MHz but that hasn't helped. Printer just stopped while doing G29 with the dreaded under-voltage event.
                                  dc42undefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                    @Serbitar, thanks for the additional data point.
                                    • ukwebbundefined
                                      ukwebb @lodger
                                      @lodger No i haven't, as @Serbitar has already said its not fixed the issue
                                        droftarts administrators @Serbitar
                                        @Serbitar I've been running 'air' prints on my test rig today. I've had one under-voltage event, 1h 18m into a 3h 30m print, but running the same exact file and settings did not provoke another. So trying to get to the bottom of this issue is, unfortunately, taking some time.
                                        Serbitarundefined lodgerundefined 2 Replies Last reply Reply Quote 0
                                        • Serbitarundefined
                                          Serbitar @droftarts
                                          @droftarts Yeah. I haven't worked out a pattern yet. Please let me know if I can do any useful testing.
                                          • lodgerundefined
                                            lodger @droftarts
                                            @droftarts When DC42 ask on Saturday I also printed the same file without issue .
                                            I have been printing around the clock up till Tuesday. Again without issue. There is just no patten.
                                            I have one of the first batch of boards, and on a earlier firmware (dont ask what one).
                                            I am sure i had this happen in standalone mode. So since Tuesday i have been printing non stop trying to prove this.
                                            I have to say though i am getting bloody sick of all these massive 3dbenchy boats lying around my living room. lol
