    Duet 3 Mini 5+ VIN under-voltage issues in SBC mode
    120
    7.3k
    • lodgerundefined
      lodger
      I have come down this morning to find a stalled print. Here is my M122,
      m122
      RepRapFirmware for Duet 3 Mini 5+ version 3.2.2 running on Duet 3 Mini5plus WiFi (SBC mode)
      Board ID: XJDX9-1296U-D65J0-40KMJ-4K03Z-7J6X6
      Used output buffers: 1 of 40 (18 max)
      Static ram: 98732
      Dynamic ram: 95844 of which 64 recycled
      Never used RAM 50576, free system stack 122 words
      Tasks: Linux(ready,99) HEAT(blocked,297) CanReceiv(blocked,947) CanSender(blocked,358) CanClock(blocked,362) TMC(blocked,75) MAIN(running,476) IDLE(ready,20) AIN(blocked,264)
      Owned mutexes: HTTP(MAIN)
      Last reset 17:19:34 ago, cause: software
      Last software reset at 2021-03-19 15:58, reason: User, none spinning, available RAM 50808, slot 1
      Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      Aux1 errors 0,0,0
      Supply voltage: min 0.0, current 24.2, max 24.3, under voltage events: 2, over voltage events: 0, power good: yes
      Driver 0: position 16355, standstill, SG min/max 0/428, read errors 0, write errors 1, ifcnt 223, reads 13005, writes 43, timeouts 17110, DMA errors 0, failedOp 0x71
      Driver 1: position 2458, standstill, SG min/max 0/410, read errors 0, write errors 1, ifcnt 223, reads 30107, writes 43, timeouts 7, DMA errors 0, failedOp 0x6f
      Driver 2: position 63048, standstill, SG min/max 0/44, read errors 0, write errors 1, ifcnt 189, reads 29631, writes 32, timeouts 494, DMA errors 0, failedOp 0x71
      Driver 3: position 0, standstill, SG min/max 0/30, read errors 0, write errors 1, ifcnt 188, reads 29889, writes 32, timeouts 235, DMA errors 0, failedOp 0x01
      Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 155, reads 30130, writes 27, timeouts 0, DMA errors 0
      Driver 5: position 0, assumed not present
      Driver 6: position 0, assumed not present
      Date/time: 2021-03-20 09:18:05
      Slowest loop: 178.10ms; fastest: 0.08ms
      === Storage ===
      Free file entries: 10
      SD card 0 not detected, interface speed: 0.0MBytes/sec
      DMs created 83, maxWait 11368610ms, bed compensation in use: mesh, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 190766, completed moves 190766, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Bed heaters = 0 -1, chamberHeaters = 2 -1
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File* is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue* is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === CAN ===
      Messages queued 561364, send timeouts 561361, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 15
      === SBC interface ===
      State: 4, failed transfers: 0
      Last transfer: 3ms ago
      RX/TX seq numbers: 42328/42328
      SPI underruns 0, overruns 0
      Number of disconnects: 0, IAP RAM available 0x10eec
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.2.2
      Code buffer space: 4096
      Full transfers per second: 36.40
      Maximum length of RX/TX data transfers: 5108/1664.
        @lodger, was that a print or a simulation?
        Please can you try the firmware at https://www.dropbox.com/sh/6203euyyobllic5/AABTHIbn7F_maK9p-oy7vq3Ea?dl=0 with the same file to see if it happens again.
        lodgerundefined 2 Replies Last reply Reply Quote 0
        • lodgerundefined
          lodger @dc42
          @dc42 Hi,
          Yes it was a print. I will just put the kettle on and update and print. It was a 10 hour print so i may not get back to you till tomo.
          Edit:: I have updated and run a Similator of the same file. Without problems !
          Just running the print now .
          • lodgerundefined
            lodger @dc42
            @dc42 Mornings.
            The print completed . with no under voltage triggers at all. I will try print something else and report if i get any more problems
              dc42 administrators @lodger
              @lodger said in Duet 3 Mini 5+ VIN under-voltage issues in SBC mode:
              @dc42 Mornings.
              Thanks for the update.
              Anyone else having this problem and happy to use beta firmware, feel free to try the firmware that I linked to above. It's compatible with DWC 3.3beta2.
              • Serbitarundefined
                Serbitar
                I have put my machine back into SBC mode running the linked beta firmware.
                It completed a 12h print over night, print queue has shorter jobs for the next few days. I will update if there are any under voltage detection issues.
                  dc42 administrators @Serbitar
                  @Serbitar, thanks for the update.
                  • Serbitarundefined
                    Serbitar
                    Not fixed i'm afraid
                    Mar 24 19:21:32 DuetControlServer[3177]: Print auto-paused due to low voltage
                    Mar 24 19:21:32 DuetControlServer[3177]: [warn] VIN under-voltage event (0.0V)
                    m122
                    RepRapFirmware for Duet 3 Mini 5+ version 3.3beta2+1 running on Duet 3 Mini5plus WiFi (SBC mode)
                    Board ID: W4ZW4-V296U-D65J0-40KM0-LR03Z-H6928
                    Used output buffers: 1 of 40 (32 max)
                    Static ram: 99720
                    Dynamic ram: 98408 of which 24 recycled
                    Never used RAM 45552, free system stack 88 words
                    Tasks: Linux(ready,145) HEAT(notifyWait,299) CanReceiv(notifyWait,943) CanSender(notifyWait,358) CanClock(delaying,340) TMC(notifyWait,109) MAIN(running,310) IDLE(ready,20) AIN(notifyWait,260)
                    Last reset 21:38:59 ago, cause: software
                    Last software reset at 2021-03-23 21:38, reason: User, none spinning, available RAM 46528, slot 2
                    Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a
                    Error status: 0x00
                    Aux0 errors 0,0,0
                    Aux1 errors 0,0,0
                    Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 3, over voltage events: 0, power good: yes
                    Driver 0: position -5573, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 19, reads 5889, writes 9, timeouts 17, DMA errors 0, failedOp 0x01
                    Driver 1: position -6035, standstill, SG min/max 0/44, read errors 0, write errors 0, ifcnt 20, reads 5906, writes 9, timeouts 0, DMA errors 0
                    Driver 2: position 8601, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 19, reads 5906, writes 9, timeouts 0, DMA errors 0
                    Driver 3: position 0, standstill, SG min/max 0/256, read errors 0, write errors 0, ifcnt 22, reads 5906, writes 9, timeouts 0, DMA errors 0
                    Driver 4: position 0, standstill, SG min/max 0/210, read errors 0, write errors 0, ifcnt 22, reads 5906, writes 9, timeouts 0, DMA errors 0
                    Driver 5: position 0, standstill, SG min/max 0/2, read errors 0, write errors 0, ifcnt 22, reads 5906, writes 9, timeouts 0, DMA errors 0
                    Driver 6: position 0, standstill, SG min/max 2/2, read errors 0, write errors 0, ifcnt 22, reads 5906, writes 9, timeouts 0, DMA errors 0
                    Date/time: 2021-03-24 19:22:01
                    Slowest loop: 1.95ms; fastest: 0.13ms
                    === Storage ===
                    DMs created 83, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000
                    === MainDDARing ===
                    Scheduled moves 467805, completed moves 467805, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
                    === AuxDDARing ===
                    Bed heaters = 0 -1, chamberHeaters = -1 -1
                    Heater 0 is on, I-accum = 0.0
                    Heater 1 is on, I-accum = 0.5
                    Segments left: 0
                    File* is doing "G1 X-68.586998 Y-74.568001 E0.009290" in state(s) 0
                    === Filament sensors ===
                    Extruder 0 sensor: ok
                    Extruder 1 sensor: ok
                    === CAN ===
                    Messages queued 266, send timeouts 266, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                    Last cancelled message type 30 dest 127
                    Last transfer: 5ms ago
                    RX/TX seq numbers: 65096/65096
                    Number of disconnects: 0, IAP RAM available 0x11578
                    Buffer RX/TX: 1776/3288-0
                    Duet Control Server v3.3-b2
                    File:
                    Buffered code: G1 X-68.587 Y-74.568 E0.00929
                    Buffered code: G1 X-67.933 Y-73.726 E0.01535
                    Buffered code: G1 X-67.168 Y-72.475 E0.02112
                    Buffered code: G1 X-66.365 Y-70.761 E0.02725
                    Buffered code: G1 X-65.747 Y-68.922 E0.02792
                    Buffered code: G1 X-67.640 Y-69.345 E0.02792
                    Buffered code: G1 X-69.429 Y-69.963 E0.02725
                    Buffered code: G1 X-70.754 Y-70.594 E0.02112
                    Buffered code: G1 X-71.659 Y-71.156 E0.01535
                    Buffered code: G1 X-72.167 Y-71.554 E0.00929
                    Buffered code: G1 X-72.601 Y-72.094 E0.00997
                    Buffered code: G1 X-75.105 Y-70.343 E0.04398
                    Buffered code: G1 X-74.694 Y-69.718 E0.01078
                    Buffered code: G1 X-74.473 Y-69.112 E0.00928
                    Buffered code: G1 X-74.219 Y-68.077 E0.01535
                    Buffered code: G1 X-74.028 Y-66.623 E0.02111
                    Buffered code: G1 X-73.992 Y-64.730 E0.02725
                    Buffered code: G1 X-74.175 Y-62.799 E0.02792
                    Buffered code: G1 X-75.733 Y-63.955 E0.02792
                    Buffered code: G1 X-77.116 Y-65.248 E0.02725
                    Buffered code: G1 X-78.069 Y-66.363 E0.02112
                    Buffered code: G1 X-78.668 Y-67.244 E0.01535
                    Buffered code: G1 X-78.970 Y-67.814 E0.00929
                    Buffered code: G1 X-79.146 Y-68.484 E0.00997
                    Buffered code: G1 X-82.146 Y-67.903 E0.04398
                    Buffered code: G1 X-82.025 Y-67.165 E0.01077
                    Buffered code: G1 X-82.070 Y-66.521 E0.00929
                    Buffered code: G1 X-82.258 Y-65.472 E0.01535
                    Buffered code: G1 X-82.675 Y-64.066 E0.02112
                    Buffered code: G1 X-83.413 Y-62.322 E0.02725
                    Buffered code: G1 X-84.365 Y-60.633 E0.02792
                    Buffered code: G1 X-85.318 Y-62.322 E0.02792
                    ==> 1512 bytes
                    Code buffer space: 1660
                    Full transfers per second: 47.08
                    Codes per second: 17.66
                    Maximum length of RX/TX data transfers: 5884/1664
                    File /opt/dsf/sd/gcodes/eggGears-2and6_0.08mm_PETG_ENDER3_6h50m.gcode is selected, processing
                    • ukwebbundefined
                      ukwebb
                      Just to add another voice, I and also getting this same issue.
                      Last night, 70% and 5 hours into a print it just stopped, and displayed VIN undervoltage event (0.0v) and then Insufficient axis homed
                      My setup is based around a coreXY machine, with a dedicated meanwell 5v 5a psu for the pi, and a meanwell 24v 6amp supply for the printer, the hot bed is 240v
                      Also, this hasn't happed until recently - i think after i did an apt update. so it was probably fine on 3.1 but not 3.2
                      lodgerundefined 1 Reply Last reply Reply Quote 0
                      • lodgerundefined
                        lodger @ukwebb
                        @ukwebb Have you tried the beta DC24 posted above.
                        ukwebbundefined 1 Reply Last reply Reply Quote 0
                          @Serbitar said in Duet 3 Mini 5+ VIN under-voltage issues in SBC mode:
                          Please can you run M115 to confirm the build date of the firmware you are using.
                          Serbitarundefined 1 Reply Last reply Reply Quote 0
                          • Serbitarundefined
                            Serbitar @dc42
                            FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.3beta2+1 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2021-03-19 18:26:13
                            • Serbitarundefined
                              Serbitar
                              After the previous failure I dropped the SPI rate to 2MHz but that hasn't helped. Printer just stopped while doing G29 with the dreaded under-voltage event.
                              dc42undefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                @Serbitar, thanks for the additional data point.
                                • ukwebbundefined
                                  ukwebb @lodger
                                  @lodger No i haven't, as @Serbitar has already said its not fixed the issue
                                    droftarts administrators @Serbitar
                                    @Serbitar I've been running 'air' prints on my test rig today. I've had one under-voltage event, 1h 18m into a 3h 30m print, but running the same exact file and settings did not provoke another. So trying to get to the bottom of this issue is, unfortunately, taking some time.
                                    Serbitarundefined lodgerundefined 2 Replies Last reply Reply Quote 0
                                    • Serbitarundefined
                                      Serbitar @droftarts
                                      @droftarts Yeah. I haven't worked out a pattern yet. Please let me know if I can do any useful testing.
                                      • lodgerundefined
                                        lodger @droftarts
                                        @droftarts When DC42 ask on Saturday I also printed the same file without issue .
                                        I have been printing around the clock up till Tuesday. Again without issue. There is just no patten.
                                        I have one of the first batch of boards, and on a earlier firmware (dont ask what one).
                                        I am sure i had this happen in standalone mode. So since Tuesday i have been printing non stop trying to prove this.
                                        I have to say though i am getting bloody sick of all these massive 3dbenchy boats lying around my living room. lol
                                          I have put new firmware at 2021-03-26 10:59:15. Those of you who have experienced this issue and have an idle machine, please can you try it and do a print (an air print will do, no need to waste filament). If you get a VIN undervoltage event, please post a M122 report. M115 should report firmware date 2021-03-26 10:59:15 for this build.
                                          • Serbitarundefined
                                            Serbitar @dc42
                                            @dc42 Same dropbox link as the previous one?
