    duet 2 froze with diag and endstop led
    764
    • KevinSantundefined
      KevinSant @Phaedrux
      @Phaedrux tested fuses and they are good and that was first thing i did was try to
      jump and erase firmware and stll nothing still shows up with lghts that you see pictued
        Do you notice any components getting hot to the touch?
          KevinSant
          YES PLUGGED IN TO USB TO CHECK AND ESP AND CARD READER GET HOT EVERYTHGING ELSE SEEMS COOL TO TOUCH ITS LIKE ALL THE LIGHTS THAT WERE ON WHEN IT FROZE STAY ON E1 HEAT X Y ENDSTOP
            Is this a new Duet? Did it ever work?
            When and where did you purchase it?
            KevinSantundefined 1 Reply Last reply Reply Quote 0
              KevinSant @Phaedrux
              @Phaedrux i purchased like 3 weeks ago from matterhackers out of california i had a clone before and wanted to support the original so bought this one i haventbeven had one print yet i had everythinh working fine homed everything than ran pid tunes then getting ready to print some calibration pieces than it just froze but it not even a month old
                Can you post some photos of the top of the board so we can see if there's anything blown? Try get a close up well lit steady shot.
                KevinSantundefined 2 Replies Last reply Reply Quote 0
                  KevinSant @Phaedrux
                  This post is deleted!
                    KevinSant @Phaedrux
                    @Phaedrux CAN I SEND IT IN TO BE FIXED IS IT COVERED UNDER WARRANTY BEING SO NEW
                      Why are the tabs on the connectors broken?
                        KevinSant @Phaedrux
                        @Phaedrux WHEN I WAS SETTING MOTOR ETC IT WAS EASIER FOR ME TO TURN AROUND CONNECTORS THEN SWITCHING WIRES SO I CAN GET TO HOME IN CORRECT DIRECTION
                          There seems to be some burn marks near the fan header?
                            KevinSant
                            i didnt see anything burn out and it dpoesnt have that unique smell?i only had one 5v pwm fan hoooked to it but are you talking about between Y endstop and fan 2?
                              T3P3Tony administrators
                              I am trying to work out what could have gone wrong with this board. Few questions:
                              why is there burns here:
                              Why is the housing removed form the fan voltage select header:
                              You say that the ESP and card reader get hot. That indicates they have been damaged, does the ESP still get hot without the SD card in? This damage normally happens when VIN voltage is applied to the 3.3V signal lines.
                                KevinSant @T3P3Tony
                                @T3P3Tony the housing was removed by accident came up with the jumper when II had 24 v hotend fan and switched to 12 v I used a a step down buck with positive connected as per douziki come to think of why the burn marks I did a hot shrink repair but board was off and used a hot air gun pretty positive that had no effect do you think because that housing was off that the vin power touched ocb and caused short?
                                  KevinSant @T3P3Tony
                                  @T3P3Tony and yes components get hot with nothing attached
                                    KevinSant @KevinSant
                                    @KevinSant what can it touch the 5v pin ? and why would that make those lights freeze? so now what throw it in trash and get another or would it be cheaper to get repaired being less than a month old
                                      Given the damage to the board the best we can do is offer a reduced cost refurbished unit on exchange. If that's of interest to you, please contact roland@duet3d.com to inquire about availability. Please include a link to this thread.
