    Problems with X axis when running tests
    593
    • BeyondXundefined
      BeyondX
      Hey,
      I am a new member of 3d printing world and i am currently setting up my first 3d printer. It is a Caribou Duet 2 WIfi.
      I managed to get everything connected and setup, but am currently running is some issues with my extruder running out of position on X axis. If i manually set the extruder in the middle of the bed, i can home all 3 axis and my Pinda 2 Z probe is working ok.
      When running one of the tests the extruder is not following the limitations in the config/macro and it goes all the way far left, so my Pinda moves out of the bed. Since the test then tests PINDA aswell, it lowers my extruder on Z axis without ever stopping and crashing into the bed.
      Here is my config :
      config.g
      Anyone can help me out with how to limit the extruder to not move all the way to the end, but to stop beforehand?
      Thanks in advance!
      BeyondX
        What tests are you running?
          ; Configuration file for Duet WiFi (firmware version 3.2)
          ; for 0.9° motors on xye
          ; for Caribou320- SE Thermistor - PINDA2
          ; CariboDuetConfiguration Release : "1.2.4"
          ;                           Build :   107
          ; Copyright Caribou Research & Development 2021. Licensed under GPL3.
          ; Source code and release notes are available on github: https://github.com/Caribou3d/CaribouDuet-Configuration-and-Macros
          ; Network settings
          M550 P"Caribou320-SP"                                 ; set printer name
          M552 S1                                                ; enable network
          M586 P0 S1                                             ; enable HTTP
          M586 P1 S1                                             ; enable FTP
          M586 P2 S0                                             ; disable Telnet
          M575 P1 S1 B57600                                      ; Enable support for PanelDue
          M569 P0 S0 F11                                         ; physical drive 0 goes backwards - x-axis
          M569 P1 S0 F8 Y3:2                                     ; physical drive 1 goes backwards - y-axis
          M569 P2 S0 F10                                         ; physical drive 2 goes backwards - z - left
          M569 P3 S1 F14                                         ; physical drive 3 goes forwards  - Extruder
          M569 P4 S0 F10                                         ; physical drive 4 goes backwards - z right
          ; Motor Configuration
          M584 X0 Y1 Z2:4 E3                                     ; set drive mapping
          M671 X-36.5:293.5 Y0:0 S1.00                           ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
          ; set Microsteps and steps / mm
          M350 X16 Y16 Z16 E16 I1                                ; configure microstepping with interpolation
          M92 X200.00 Y200.00 Z400.00 E830.00                    ; set steps per mm
          ; set motor currents
          M906 X950 Y1000 Z650 E650 I40                          ; set motor currents (mA) and motor idle factor in per cent
          M84 S60                                                ; Set idle timeout
          ; set speeds
          M201 X500.00 Y500.00 Z100.00 E500.00                   ; set accelerations (mm/s^2)
          M203 X9000.00 Y9000.00 Z1000.00 E3600.00               ; set maximum speeds (mm/min)
          M204 P500.0 T500.0                                     ; set print and travel accelerations (mm(s^2)
          M566 X480.00 Y480.00 Z48.00 E300.00                    ; set maximum instantaneous speed changes (mm/min)
          M564 H0                                                ; Allow unhomed movement
          M208 X5 Y0 Z0 S1                                   ; set axis minima
          M208 X210 Y190 Z300 S0                    	           ; set axis maxima
          M574 X1 S3                                             ; configure sensorless endstop for low end on X
          M574 X1 S1 P"xstop"  								   ; X min active high endstop switch
          M574 Y1 S3                                             ; configure sensorless endstop for low end on Y
          M574 Y1 S1 P"ystop"  								   ; Y min active high endstop switch
          M574 Z1 S2                                             ; configure Z-probe endstop for low end on Z
          M574 Z2 S3                                             ; configure sensorless endstop for high end on Z
          M591 D0 P2 C"e0_stop" S1                       ; configure extruder endstop (filament sensor)
          ; PINDA2
          M558 P5 C"zprobe.in" H1.5 F1000 T12000 A3                   ; set Z probe to PINDA2
          M308 S2 P"e1temp" A"Pinda V2" Y"thermistor" T100000 B3950   ; temperature of PINDA2
          M557 X23:235 Y5:186 S30.25:30                               ; define mesh grid
          M574 Z1 S2                                             ; Set endstops controlled by probe
          ; Stallguard Sensitivy
          M915 X S2 F0 H200 R0                                   ; Set X axis Sensitivity
          M915 Y S1 F0 H200 R0                                   ; Set Y axis Sensitivity
          M915 Z S0 F0 H200 R0                                   ; Set Z axis Sensitivity
          ; Heater & Fans
          ; heated bed
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 R4700 A"Bed"  ; configure sensor 0 as thermistor on pin bedtemp
          M950 H0 C"bedheat" Q50 T0                                    ; create bed heater output on bedheat and map it to sensor 0
          M143 H0 S110                                                 ; set temperature limit for heater 0 to 110C
          M307 H0 B0 S1.00                                             ; disable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                                      ; map heated bed to heater 0
          ; extruder
          ; Hotend (Mosquito or Mosquito Magnum with SE Thermistor)
          M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 A"Nozzle"   ; SE configure sensor 0 as thermistor on pin e0temp
          M950 H1 C"e0heat" T1                                        ; create nozzle heater output on e0heat and map it to sensor 2
          M307 H1 B0 S1.00                                            ; disable bang-bang mode for heater  and set PWM limit
          M143 H1 S365                                                ; set temperature limit for heater 1 to 365°C
          M308 S4 P"mcu-temp" Y"mcu-temp" A"MCU"                 ; set virtual heater for MCU
          M308 S5 P"drivers" Y"drivers" A"Driver"                ; set virtual heater for stepper drivers
          ; extruder fan (temerature controlled)
          M950 F1 C"fan1" Q500                                   ; create fan 1 on pin fan0 and set its frequency
          M106 P1 H1 T45                                         ; fan turns on at 45°C
          ; radial fan
          M950 F0 C"fan0" Q160                                   ; create fan 0 on pin fan1 and set its frequency
          M106 P0 S0 H-1                                         ; set fan 0 value. Thermostatic control is turned off
          M563 P0 D0 H1 F0                                       ; define tool 0
          G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
          G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
          M302 S190 R190                                         ; allow extrusion starting from 190°C and retractions already from 190°C
          ; other settings
          M18 XYE                                                ; release / unlock X, Y, and E axis
          M501                                                   ; use config-override (for Thermistor Parameters and other settings)
          G90                                                    ; send absolute coordinates...
          M83                                                    ; ... but relative extruder moves
          ; Offsets - place off-sets for x and y here. z-offsets are handled in the print sheet macros
          G31 P1000 X23 Y5
          I can't tell from your config if you're using endstops or stall detection for XY homing.
          BeyondXundefined 1 Reply Last reply Reply Quote 0
          • BeyondXundefined
            BeyondX
            Hey, thanks alot for a reply.
            I always thought a Gcommand M574 takes care of the enstops? Ofcourse i might be dead wrong and might be missing something major, but here is the Level-X axis test i have been struggling with:
            M913 X100 Y100 Z100          ; set motor currents to 100%
            G91                          ; relative positioning
            G28                          ; home Axes
            G90                          ; absolute positioning
            G1 X125 Y55 F6000            ; move extruder to the middle of the X axis
            M564 S0                      ; disable minimum and maximum axis limits
            G1 Z305 F6000                ; Move Z axis just below top
            M913 Z40                     ; reduce Z motor current to 30% of set current
            G1 H1 Z15 F300               ; move Z axis 20mm up slowly levling the X gantry
            M913 Z100                    ; return Z motor current to 100% of set current
            M564 S1                      ; enable minimum and maximum axis limits
            M208 X256.9 Y214 Z316.50 S0  ; set axis maxima
            G1 X11.5 Y4.5 Z10.0 F6000    ; go to first probe point
            M400	     	             ; wait for current moves to finish
            G30                          ; probe bed
            I alos have M208 command included in cofig file, where i tried to limit the movement of the axes, but not sure if that works in the way i thought 🙂
            I downloaded the config and macros of the github, both were made directly for the version i am using - Caribou3d Duet 2 Wifi 320 with SE thermistor and PINDA2.
            Any further help on how to get the tests up and running and start printing would be greatly appreciated!
            Best regards,
            BeyondX
              Phaedrux Moderator @BeyondX
              @beyondx said in Problems with X axis when running tests:
              It does, but you have m574 for both sensorless and endstops.
              So only the second instance will take effect. So first it sets sensorless and then sets endstops. So if you're trying to use sensorless you should remove the endstop m574s.
              • BeyondXundefined
                BeyondX @Phaedrux
                @phaedrux
                Would then removing the endstop and only keep sensorless, cause that extruder would be moving base of the limits set with M208?
                Additionally, would this kind of removal of endstop switches in M574 successfully run the provided macro as well?
                Thanks in advance!
                  Does the printer have actual endstop switches or not?
                  If you have them, I would suggest just using them.
                  Either way, if you want to use sensorless homing you need to remove the M574 commands that define the endstop switches and leave the commands that define sensorless homing.
                  https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing
                  • BeyondXundefined
                    BeyondX
                    @phaedrux
                    I do apologize for a late reply!
                    Thanks for the help thus far. I have double checked and indeed tehre is no physical endstops, so i will go with sensorless homing.
                    That being said, when i tried to do the tests again i am running into the problem with homing X axis. The homing goes through normally, but i still get a G28 X Error: Homing failed.
                    I am not sure if i am missing a G28 code at all, but Y axis is home normally.
                    Attached both homex.g and homey.g file
                    What am i missing?
                    homey.g homex.g
                    Thanks in advance for the help!
                      What do you have in this macro?
                      M98 P"current-sense-homing.g"
                      If Y works but X does not that may mean that X needs a different motor current or sensitivity setting. You'll need to do some tuning to get reliable stalls.
                      • BeyondXundefined
                        BeyondX @Phaedrux
                        @phaedrux Hey, thesae are the two homing files.
                        current-sense-normal.g
                        For stallguard sensitivity i have these:
                        Best regards,
                        BeyondX
                          What kind of a tuning process did you use to arrive at those values?
