    Fan needs more power to start spinning.
    • snagit007undefined
      snagit007
      Hi guys, I am new here and just got my BLV mgn cube working with Duet3 and RRF3. Very proud of this piece of equipment!
      I have a little issue with parallel fans which are used for the x/y motor cooling. They do not start itself and I need to touch them to spin, then they keep on running.
      I did not find any info if the frequency is related to the power? Is there any other parameter which could give it more power?
      M950 F2 C"out7" Q500
      M106 P2 C"Motor Fan" T50 H0
      jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @snagit007
        @snagit007 add a blip value to the M106. E.g. B1
          Phaedrux Moderator @snagit007
          @snagit007 said in Fan needs more power to start spinning.:
          There should also be an S value on that line to tell it what speed to use when the temp is reached. S1 would be full power.
            snagit007
            everything is becoming clearer with every hour I spent. Thanks so much!
