Disable internal driver on duex 5
363
    moe.adams9093
    I have a question if I disable the Internal driver on duex 5 driver number 7&8 are available what would be the voltage?. will it be 3.3V or 5V to drive external and what will be the number for the new drivers.
    undefined undefined 2 Replies Last reply 1 Apr 2021, 22:26 Reply Quote 0
      Phaedrux Moderator @moe.adams9093
      @moe-adams9093 said in Disable internal driver on duex 5:
      Sorry but I'm not really sure what you're asking.
      What are you trying to do?
        dc42 administrators @moe.adams9093
        @moe-adams9093, how may external drivers do you need to add? If it's just two then it's easier to use CONN_LCD instead. The signal levels are 3.3V.
        undefined 1 Reply Last reply 2 Apr 2021, 19:45 Reply Quote 0
          moe.adams9093 @dc42
          @dc42 it’s only 2 driver they are already hooked up on conn lcd Esteps calibrated 100 present but they are rough when printing I believe it’s because conn lcd provide only 3.3 v and the encoder require 5V minimum. According to the documentation of the motors the T perimeter should be at 5us that’s at 200khz. I was thinking about installing a shift register high speed but also I’m Worried about losing some signals from the input. So any technical suggestions or advice? Motors are NEMA 23 driver and encoder built in. Thank you
          undefined 1 Reply Last reply 3 Apr 2021, 05:18 Reply Quote 0
            @moe-adams9093, I suggest you use a 74LVC06 chip to convert the 3.3V signals to 5V for the external drivers.
            undefined 1 Reply Last reply 9 Apr 2021, 03:58 Reply Quote 0
              moe.adams9093 @dc42
              @dc42 said in Disable internal driver on duex 5:
              74LVC06
              Thank you for your suggestions I couldn’t find 74LVC06 in stock
              I found 74LVC06A-Q100
              Hex inverter with open-drain outputs do you think this chip should work fine.
              Thanks for your suggestions do you think using internal driver will be a lot better then using external as far positioning and accuracy speed etc or it will perform as the same. Because I have few more printer and they all use duet board and I don’t have this issue rough printing surface and lots of vibration when it’s moving. Thanks
              undefined 1 Reply Last reply 9 Apr 2021, 20:20 Reply Quote 0
                74LVC06A-Q100
                Yes, the -Q100 is the more expensive automotive qualified version of the same chip.
                undefined 1 Reply Last reply 11 Apr 2021, 04:02 Reply Quote 0
                  moe.adams9093 @dc42
                  @dc42 ok thank you
                  5 out of 8
