    M12 Heatsink does not fit PCB Smart Effector Hole
    Smart effector for delta printers
    507
      T3P3Tony administrators @ignacmc
      @ignacmc the fit is designed to be very snug to avoid centering issues etc.
      I just measured a couple of heatsinks i have to hand and they are 11.95 in diameter so it may be that the heatsinks are very lightly wider then they used to be at 12mm.
      Can you screw the heatsink through the PCB?
      ignacmcundefined 1 Reply Last reply Reply Quote 0
      • ignacmcundefined
        ignacmc @T3P3Tony
        @t3p3tony The screw passes through the hole quite snugly...but the shoulder below the screw is unable to pass. As I told you before, I have an old M12 threaded E3dv6 clone heatsink bought on aliexpress two years ago and it has exactly the same problem. Seems that the "excepcionality" is in the PCB hole diameter....
        Should i enlarge the hole a bit by carefully sanding the inside or what would you suggest? Trying to push the shoulder by hand force through the hole has not been successful.
        Predator with Duet3 Mini 5+, Smarteffector v4 and LGX Lite Extruder
          @ignacmc Ahh i see. i would try sanding rather than focring it through, especially as its only 0.1mm or so.
          • ignacmcundefined
            ignacmc @T3P3Tony
            @t3p3tony Seems that the PCB is quite traslucid on that zone (up to 2mm around the hole....There should be not PCB tracks there that I could damage, right?
            T3P3Tonyundefined dc42undefined 2 Replies Last reply Reply Quote 0
              @ignacmc thats correct there is a 16mm diameter exclusion area:
                dc42 administrators @ignacmc
                @ignacmc, the PCB is only 2-layer and the traces are a few mm from the inside of the hole, so you can use e.g. a needle file to enlarge the hole slightly. But take great care not to scratch the fine strain gauge traces on either side of the PCB.
                • ignacmcundefined
                  ignacmc @dc42
                  @dc42 I have just introduced my finger sheated with a piece of sandpaper, rubbed all around several times, and it seems to pass through now. I would say that I have not caused any noticeable "lateral play" or gap on the system...the fit is still snug so I expect it will work.
                  • ignacmcundefined
                    ignacmc @ignacmc
                    @ignacmc One last question...if I want to use a "non-threaded" heatsink like the Mosquito or Dragon Hotend....Will it work with a M12 printed adapter? there are some on Thingiverse
                    dc42undefined Dougal1957undefined 2 Replies Last reply Reply Quote 0
                      @ignacmc said in M12 Heatsink does not fit PCB Smart Effector Hole:
                      I don't see why that wouldn't work. A harder plastic will transmit the force of nozzle contact better than a soft plastic.
                      • Dougal1957undefined
                        Dougal1957 @ignacmc
                        713maker do manufacture an adaptor for the Mosquito which IMHO would be the best option see https://713maker.com/gb/mosquito/mosquito-hot-end-duet-smart-effector-adaptor
                        hth
                        Doug
