    Duet 3 Mini 5+ VIN under-voltage issues in SBC mode
    120
    7.0k
    • Serbitarundefined
      Serbitar @dc42
      @dc42 I had reset the board much earlier, around 17:00.
      At 17:24 the VSSA faults started.
      At 1729 I did m122 and then reset the board so that I could copy the result out of DWC. The m122 is from before that reset.
      • M-Pixelundefined
        M-Pixel
        Error: VSSA fault, check thermistor wiring
        4/12/2021, 11:07:17 AM 	M122
        RepRapFirmware for Duet 3 Mini 5+ version 3.3beta2+1 (2021-04-11 10:20:02) running on Duet 3 Mini5plus Ethernet (SBC mode)
        Board ID: PG824-LA67A-G65J0-40TFS-L3D0Z-ZGG9A
        Used output buffers: 1 of 40 (12 max)
        Static ram: 100072
        Dynamic ram: 92492 of which 0 recycled
        Never used RAM 48284, free system stack 126 words
        Tasks: Linux(ready,139) HEAT(delaying,231) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(delaying,332) TMC(notifyWait,99) MAIN(running,599) IDLE(ready,20) AIN(notifyWait,260)
        Owned mutexes: HTTP(MAIN)
        Last reset 01:46:38 ago, cause: power up
        Last software reset at 2021-04-11 19:13, reason: User, none spinning, available RAM 48284, slot 0
        Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a
        Error status: 0x00
        Aux0 errors 0,0,0
        Aux1 errors 0,0,0
        MCU revision 3, ADC conversions started 7620048, completed 7620047, timed out 0, errs 1
        tnd=0 rnd=0 wrd=0 wtd=1 war=1
        Supply voltage: min 0.0, current 0.1, max 24.3, under voltage events: 1, over voltage events: 0, power good: no
        Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/12/0, gc cycles 0
        Driver 0: position 16418, ok, SG min/max 0/72, read errors 0, write errors 0, ifcnt 15, reads 20007, writes 15, timeouts 1, DMA errors 0, failedOp 0x01
        Driver 1: position 8692, ok, SG min/max 0/54, read errors 0, write errors 0, ifcnt 15, reads 19999, writes 15, timeouts 9, DMA errors 0, failedOp 0x6a
        Driver 2: position 120, standstill, SG min/max 0/352, read errors 0, write errors 0, ifcnt 15, reads 20008, writes 15, timeouts 0, DMA errors 0
        Driver 3: position 0, ok, SG min/max 0/34, read errors 0, write errors 0, ifcnt 13, reads 20001, writes 13, timeouts 9, DMA errors 0, failedOp 0x6a
        Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 20012, writes 11, timeouts 0, DMA errors 0
        Driver 5: position 0, assumed not present
        Driver 6: position 0, assumed not present
        Date/time: 2021-04-12 19:07:16
        Slowest loop: 108.23ms; fastest: 0.06ms
        === Storage ===
        Free file entries: 10
        SD card 0 not detected, interface speed: 0.0MBytes/sec
        DMs created 83, maxWait 5180087ms, bed compensation in use: none, comp offset 0.000
        === MainDDARing ===
        Scheduled moves 623, completed moves 623, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
        === AuxDDARing ===
        Bed heaters = 0 -1, chamberHeaters = -1 -1
        Segments left: 0
        Movement lock held by null
        Telnet is idle in state(s) 0
        File* is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Queue* is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is idle in state(s) 0
        Aux2 is idle in state(s) 0
        Code queue is empty.
        === CAN ===
        Messages queued 57504, send timeouts 57501, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
        Last cancelled message type 30 dest 127
        === SBC interface ===
        State: 4, failed transfers: 0
        Last transfer: 3ms ago
        RX/TX seq numbers: 30312/30312
        SPI underruns 0, overruns 0
        Number of disconnects: 0, IAP RAM available 0x118dc
        Buffer RX/TX: 0/0-0
        === Duet Control Server ===
        Duet Control Server v3.2.2
        Code buffer space: 4096
        Full transfers per second: 5.95
        Maximum length of RX/TX data transfers: 3220/1640
        File /opt/dsf/sd/gcodes/hdd-rack-frame large left.gcode is selected, paused
        • PaulHewundefined
          PaulHew
          Just had another VSSA.
          12/04/2021, 21:12:04 	Error: VSSA fault, check thermistor wiring
          12/04/2021, 21:12:01 	m122
          RepRapFirmware for Duet 3 Mini 5+ version 3.3beta2+1 (2021-04-12 08:36:30) running on Duet 3 Mini5plus Ethernet (SBC mode)
          Board ID: A45XG-F396U-D65J0-40KML-1F03Z-H03XP
          Used output buffers: 4 of 40 (20 max)
          Static ram: 100072
          Dynamic ram: 91932 of which 0 recycled
          Never used RAM 51700, free system stack 172 words
          Tasks: Linux(resourceWait,127) HEAT(delaying,322) CanReceiv(notifyWait,774) CanSender(notifyWait,371) CanClock(delaying,340) TMC(notifyWait,99) MAIN(running,484) IDLE(ready,20) AIN(notifyWait,259)
          Last reset 09:07:01 ago, cause: software
          Last software reset at 2021-04-12 12:04, reason: User, GCodes spinning, available RAM 51700, slot 1
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a
          Error status: 0x00
          Aux0 errors 0,0,0
          Aux1 errors 0,0,0
          MCU revision 3, ADC conversions started 39529293, completed 39529292, timed out 0, errs 1
          Supply voltage: min 0.0, current 0.1, max 24.0, under voltage events: 1, over voltage events: 0, power good: no
          Driver 0: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 61, reads 12224, writes 11, timeouts 20730, DMA errors 0, failedOp 0x6f
          Driver 1: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 61, reads 32954, writes 11, timeouts 0, DMA errors 0
          Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 63, reads 32953, writes 11, timeouts 0, DMA errors 0
          Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 63, reads 32953, writes 11, timeouts 0, DMA errors 0
          Driver 4: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 63, reads 32954, writes 11, timeouts 0, DMA errors 0
          Date/time: 2021-04-12 21:12:00
          Slowest loop: 36.07ms; fastest: 0.10ms
          === Storage ===
          === MainDDARing ===
          === AuxDDARing ===
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          File is idle in state(s) 0
          Queue is idle in state(s) 0
          === CAN ===
          Messages queued 295399, send timeouts 0, received 393841, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 384, free buffers 17 (min 16)
          Last transfer: 4ms ago
          RX/TX seq numbers: 54864/54864
          Number of disconnects: 0, IAP RAM available 0x118a8
          Buffer RX/TX: 0/0-0
          Full transfers per second: 35.62
          Maximum length of RX/TX data transfers: 3268/604
          12/04/2021, 21:12:00 	Error: VSSA fault, check thermistor wiring
            dc42 administrators @PaulHew
            Thanks, everyone. There are two clear patterns emerging.
            I am testing a new firmware build overnight, so maybe I will have news in the morning.
            lodgerundefined PaulHewundefined Fletcherundefined 3 Replies Last reply Reply Quote 1
            • lodgerundefined
              lodger @dc42
              @dc42 Did MicroChip get back to you. Or is this all you and the teams hard work.....Just to say thank you really ..
              Paul
              • PaulHewundefined
                PaulHew @dc42
                @dc42 Just out of interest, what is the critical bit in our logs that assist you DC42?
                • PaulHewundefined
                  PaulHew
                  Undervotage.... Printer was idle.
                  13/04/2021, 09:18:15 	m122
                  Used output buffers: 1 of 40 (23 max)
                  Static ram: 100072
                  Tasks: Linux(resourceWait,119) HEAT(delaying,322) CanReceiv(notifyWait,774) CanSender(notifyWait,371) CanClock(delaying,340) TMC(notifyWait,99) MAIN(running,484) IDLE(ready,20) AIN(notifyWait,259)
                  Last reset 12:02:11 ago, cause: software
                  Last software reset at 2021-04-12 21:16, reason: User, none spinning, available RAM 51700, slot 2
                  Error status: 0x00
                  Aux0 errors 0,0,0
                  Aux1 errors 0,0,0
                  MCU revision 3, ADC conversions started 51519632, completed 51519631, timed out 0, errs 3
                  tnd=0 rnd=0 wrd=0 wtd=3 war=3
                  Supply voltage: min 0.0, current 23.9, max 24.0, under voltage events: 1, over voltage events: 0, power good: yes
                  Driver 0: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 82, reads 28663, writes 20, timeouts 51838, DMA errors 0, failedOp 0x6f
                  Driver 1: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 82, reads 14925, writes 20, timeouts 40, DMA errors 0, failedOp 0x06
                  Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 84, reads 14965, writes 20, timeouts 0, DMA errors 0
                  Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 84, reads 14963, writes 20, timeouts 0, DMA errors 0
                  Driver 4: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 84, reads 14965, writes 20, timeouts 0, DMA errors 0
                  Date/time: 2021-04-13 09:18:16
                  Slowest loop: 63.01ms; fastest: 0.10ms
                  === Storage ===
                  === MainDDARing ===
                  === AuxDDARing ===
                  Segments left: 0
                  === CAN ===
                  Messages queued 389993, send timeouts 0, received 519973, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 500, free buffers 17 (min 16)
                  RX/TX seq numbers: 36429/36429
                  Buffer RX/TX: 0/0-0
                  Full transfers per second: 35.63
                  Maximum length of RX/TX data transfers: 3284/604
                  12/04/2021, 23:04:48 	Warning: VIN under-voltage event (0.0V)
                  • Fletcherundefined
                    Fletcher @dc42
                    @dc42 Another VSSA fault chain on the latest firmware:
                    4/13/2021, 7:41:44 AM 	Error: VSSA fault, check thermistor wiring
                    4/13/2021, 7:41:44 AM 	m122
                    Board ID: FDQG2-Q296U-D65J0-40KMG-1K03Z-HXFTZ
                    Static ram: 100072
                    Dynamic ram: 91764 of which 64 recycled
                    Never used RAM 51804, free system stack 172 words
                    Tasks: Linux(ready,137) HEAT(delaying,322) CanReceiv(notifyWait,774) CanSender(notifyWait,371) CanClock(delaying,340) TMC(notifyWait,99) MAIN(running,498) IDLE(ready,20) AIN(notifyWait,260)
                    Last reset 23:27:06 ago, cause: software
                    Last software reset at 2021-04-12 16:13, reason: User, none spinning, available RAM 51856, slot 1
                    Error status: 0x00
                    Aux0 errors 0,0,0
                    Aux1 errors 0,0,0
                    MCU revision 3, ADC conversions started 100481305, completed 100481304, timed out 0, errs 1
                    Supply voltage: min 0.0, current 0.1, max 24.4, under voltage events: 1, over voltage events: 0, power good: no
                    Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 218, reads 4487, writes 11, timeouts 0, DMA errors 0
                    Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 220, reads 4487, writes 11, timeouts 0, DMA errors 0
                    Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 192, reads 4489, writes 9, timeouts 0, DMA errors 0
                    Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 218, reads 4486, writes 11, timeouts 0, DMA errors 0
                    Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 218, reads 4487, writes 11, timeouts 0, DMA errors 0
                    Date/time: 2021-04-13 15:41:41
                    Slowest loop: 57.18ms; fastest: 0.08ms
                    === Storage ===
                    === MainDDARing ===
                    === AuxDDARing ===
                    Segments left: 0
                    === CAN ===
                    Messages queued 759838, send timeouts 0, received 1013078, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 354, free buffers 17 (min 16)
                    RX/TX seq numbers: 14877/14877
                    Buffer RX/TX: 0/0-0
                    Duet Control Server v3.3-b2
                    Full transfers per second: 35.89
                    Codes per second: 0.00
                    Maximum length of RX/TX data transfers: 3044/804
                    4/13/2021, 7:41:39 AM 	Error: VSSA fault, check thermistor wiring
                    It was stable for almost 24 hours, which is positive change, at least! Thank you for all the work you're putting in on this issue.
                      dc42 administrators @Fletcher
                      All, please try the new firmware at https://www.dropbox.com/sh/0mwfe22wepk5efh/AAB6Lp0rwBPjVK2R4SxbKhLya?dl=0. M115 reports it as 3.2beta2+2.
                      This version avoids using the ADC DMA sequencer completely, so I am hopeful that it will solve the problem. I was worried that the additional ADC interrupt load would be excessive, but with careful code optimisation I have got it down to 0.5% of total CPU time.
                      Serbitarundefined 1 Reply Last reply Reply Quote 2
                      • Serbitarundefined
                        Serbitar @dc42
                        @dc42 Looks like this version (and probably the other recent ones) breaks duetcontrolserver.
                        With 3.3b2 the logs are nice and quiet, with 3.3b2+2 the duetcontrolserver log is a fast rolling spam like this:
                        Apr 13 20:58:38 ender3 DuetControlServer[1585]: [error] Failed to merge JSON due to internal error: {"key":"","flags":"d99fn","result":{"boards":[{"mcuTemp":{},"vIn":{"current":0.4}}],"fans":[],"heat":{"heaters":[]},"inputs":[{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"}],"job":{"build":null,"duration":null,"filePosition":0,"layer":null,"layerTime":null,"pauseDuration":null,"timesLeft":{"filament":null,"file":null,"slicer":null},"warmUpDuration":null},"move":{"axes":[{"machinePosition":0,"userPosition":0},{"machinePosition":0,"userPosition":0},{"machinePosition":0,"userPosition":0}],"currentMove":{"acceleration":0,"deceleration":0,"laserPwm":null,"requestedSpeed":0,"topSpeed":0},"extruders":[],"virtualEPos":0},"sensors":{"analog":[],"endstops":[null,null,null],"filamentMonitors":[],"gpIn":[],"probes":[]},"seqs":{"boards":0,"directories":0,"fans":0,"global":0,"heat":0,"inputs":77,"job":1,"move":2,"network":2,"reply":0,"scanner":1,"sensors":0,"spindles":0,"state":0,"tools":0,"volChanges":[0,0],"volumes":0},"spindles":[{"current":0,"state":"unconfigured"},{"current":0,"state":"unconfigured"}],"state":{"atxPower":null,"currentTool":-1,"gpOut":[],"laserPwm":null,"msUpTime":101,"nextTool":-1,"previousTool":-1,"status":"off","time":"2021-04-13T20:58:38","upTime":83},"tools":[]},"next":0}
                        Apr 13 20:58:38 ender3 DuetControlServer[1585]:    System.InvalidOperationException: The requested operation requires an element of type 'Number', but the target element has type 'Array'.
                        Apr 13 20:58:38 ender3 DuetControlServer[1585]:    at System.Text.Json.JsonDocument.TryGetValue(Int32 index, Int32& value)
                        Apr 13 20:58:38 ender3 DuetControlServer[1585]:    at System.Text.Json.JsonElement.GetInt32()
                        Apr 13 20:58:38 ender3 DuetControlServer[1585]:    at DuetControlServer.Model.Updater.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 157
                        root@ender3 ~ # dpkg -l duetcontrolserver
                        Desired=Unknown/Install/Remove/Purge/Hold
                        | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
                        |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
                        ||/ Name              Version      Architecture Description
                        ii  duetcontrolserver 3.3-b2       armhf        Control server application for Duet 3 series
                        I was hoping to do another batch of small sequential prints with the new firmware
                        • Serbitarundefined
                          Serbitar
                          FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.3beta2+1 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2021-04-09 14:40:21
                          This is the first version that causes the DCS log spam
                          Serbitarundefined 1 Reply Last reply Reply Quote 0
                          • Serbitarundefined
                            Serbitar @Serbitar
                            Actually this is a bit weird. I just went through the remaining versions in sequence and 3.3b2+2 isn't spamming the logs.
                              @serbitar, I've updated the binary at https://www.dropbox.com/sh/0mwfe22wepk5efh/AAB6Lp0rwBPjVK2R4SxbKhLya?dl=0 to avoid DCS reporting those errors. The build time reported by M115 is now 21:29:10. The previous version was 18:55.
                              • Serbitarundefined
                                Serbitar @dc42
                                @dc42 said in Duet 3 Mini 5+ VIN under-voltage issues in SBC mode:
                                With the 18:55 version I had a print paused over night and the printer didn't have any VSSA or VIN troubles.
                                Print has now been resumed and will upgrade again later today after it finishes.
                                  dc42 administrators @Serbitar
                                  Thanks. I am 99% certain that my rewrite of the ADC driver has fixed this issue, so I will mark it as solved. Feel free to revert that if the problem recurs.
                                  For others who have experienced this issue, thanks for your patience. The fix is in the Duet3Firmware_Mini5plus.uf2 file at https://www.dropbox.com/sh/0mwfe22wepk5efh/AAB6Lp0rwBPjVK2R4SxbKhLya?dl=0. The 3.3beta3 release will include this fix.
                                  Serbitarundefined Fletcherundefined 2 Replies Last reply Reply Quote 3
                                  • Serbitarundefined
                                    Serbitar @dc42
                                    @dc42 Yep, looks good. No issues in the last 24h.
                                    Many thanks for sorting this out!
                                    • Fletcherundefined
                                      Fletcher @dc42
                                      @dc42 Running a print successfully as we speak, after 24hr with no issues. Thank you for your work sorting this out!
                                        droftarts administrators
                                        Many thanks to everyone who helped resolve this issue, for your patience, persistence and providing vital testing and feedback. I hope you didn’t waste too much filament!
