    Duet 3 Mini 5+ VIN under-voltage issues in SBC mode
    120
    7.0k
    • lodgerundefined
      lodger @dc42
      @dc42 Did MicroChip get back to you. Or is this all you and the teams hard work.....Just to say thank you really ..
      Paul
      • PaulHewundefined
        PaulHew @dc42
        @dc42 Just out of interest, what is the critical bit in our logs that assist you DC42?
        • PaulHewundefined
          PaulHew
          Undervotage.... Printer was idle.
          13/04/2021, 09:18:15 	m122
          RepRapFirmware for Duet 3 Mini 5+ version 3.3beta2+1 (2021-04-12 08:36:30) running on Duet 3 Mini5plus Ethernet (SBC mode)
          Board ID: A45XG-F396U-D65J0-40KML-1F03Z-H03XP
          Used output buffers: 1 of 40 (23 max)
          Static ram: 100072
          Dynamic ram: 91932 of which 0 recycled
          Never used RAM 51700, free system stack 172 words
          Tasks: Linux(resourceWait,119) HEAT(delaying,322) CanReceiv(notifyWait,774) CanSender(notifyWait,371) CanClock(delaying,340) TMC(notifyWait,99) MAIN(running,484) IDLE(ready,20) AIN(notifyWait,259)
          Owned mutexes: HTTP(MAIN)
          Last reset 12:02:11 ago, cause: software
          Last software reset at 2021-04-12 21:16, reason: User, none spinning, available RAM 51700, slot 2
          Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a
          Error status: 0x00
          Aux0 errors 0,0,0
          Aux1 errors 0,0,0
          MCU revision 3, ADC conversions started 51519632, completed 51519631, timed out 0, errs 3
          tnd=0 rnd=0 wrd=0 wtd=3 war=3
          Supply voltage: min 0.0, current 23.9, max 24.0, under voltage events: 1, over voltage events: 0, power good: yes
          Driver 0: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 82, reads 28663, writes 20, timeouts 51838, DMA errors 0, failedOp 0x6f
          Driver 1: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 82, reads 14925, writes 20, timeouts 40, DMA errors 0, failedOp 0x06
          Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 84, reads 14965, writes 20, timeouts 0, DMA errors 0
          Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 84, reads 14963, writes 20, timeouts 0, DMA errors 0
          Driver 4: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 84, reads 14965, writes 20, timeouts 0, DMA errors 0
          Driver 5: position 0, assumed not present
          Driver 6: position 0, assumed not present
          Date/time: 2021-04-13 09:18:16
          Slowest loop: 63.01ms; fastest: 0.10ms
          === Storage ===
          Free file entries: 10
          SD card 0 not detected, interface speed: 0.0MBytes/sec
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters = 0 -1, chamberHeaters = -1 -1
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty.
          === CAN ===
          Messages queued 389993, send timeouts 0, received 519973, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 500, free buffers 17 (min 16)
          === SBC interface ===
          State: 4, failed transfers: 0
          Last transfer: 4ms ago
          RX/TX seq numbers: 36429/36429
          SPI underruns 0, overruns 0
          Number of disconnects: 0, IAP RAM available 0x118a8
          Buffer RX/TX: 0/0-0
          === Duet Control Server ===
          Duet Control Server v3.2.2
          Code buffer space: 4096
          Full transfers per second: 35.63
          Maximum length of RX/TX data transfers: 3284/604
          12/04/2021, 23:04:48 	Warning: VIN under-voltage event (0.0V)
          • Fletcherundefined
            Fletcher @dc42
            @dc42 Another VSSA fault chain on the latest firmware:
            4/13/2021, 7:41:44 AM 	Error: VSSA fault, check thermistor wiring
            4/13/2021, 7:41:44 AM 	m122
            Board ID: FDQG2-Q296U-D65J0-40KMG-1K03Z-HXFTZ
            Used output buffers: 1 of 40 (12 max)
            Static ram: 100072
            Dynamic ram: 91764 of which 64 recycled
            Never used RAM 51804, free system stack 172 words
            Tasks: Linux(ready,137) HEAT(delaying,322) CanReceiv(notifyWait,774) CanSender(notifyWait,371) CanClock(delaying,340) TMC(notifyWait,99) MAIN(running,498) IDLE(ready,20) AIN(notifyWait,260)
            Last reset 23:27:06 ago, cause: software
            Last software reset at 2021-04-12 16:13, reason: User, none spinning, available RAM 51856, slot 1
            Error status: 0x00
            Aux0 errors 0,0,0
            Aux1 errors 0,0,0
            MCU revision 3, ADC conversions started 100481305, completed 100481304, timed out 0, errs 1
            tnd=0 rnd=0 wrd=0 wtd=1 war=1
            Supply voltage: min 0.0, current 0.1, max 24.4, under voltage events: 1, over voltage events: 0, power good: no
            Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 218, reads 4487, writes 11, timeouts 0, DMA errors 0
            Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 220, reads 4487, writes 11, timeouts 0, DMA errors 0
            Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 192, reads 4489, writes 9, timeouts 0, DMA errors 0
            Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 218, reads 4486, writes 11, timeouts 0, DMA errors 0
            Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 218, reads 4487, writes 11, timeouts 0, DMA errors 0
            Date/time: 2021-04-13 15:41:41
            Slowest loop: 57.18ms; fastest: 0.08ms
            === Storage ===
            === MainDDARing ===
            === AuxDDARing ===
            Segments left: 0
            === CAN ===
            Messages queued 759838, send timeouts 0, received 1013078, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 354, free buffers 17 (min 16)
            RX/TX seq numbers: 14877/14877
            Buffer RX/TX: 0/0-0
            Duet Control Server v3.3-b2
            Full transfers per second: 35.89
            Codes per second: 0.00
            Maximum length of RX/TX data transfers: 3044/804
            4/13/2021, 7:41:39 AM 	Error: VSSA fault, check thermistor wiring
            It was stable for almost 24 hours, which is positive change, at least! Thank you for all the work you're putting in on this issue.
              dc42 administrators @Fletcher
              All, please try the new firmware at https://www.dropbox.com/sh/0mwfe22wepk5efh/AAB6Lp0rwBPjVK2R4SxbKhLya?dl=0. M115 reports it as 3.2beta2+2.
              This version avoids using the ADC DMA sequencer completely, so I am hopeful that it will solve the problem. I was worried that the additional ADC interrupt load would be excessive, but with careful code optimisation I have got it down to 0.5% of total CPU time.
              Serbitarundefined 1 Reply Last reply Reply Quote 2
              • Serbitarundefined
                Serbitar @dc42
                @dc42 Looks like this version (and probably the other recent ones) breaks duetcontrolserver.
                With 3.3b2 the logs are nice and quiet, with 3.3b2+2 the duetcontrolserver log is a fast rolling spam like this:
                Apr 13 20:58:38 ender3 DuetControlServer[1585]: [error] Failed to merge JSON due to internal error: {"key":"","flags":"d99fn","result":{"boards":[{"mcuTemp":{},"vIn":{"current":0.4}}],"fans":[],"heat":{"heaters":[]},"inputs":[{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"}],"job":{"build":null,"duration":null,"filePosition":0,"layer":null,"layerTime":null,"pauseDuration":null,"timesLeft":{"filament":null,"file":null,"slicer":null},"warmUpDuration":null},"move":{"axes":[{"machinePosition":0,"userPosition":0},{"machinePosition":0,"userPosition":0},{"machinePosition":0,"userPosition":0}],"currentMove":{"acceleration":0,"deceleration":0,"laserPwm":null,"requestedSpeed":0,"topSpeed":0},"extruders":[],"virtualEPos":0},"sensors":{"analog":[],"endstops":[null,null,null],"filamentMonitors":[],"gpIn":[],"probes":[]},"seqs":{"boards":0,"directories":0,"fans":0,"global":0,"heat":0,"inputs":77,"job":1,"move":2,"network":2,"reply":0,"scanner":1,"sensors":0,"spindles":0,"state":0,"tools":0,"volChanges":[0,0],"volumes":0},"spindles":[{"current":0,"state":"unconfigured"},{"current":0,"state":"unconfigured"}],"state":{"atxPower":null,"currentTool":-1,"gpOut":[],"laserPwm":null,"msUpTime":101,"nextTool":-1,"previousTool":-1,"status":"off","time":"2021-04-13T20:58:38","upTime":83},"tools":[]},"next":0}
                Apr 13 20:58:38 ender3 DuetControlServer[1585]:    System.InvalidOperationException: The requested operation requires an element of type 'Number', but the target element has type 'Array'.
                Apr 13 20:58:38 ender3 DuetControlServer[1585]:    at System.Text.Json.JsonDocument.TryGetValue(Int32 index, Int32& value)
                Apr 13 20:58:38 ender3 DuetControlServer[1585]:    at System.Text.Json.JsonElement.GetInt32()
                Apr 13 20:58:38 ender3 DuetControlServer[1585]:    at DuetControlServer.Model.Updater.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 157
                root@ender3 ~ # dpkg -l duetcontrolserver
                Desired=Unknown/Install/Remove/Purge/Hold
                | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
                |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
                ||/ Name              Version      Architecture Description
                ii  duetcontrolserver 3.3-b2       armhf        Control server application for Duet 3 series
                I was hoping to do another batch of small sequential prints with the new firmware
                • Serbitarundefined
                  Serbitar
                  FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.3beta2+1 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2021-04-09 14:40:21
                  This is the first version that causes the DCS log spam
                  Serbitarundefined 1 Reply Last reply Reply Quote 0
                  • Serbitarundefined
                    Serbitar @Serbitar
                    Actually this is a bit weird. I just went through the remaining versions in sequence and 3.3b2+2 isn't spamming the logs.
                      @serbitar, I've updated the binary at https://www.dropbox.com/sh/0mwfe22wepk5efh/AAB6Lp0rwBPjVK2R4SxbKhLya?dl=0 to avoid DCS reporting those errors. The build time reported by M115 is now 21:29:10. The previous version was 18:55.
                      • Serbitarundefined
                        Serbitar @dc42
                        @dc42 said in Duet 3 Mini 5+ VIN under-voltage issues in SBC mode:
                        With the 18:55 version I had a print paused over night and the printer didn't have any VSSA or VIN troubles.
                        Print has now been resumed and will upgrade again later today after it finishes.
                          dc42 administrators @Serbitar
                          Thanks. I am 99% certain that my rewrite of the ADC driver has fixed this issue, so I will mark it as solved. Feel free to revert that if the problem recurs.
                          For others who have experienced this issue, thanks for your patience. The fix is in the Duet3Firmware_Mini5plus.uf2 file at https://www.dropbox.com/sh/0mwfe22wepk5efh/AAB6Lp0rwBPjVK2R4SxbKhLya?dl=0. The 3.3beta3 release will include this fix.
                          Serbitarundefined Fletcherundefined 2 Replies Last reply Reply Quote 3
                          • Serbitarundefined
                            Serbitar @dc42
                            @dc42 Yep, looks good. No issues in the last 24h.
                            Many thanks for sorting this out!
                            • Fletcherundefined
                              Fletcher @dc42
                              @dc42 Running a print successfully as we speak, after 24hr with no issues. Thank you for your work sorting this out!
                                droftarts administrators
                                Many thanks to everyone who helped resolve this issue, for your patience, persistence and providing vital testing and feedback. I hope you didn’t waste too much filament!
