Fan confusiom
M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency ;M106 P0 S0 ; ************************ ; set fan 0 value . ;M950 F2 C"nil" ; free up fan2 connector so it is no longer assinged to fan 2 ;M950 F1 C"fan2" Q500 ; create fan 1 on pin fan2 and set its frequency M106 P0 S1.0 H1 T45 ; set fan 1 value. Thermostatic control is turned on. This fan turns on if heater1 is over 45 degrees M950 F8 C"duex.fan8" ; declare fan 8 on the duex card - this is the fan output used for the automatic bed lights M106 P8 S1 H1 T45 ; lights are turned on automatically when nozzle 1 is over 45C M563 S"Nozzle 0" P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0
You're defining a fan0 and fan8. and you have fan0 as thermostatic but also bound to tool0 as the part fan. So which is it supposed to be?
@phaedrux, Fan8 is to turn on some LED lights ... and they work exactly as expected. I am not following the double assignment stuff.
I define fan0 with M950
then 3 lines of commented out code
then I set fan 0 as thermostatically controlled
Is fan 0 the fan that cools the hot end?
What I want is for that fan to come on when the hot end reaches 45 degrees -
Ah, I see where fan 0 is assigned as tool fan in the M563 command.
So if I wanted a thermostatically controlled hot end fan and also a tool fan (ie two separate fans), what should my config.g say ? -
If fan0 is the hotend heatsink fan, then having it thermostatically controlled as you have it now is fine.
BUT then you also need a different fan that isn't thermostatically controlled defined and it needs to be mapped in the M563 tool definition.
You don't currently have a part cooling fan defined at all.
If you have a part cooling fan, what port is it connected to?
@phaedrux, thanks for all your help but I think I am getting myself more and more in trouble as I mess around with config.g. I think it's time to call it a day and start fresh tomorrow after a good nights sleep.
At this point I would settle for somebodies config,g's fan section if you are set up for a single hotend with a thermostatically controlled hot end fan and a standard part cooling fan.
That's easy enough but we need to know what fan port you will use for the part cooling fan
@phaedrux, I am using the third PWM port on the Duet2 wifi board which would be fan2. Fan1 has a dead mosfet and fan0 is used as the hotend cooling fan.
Thanks!
Now fan2 might also be blown but I do not know this for a fact. The last bit of experimenting has none of the PWM fans working
Both fans were tested against the always on fan outputs and are working. -
So I have a sort-of working version:
M106 P0 S1 H1 T45 ; set fan 1 value and Thermostatic control .
M106 P8 S1 H1 T45 ; lights are turned on automatically when nozzle 1 is over 45C; Tools
M563 S"Nozzle 0" P0 D0 H1 F1 ; define tool 0
What I have is the hot end fan and the lights acting like expected. The part cooling fan is not working but that is possibly a blown mosfet. Last but not least, the web interface lists 3 fans when I expect to see only one. It lists the 'tool fan', 'fan 1' and 'fan 2'.
Since the hot end fan is thermostatically controlled, I do not expect it to show up on the web interface. Since fan 2 was declared as 'nil' and fan 1 was assigned to the fan 2 port, I expect to see only 'fan 0'.
Why am I seeing 3 fan listings ? -
@jens55 i dont think M950 F2 C"nil" is required and thats probably adding to one fan.
The tool fan is the part cooling fan of the current tool. This can be hidden -
@jay_s_uk, the M950 F2 C"nil" is specifically needed to reassign fan connector two to be used as fan connector one.
As per gcode reference:
C"name" Pin name(s) and optional inversion status, see Pin Names. Pin name "nil" frees up the pin. A leading '!' character inverts the input or output. A leading '^' character enables the pullup resistor. The '^' and '!' characters may be placed in either order.The pin needs to be freed up in order to assign it to fan1
I suppose one could specifically assign fan2 to heater 1 but for some reason or another that wasn't done on original setup and I didn't feel it necessary to redo more than what was absolutely necessary (and even then I got into trouble)
@jens55 nothing is preassigned in newer firmware
Nil is only required now when you want to alter an existing definition. In RRF 3.1 and later there are no pre-defined assignments anymore. So you don't need to use Nil unless you've already defined a pin and want to re-assign it to something else.
Here's my fan setup as an example.
; Fans M950 F0 C"fan0" Q100 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 B0.5 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q1000 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 B0.5 ; set fan 1 value. Thermostatic control is turned on M950 F2 C"fan2" Q15000 ; create fan 2 on pin fan2 and set its frequency M106 P2 S0.33 H1:0 T45 B0.5 ; Tools M563 P0 S"Titan Aero" D0 H1 F0
Let's modify it to use the fan headers you are using and add fan2 as a part cooling fan for tool0.
M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S1.0 H1 T45 ; set fan 1 value. Thermostatic control is turned on. This fan turns on if heater1 is over 45 degrees M950 F8 C"duex.fan8" ; declare fan 8 on the duex card - this is the fan output used for the automatic bed lights M106 P8 S1 H1 T45 ; lights are turned on automatically when nozzle 1 is over 45C M950 F1 C"fan2" Q100 ; create fan 1 on pin fan2 and set its frequency M106 P1 S0 H-1 B0.5 ; set fan 1 value. Thermostatic control is turned off M563 S"Nozzle 0" P0 D0 H1 F1 ; define tool 0
It creates fan1 on the fan2 port and assigns it to tool0.
@phaedrux, thanks for the configuration example and thanks for confirming jay_s_uk's comment about the "nil" line not being necessary any more.
I replaced the Duet2Wifi board this morning and it did indeed have two of the PWM fan output ports blown up.
I am currently struggling with getting the new board on line and I will test things after that. It looks like the config file I came up with last night is the same as your suggestion so that looks promising.
More when I have things going again.
Things are looking good except for the 'Fan control' section of the DWC.
I show two fans - 'Tool Fan' and 'Fan 1'. Both selections control the single fan that cools the printed model.
I have removed the fan8 (lights) stuff in case it generated that second fan entry.Any suggestions on what might cause this second phantom entry?
It's not a phantom entry, it's the same fan.
The "tool fan" slider will control the fan of the currently selected tool. So if you had two tools with different fans it would control the fan of the selected tool.
If you only have a single tool, there's only one fan to control and it is a duplicate. You can use the "change visibility" button there to hide it if you wish.
Oh, go figure ..... I never noticed that before .... learn something new every day
Where would I find the visibility selector?Thanks again for all help from both jay_s_uk and Phaedrux!
The change visibility slider is only present on one of the pages that shows the fan sliders. The one that's on the right side. Sorry I can't recall which page that is though at the moment. Status or dashboard. It's been requested to add it to both places.
