    Heaters problem
    1.3k
    • erwalyundefined
      erwaly
      I got a 24v 15A 360W power supply and not use external mosfet is conect to board.
        Phaedrux Moderator @erwaly
        @erwaly said in Heaters problem:
        Can i use the pwm fz in Q1
        Yes I think so. I think I've used it in the past to stop the pot lights from flickering. Give it a try.
        The video definitely shows more audible clicking that I would expect. But maybe my noise floor is a lot higher and I just never noticed before.
          After doing a heating of the bed can you send M122 in the gcode console and post the results here please?
          erwalyundefined 1 Reply Last reply Reply Quote 0
            Mosfets do not normally make any noise, so I suspect the noise is coming from somewhere else, e.g. the PSU, or the bed heater itself.
            erwalyundefined 2 Replies Last reply Reply Quote 0
            • erwalyundefined
              erwaly @Phaedrux
              @Phaedrux yes i send m122 when the bed is to 60° degrees that show me:
              M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
              Board ID: 08DGM-9T6BU-FG3S8-6J1F8-3S86Q-1BKZF
              Used output buffers: 3 of 24 (12 max)
              Static ram: 23460
              Dynamic ram: 73404 of which 32 recycled
              Never used RAM 15184, free system stack 182 words
              Tasks: NETWORK(ready,182) HEAT(blocked,294) MAIN(running,449) IDLE(ready,20)
              Owned mutexes:
              Last reset 00:05:05 ago, cause: power up
              Last software reset at 2021-03-23 19:50, reason: User, GCodes spinning, available RAM 15184, slot 2
              Error status: 0x00
              Aux0 errors 0,0,0
              MCU temperature: min 26.9, current 37.4, max 37.5
              Supply voltage: min 23.9, current 24.7, max 25.1, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 0: position 0, standstill, SG min/max not available
              Driver 1: position 0, standstill, SG min/max not available
              Driver 2: position 0, standstill, SG min/max not available
              Driver 3: position 0, standstill, SG min/max not available
              Driver 4: position 0, standstill, SG min/max not available
              Driver 5: position 0
              Driver 6: position 0
              Driver 7: position 0
              Driver 8: position 0
              Driver 9: position 0
              Driver 10: position 0
              Driver 11: position 0
              Date/time: 2021-03-23 23:01:32
              Cache data hit count 370524343
              Slowest loop: 154.06ms; fastest: 0.21ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 1.7ms, write time 0.0ms, max retries 0
              === MainDDARing ===
              === AuxDDARing ===
              Heater 0 is on, I-accum = 0.0
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 15.70ms; fastest: 0.00ms
              Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
              HTTP sessions: 1 of 8
              • WiFi -
                Network state is active
                WiFi firmware version 1.25
                WiFi MAC address cc:50:e3:14:a8:92
                WiFi Vcc 3.38, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 24952
                WiFi IP address 192.168.1.85
                WiFi signal strength -75dBm, mode 802.11n, reconnections 0, sleep mode modem
                Clock register 00002002
              • erwalyundefined
                erwaly @dc42
                @dc42 maybe is the power supply tomorrow can i try other one, and i don't think is the hotbed because whit the hotend have same problem. And today i changed the thermistor and wires from the bed for new ones to try and nothing I got same problem.when I'll try the power supply i say it here, thanks for yours attention.
                • erwalyundefined
                  erwaly @dc42
                  @dc42 I tryed other power supply today the same one 24v 15a 360w, and when heating it the bed,in the new power supply is burned to 160ohm resistance... I so strange because the first one don't have nothing burned and work fine just the sound...i buy a new hotend for extruder a new hotbed, tomorrow i try the extruder, the bed is take more time to come, but a say anything here when i change it. Thanks for their help.
                  erwalyundefined 1 Reply Last reply Reply Quote 1
                  • erwalyundefined
                    erwaly @erwaly
                    @erwaly finally i get a new bed and new hotend, i got a logistics problem whit the send and coming today, i try whit new bed, new thermistor,new wires and different power supply and i have the same problem. Whit the new power supply is less sound but can listen it... I think maybe can is a bad update, i don't remember whit what firmware comes not sure but maybe 1.21 or 2.02 i buy it on 2019 but never use before. I want to downgrade the software and new upgrade, what is the best firmware to start? From 2.0 and up or better from 1. 21 and up
                      I'm not sure what you mean. Did you have firmware 3.2.2 running as shown in your M122 above?
                      • erwalyundefined
                        erwaly @Phaedrux
                        @phaedrux yes i have 3.2.2 now but i want reinstall and new update, what is the best software to start ne install from 0... 2.00 or 1.21,or 3??i think maybe i don't install one file from old updates.
                          I really don't understand what you're asking. What are you trying to accomplish?
                          • erwalyundefined
                            erwaly @Phaedrux
                            @phaedrux I think that when I updated my motherboard I made a mistake and some version did not install well. I want to do a clean installation by deleting everything with bossa and installing the board from 0, the thing is which is the best version to install and update, or do I directly load the 3.2.2 again?
                              Ah ok. Well if you have access to the board via usb terminal or DWC currently working you can check the installed firmware with M122 or M115. If it's 3.2.2, you're good to go.
                              If you want to reinstalled everything and you have access to DWC you can just upload the full zip file for 3.2.2.
                              https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
                              If you don't have access to DWC and you want to reinstall the firmware with BOSSA use the combined firmware file from that same zip file.
                              https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2CombinedFirmware.bin
                              And put the DWC files from this zip file into the /www folder manually.
                              https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/DuetWebControl-SD.zip
                              • erwalyundefined
                                erwaly @Phaedrux
                                @phaedrux If I have access via web and usb that is not the problem, the question is if I erase the board and install 3.2.2, that version has all the necessary files or should I first update to 3 and then 3.1 ... to 3.2.2
                                  If you're using bossa to flash the board you only need the version you intend to use. After you're up and running though it's probably a good idea to upload the zip file release via the web interface to that all of the other IAP files are present for the next time you want to update the firmware.
                                  In general, if you already have DWC running, just use the zip file upload method.
                                  • erwalyundefined
                                    erwaly @Phaedrux
                                    @phaedrux So update ok, reinstall by bossa and upload the files to the sd. Really everything works well, it is only when heating the bed or the hotend the power supply beeps as I showed in the videos, I already tried to change everything, I even tried 2 sources and the problem continues, I only have to try another plate ... I don't know what can be failing, change cables, thermistor, hotend, complete bed, 3 different power supplies and keep beeping when it reaches the indicated temperature.
                                      Can you identify by ear where the noise is coming from?
                                      • erwalyundefined
                                        erwaly @Phaedrux
                                        @phaedrux yes the sound is made by the power supply when the bed mosfet or the hotend cuts and opens, I have tried 3 different power supplies and the sound does it with all 3.
                                          What brand of power supply?
                                          • erwalyundefined
                                            erwaly @Phaedrux
                                            @phaedrux one is Creality 3D DC 24V 15A 360W, the other two are Chinese from amazon NEWSTYLE DC 24V 15A 360W
