    DueUI Release v3.2.5-beta4 is Now Available
    DueUI
    2.0k
    • gtj0undefined
      gtj0
      v3.2.5-beta4
      https://github.com/gtjoseph/DueUI/releases/tag/v3.2.5-beta4
      https://github.com/gtjoseph/DueUI/wiki
      Changes since v3.2.5-beta3
      Loader fixes:
      • Fixed issue with blank password with standalone Duets.
      • Theme names are now properly taken from config files.
      v3.2.5-beta3
      https://github.com/gtjoseph/DueUI/releases/tag/v3.2.5-beta3
      Changes since v3.2.5-beta2
      • Addressed issues with config precedence
        • The whole "sessionStorage" thing was too complicated and I've removed it.
        • Settings are only saved if you click the "Save" button.
        • A new "Save" button was added to the menubar.
        • The save buttons now change color when a setting is changed to remind you to save them.
        • The underlying configuration precedence stuff was changed to handle a wider variety of cases.
      v3.2.5-beta2
      I'm disavowing all knowledge of v3.2.5-beta1 🙂 This release cleans up old installs of DueUI automatically.
      Download: https://github.com/gtjoseph/DueUI/releases/download/v3.2.5-beta2/DueUI-v3.2.5-beta2.zip
      Wiki: https://github.com/gtjoseph/DueUI/wiki
      Pay particular attention to Settings: https://github.com/gtjoseph/DueUI/wiki/Settings
      • Breaking Changes:
        • This was true for the DueUI 3.2.0 release but I'm going to reiterate...You MUST be running a Duet board or Duet Software Framework installation at release 3.1.0 or higher. There were simply too many object model differences between DSF and Standalone installations and I couldn't keep up with them.
        • If you stored your DueUI settings in your dueui_config.json file, the syntax has changed slightly. Instead of declaring the settings as a class class DueUISettings {, they're now declared as an object: configFileSettings = {. See the new default config for exact syntax. Other than this change, a configuration that worked in the previous version should still work as long as it was compatible with RRF 3.1.
        • The theme setting has been replaced by theme_name and theme_path. If you want to use one of the standard themes, you can just specify its name in theme_name and don't specify theme_path. For instance theme_path: "Darkly". If you want to use an external bootstrap theme, you can provide the full URL to the css file in theme_path.
        • I'm no longer going to host a DueUI installation at dueui.org. It's just too much trouble to maintain.
      • Enhancements:
        • There are no longer separate downloads and default configuration files for DSF vs Standalone installations. The same zip download and default configuration will work for both types of installations.
        • You no longer have to choose between DSF and Standalone installation types in Settings. It's autodetected.
        • There is now only one poll interval setting when operating in a Standalone installation. With recent changes made to RRF, the other poll intervals are no longer needed.
        • Settings changes are now automatically saved to the browser's tab-specific "sessionStorage". This allows you to reload the tab while preserving any settings changes you've made. The changes are discarded when you close the tab. If you want to save them across browser restarts or or tab closures, click the "Save" button as you did previously.
        • The underlying JavaScript and CSS files have been reorganized to make loading from standalone devices less resource intensive. I was noticing that sometimes the pages weren't rendering and realized that the Duet had too many connections open to service the requests.
        • An "alt" property was added to the image widget to allow setting alternate text to be displayed if the image or stream can't be loaded.
      • Behind The Scenes
        • There was a lot of refactoring done to the connection and polling code that should make it more reliable (and easier to maintain for me).
      Please open a separate topic for any issues.
      • gtj0undefined
        gtj0 @gtj0
        @stuartofmt Have you had a chance to try this version out?
        • thweundefined
          thwe
          I updated from 3.0.2 and now the browser can no longer find the config.
          After pointing to my printer, in my case http://192.168.178.29/dueui.html got the error
          and then
          then come to the page
          After Save and Refresh get always the same errors from my browsers (Firefox, GoogleChrome, Edge)
          This is my electronic:
          and my files on /sys:
          After backup to the old version everything works fine, please help.
          Thomas
          stuartofmtundefined 1 Reply Last reply Reply Quote 0
          • stuartofmtundefined
            stuartofmt @thwe
            @thwe
            There are still some residual bugs around the configurations that @gtj0 is working on. It does recognise (completely) the configFileSettings
            If you want to use this beta version: Commented out the configFileSettings and instead, invoked from a url for example (from my setup with your values):
            localhost:8080/dueui.html?dueui_config_url=http://localhost:8080/dueui_config_thwe.json&theme=Darkly&duet_host=192.168.178.29&duet_polling_enabled=1
            The form of the url paths may be slightly different depending on where you are running dueui.
            gtj0undefined thweundefined 2 Replies Last reply Reply Quote 0
            • gtj0undefined
              gtj0 @stuartofmt
              @stuartofmt @thwe Yep. I'm working on them. Should have a release up tomorrow evening (GMT -06:00).
              • thweundefined
                thwe @stuartofmt
                @stuartofmt
                thanks for your support, but unfortunately it still does not work.
                I have used the following in the browser:
                http://192.168.178.29/dueui.html?dueui_config_url=http://192.168.178.29/dueui_config_default.json&theme=Darkly&duet_host=192.168.178.29&duet_polling_enabled=1
                http://192.168.178.29/dueui.html?dueui_config_url=http://192.168.178.29/dueui_config_default.json&theme=Darkly&duet_host=192.168.178.29&duet_polling_enabled=0
                and no matter if I call with the original config or with my modified one, I always get the message:
                Will wait for the next release.
                Thomas
                stuartofmtundefined gtj0undefined 2 Replies Last reply Reply Quote 0
                  stuartofmt @thwe
                  @thwe said in DueUI Release v3.2.5-beta3 is Now Available:
                  It looks like you are installing Dueui on your Duet (Standalone). Yes?
                  In which case the form of the url is different. See the link here:
                  Not the way I'm set up but its something like this:
                  http://192.168.178.29/dueui.html?dueui_config_url=dueui_config_default.json&theme=Darkly&duet_polling_enabled=1
                  It might be best to wait for the next beta release.
                  In any case and to help in the future. Here is what I do when using the full url approach installing Dueui on a separate http server:
                  1. Make sure the configFileSettings are commented out:
                   configFileSettings
                  <snip>
                  1. Make sure the browser is clean i.e. delete history cookies etc.
                  2. Make sure the duet code is in the root of the http server (i.e. not in a sub-directory)
                  http root
                                 dueui.html
                                 configfile.json
                                 etc.
                               /css
                               /js
                               ​/fonts
                  This last point I have found can be an issue with Dueui not being able to find the config file (for example when everything dueui is in its own subdirectory off the http root).
                  Also - you need polling_enabled=1 otherwise Dueui will not "talk" to duet_host.
                  thweundefined 1 Reply Last reply Reply Quote 0
                  • gtj0undefined
                    gtj0 @thwe
                    @thwe Actually, on a standalone Duet with with the default config, the url should just be
                    http://192.168.178.29/dueui.html?theme_name=Darkly&duet_polling_enabled=1
                    Note that "theme" has changed to "theme_name".
                    That should work.
                    The reason it didn't is that if you use a full URL for the config file it has to be in the form the server understands. In standalone mode, the Duet web server requires the file be in the form
                    dueui_config_url=http://<your_duet>/rr_download?name=/sys/dueui_config_default.json
                    If the config file is on the Duet itself, you don't need to use the full URL. Just use...
                    dueui_config_url=/sys/dueui_config_default.json
                    DueUI adjusts that internally so that's portable across all Duets and the DSF.
                    I'm still working on the next beta. I think it'll be today.
                    • thweundefined
                      thwe @stuartofmt
                      @stuartofmt said in DueUI Release v3.2.5-beta3 is Now Available:
                      correctly
                      @gtj0 said in DueUI Release v3.2.5-beta3 is Now Available:
                      That should work.
                      With this call and with the original config I get the same error again "
                      After canceling the browser data get:
                      "No config file was found at ' 'http://192.168.178.29/dueui_config_default.json'"
                      Thomas
                      • gtj0undefined
                        gtj0 @thwe
                        @thwe OK, I'll get it figured out.
                        If you could...
                        • Open the debugger by right clicking anywhere in the main window and then clicking on "Inspect" or "Inspect element".
                        • Click on the "Console" tab in the debugger window
                        • Recreate the problem
                        • Save the console log to a file
                          • For Chrome based browsers, right click anywhere in the Console tab and select "Save As".
                          • For Firefox, right click on a log message and select "Save visible messages to..."
                        • Attach the resulting log here.
                        • thweundefined
                          thwe @gtj0
                          @gtj0
                          i hope that the following ist correct - never done something 🙄
                          1. clear browser cache and data
                          2. open: http://192.168.178.29/dueui.html?theme_name=Darkly&duet_polling_enabled=1
                          dueui-loader.js:360 Initializing
                          dueui-loader.js:367 {localSettings: {…}}
                          dueui-loader.js:379 {queryParams: {…}}
                          dueui-loader.js:309 Testing http://192.168.178.29 as Standalone
                          dueui-loader.js:124 GET http://192.168.178.29/rr_connect 500 (Unknown request)
                          tryFetch @ dueui-loader.js:124
                          isStandalone @ dueui-loader.js:310
                          getHostBackendType @ dueui-loader.js:337
                          dueui_loader @ dueui-loader.js:388
                          (anonymous) @ dueui-loader.js:500
                          dueui-loader.js:318 http://192.168.178.29 not Standalone: (500) Unknown request
                          dueui-loader.js:323 Testing http://192.168.178.29 as DSF
                          dueui-loader.js:124 GET http://192.168.178.29/machine/file/sys/config.g 404 (page not found<br>Check that the SD card is mounted and has the correct files in its /www folder)
                          isDSF @ dueui-loader.js:324
                          getHostBackendType @ dueui-loader.js:340
                          async function (async)
                          dueui-loader.js:332 http://192.168.178.29 not DSF: (404) page not found<br>Check that the SD card is mounted and has the correct files in its /www folder
                          dueui-loader.js:391 192.168.178.29 is UNKNOWN: (undefined) undefined
                          dueui-loader.js:396 Starting with config_url: dueui_config_default.json
                          dueui-loader.js:410 192.168.178.29 is not a Duet or DSF
                          dueui-loader.js:427 Trying: 'http://192.168.178.29/dueui_config_default.json'
                          DevTools failed to load SourceMap: Could not load content for http://192.168.178.29/js/bootstrap.bundle.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                          dueui-loader.js:124 GET http://192.168.178.29/dueui_config_default.json 404 (page not found<br>Check that the SD card is mounted and has the correct files in its /www folder)
                          dueui_loader @ dueui-loader.js:429
                          dueui-loader.js:439 No config file was found at ' 'http://192.168.178.29/dueui_config_default.json'
                          dueui-loader.js:476 No config file found
                          dueui-loader.js:314 http://192.168.178.29 is Standalone
                          dueui-loader.js:304 Loading theme Darkly from css/dueui-Cerulean.theme.min.css.gz
                          dueui-bundle.js:93 Unknown backend.  Showing settings
                          dueui-bundle.js:1492 S.Event {type: "dueui-setting-change", timeStamp: 1618929258576, jQuery360016537159328505102: true, isTrigger: 3, namespace: "", …} {name: "duet_password", value: "reprap"}
                          dueui-bundle.js:1492 S.Event {type: "dueui-setting-change", timeStamp: 1618929258583, jQuery360016537159328505102: true, isTrigger: 3, namespace: "", …} {name: "dueui_config_url", value: "dueui_config_default.json"}
                          dueui-bundle.js:1492 S.Event {type: "dueui-setting-change", timeStamp: 1618929258597, jQuery360016537159328505102: true, isTrigger: 3, namespace: "", …} {name: "duet_debug_polling_enabled", value: 0}
                          dueui-bundle.js:1492 S.Event {type: "dueui-setting-change", timeStamp: 1618929258599, jQuery360016537159328505102: true, isTrigger: 3, namespace: "", …} {name: "dueui_settings_dont_send_gcode", value: 0}
                          dueui-bundle.js:1492 S.Event {type: "dueui-setting-change", timeStamp: 1618929258602, jQuery360016537159328505102: true, isTrigger: 3, namespace: "", …} {name: "dueui_test_mode", value: 0}
                          dueui-bundle.js:1492 S.Event {type: "dueui-setting-change", timeStamp: 1618929258604, jQuery360016537159328505102: true, isTrigger: 3, namespace: "", …} {name: "duet_polling_enabled", value: 1}
                          DevTools failed to load SourceMap: Could not load content for http://192.168.178.29/bootstrap.min.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                          Thomas
                          • gtj0undefined
                            gtj0 @thwe
                            @thwe Yeah that was perfect. It's the same issue that's already been reported. What's happening is that for some reason, the password is blank but the Duet still requires the parameter to be sent even if its blank.
                            I'm working on it still.
                            • gtj0undefined
                              gtj0 @gtj0
                              @stuartofmt @thwe I think I've got everything fixed. Sorry for the delay.
                              • thweundefined
                                thwe
                                Installed v3.2.5-beta4 via DWC -> File -> System -> UPLOAD SYSTEM FILE
                                1. google chrome + firefox: clear browser cache and data
                                3. get the same error: "Could not connect to 192.168.178.29 or retrieve any config files"
                                Debugger Log's:
                                Firefox: console-export-2021-4-26_18-23-44.txt
                                Google Chrome: 192.168.178.29-1619455172710.txt
                                get then
                                after click "OK"
                                Thomas
                                • gtj0undefined
                                  gtj0 @thwe
                                  @thwe Well, at least it found the config file. 🙂
                                  Unfortunately, I just realized which version of RRF you're running.
                                  https://github.com/gtjoseph/DueUI/releases/tag/v3.2.5-beta2
                                  has a note in "Breaking Changes" ...
                                  I should have caught this earlier, sorry.
                                  Ther bottom line is that you should stick with the current 3.0.2 until you can upgrade RRF.
                                  • gtj0undefined
                                    gtj0
                                    @stuartofmt Had a chance to try beta4 yet?
