    Using Marlin Output for OctoPrint
    1.1k
    • thomaspjundefined
      thomaspj
      I set the Duet Ethernet to do Marlin output which was successful in connecting to octoprint but It only sends back the bed temperature and not both the bed and Hotend. Does anyone know why and how I could fix this? Thanks
        You need to select a tool, for example by sending the T0 command. Otherwise RRF doesn't know which hotend you wanted.
          T3P3Tony administrators
          You can put T0 at the end of config.g if you always want to startup with a tool selected.
          • thomaspjundefined
            thomaspj
            @dc42:
            I tried that using T0 through T3 and they all returned only the Bed temp
            • fcwiltundefined
              fcwilt
              @thomaspj:
              Given the first rate web interface the Duet firmware provides why do you need/want OctoPrint?
                @thomaspj:
                @dc42:
                Perhaps there is some subtle difference between what RRF and Marlin return in response to a M105 command. Do you know what Octoprint expects?
                • weputundefined
                  weput
                  @fcwilt:
                  @thomaspj:
                  Im used to send stuff from slic3r directly to octoprint… and i really miss that feature.
