    Duex 5 fan short
    345
    • lopuundefined
      lopu
      I have accidentaly shorted one of the fan outputs. Connected steppers don´t work, did i just fried all the stepper drivers or some mosfet or cap ? Only thing connected that works is Bl touch.
      Thanks for any help.
      lopuundefined 1 Reply Last reply Reply Quote 0
      • lopuundefined
        lopu @lopu
        @lopu After connecting to USB and running for few seconds there is big source of heat from direction of chip U8 (SX1509B according to schematics from github)
          Are you talking about the main duet board or the duex?
          Take a look here to see how far you can get.
          https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
          Other than the hot U8 do you see any other visible damage on components?
          • lopuundefined
            lopu @Phaedrux
            @phaedrux
            1. only the duex steppers dont work
            2. The duet 2 is responding when connected to the USB and gets recognized in the device manager in COMs
            3. only visible damage is one of the pins is melted but no chip is visibly cracked or damaged in any other way 20210418_193724.jpg
              Can you get a clear close up shot of the board?
              • lopuundefined
                lopu @Phaedrux
                Of this area or the whole board ?
                  The more pictures the better chance we can spot something.
                  • lopuundefined
                    lopu @Phaedrux
                    20210418_195115.jpg 20210418_195223.jpg 20210418_195245.jpg 20210418_195419.jpg 20210418_195426.jpg 20210418_195423.jpg
                    If you need more pictures let me know
                    • jens55undefined
                      jens55
                      TR6 looks discoloured
                      lopuundefined 1 Reply Last reply Reply Quote 1
                      • lopuundefined
                        lopu @jens55
                        @jens55 I just marked it with sharpie as i expected it to be dead before i marked it, it had the same colour as the rest.
