Solved Wifi error
oh my bad your right
@dc42 I'm gonna bother you again I've uploaded my configs files but at startup the board wifi is off and I need to send a M552 S1 command, even after setting the network to enabled ? Oh and also I connected the paneldue it's just white, I've tried with the 4pin and the sd card cables. It's also enabled in the config tool.
Do you have M552 S1 in your config.g?
Try flashing the PanelDue firmware.
@Phaedrux flashed the firmware screen is inverted horizontally and vertically , also weirdly yellow... The wifi problem is gone, flashed another firmware this one probably included M552 S1. I'm printing a benchy right now but it is really slow, peak speed is about 12mm/s where it should be like 40-50 trusting G-code analyser, any setting that could be involved ?
For the PanelDue screen orientation there are some settings you can change in the settings page on the panel.
Weirdly yellow? Can you post a photo? How do you have it wired now?
M552 S1 needs to be in config.g for it to enable the wifi module at start regardless of firmware.
Can you copy and paste the text of the results of sending M122 and M98 P"config.g" from the gcode console?
Also post the entire contents of config.g and you slicer start gcode. That may give a clue on what's going on with the speed.
Here's the screen right now it's connected with the 4 pin but the SD one gives similar results
Sorry I didn't meant firmware I meant config, I changed the config with the online tool so I have a M552 S1.
M122:
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
Board ID: 0JD0M-9P6B2-NJ4S4-6JKFG-3S46S-1V02L
Used output buffers: 3 of 24 (18 max)
Static ram: 23460
Dynamic ram: 73192 of which 468 recycled
Never used RAM 14960, free system stack 111 words
Tasks: NETWORK(ready,161) HEAT(blocked,78) MAIN(running,417) IDLE(ready,20)
Owned mutexes: WiFi(NETWORK)
Last reset 07:36:24 ago, cause: reset button or watchdog
Last software reset at 2021-04-17 13:04, reason: User, GCodes spinning, available RAM 16876, slot 0
Error status: 0x00
Aux0 errors 2,2,2
MCU temperature: min 29.3, current 35.7, max 39.9
Supply voltage: min 11.2, current 12.0, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max 104/669
Driver 1: position 24000, standstill, SG min/max 116/678
Driver 2: position 23240, standstill, SG min/max not available
Driver 3: position 0, standstill, SG min/max not available
Driver 4: position 0, standstill, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2021-04-18 22:45:39
Slowest loop: 5200.44ms; fastest: 0.12ms
=== Storage ===
Free file entries: 10
SD card longest read time 4.2ms, write time 61.2ms, max retries 0
DMs created 83, maxWait 6772417ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 87462, completed moves 87462, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 3], CDDA state -1
=== AuxDDARing ===
Heater 0 is on, I-accum = 0.3
Heater 1 is on, I-accum = 0.5
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 64.92ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.25beta0
WiFi MAC address 24:a1:60:2d:e7:57
WiFi Vcc 3.38, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 19392
WiFi IP address 192.168.1.60
WiFi signal strength -58dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
M98 P"config.g":
HTTP is enabled on port 80
FTP is disabled
TELNET is disabledconfig.g:
; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Apr 17 2021 13:14:11 GMT+0200 (heure d’été d’Europe centrale); General preferences
M550 P"My Printer" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes backwards
M92 X80.00 Y80.00 Z400.00 E2910.26 ; set steps per mm
M208 X300 Y300 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M575 P1 S1 B57600 ; enable support for PanelDue - WiFi -
Check the setup page on the PanelDue. What firmware is installed?
Did you try to flash it yet? What firmware version did you use? What hardware version of PanelDue is it?
@phaedrux the firmware version displayed on the panel due is 3.2.11 which is the version I flashed, my panel has a ATSAM4S4B so hardware version 3 I believe.
also my start g code:
M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
M220 S100 ;Reset Feedrate
M221 S100 ;Reset FlowrateG28 ;Home
G92 E0 ;Reset Extruder
G1 Z2.0 F3000 ;Move Z Axis up
G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
G1 Z2.0 F3000 ;Move Z Axis up -
@docfail said in Wifi error:
M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup JerkRemove those lines from your start gcode. They are over writing your settings from config.g with settings for Marlin.
Which firmware binary specifically did you use for the PanelDue?
If it's a 7i it should be this one: https://github.com/Duet3D/PanelDueFirmware/releases/download/3.2.11/PanelDueFirmware-5.0i-7.0i.zip
Please try reflashing.
@phaedrux ok now it work thanks !!! Before I tried using the PanelDueFirmware-v3-7.0.zip, why isn't it correct ? G code also runs at normal speed !
I'm also using a cr10s stock layer fan but it isn't turning on, the hotend fan is working great but not this one even on the same output. Layer fan works on the psu output, could this be something pwm related ? -
No, because you have the 7i
I don't see anything wrong in your config for fan0. Can you confirm you have it connected to the fan0 port?
Manually send M106 P0 S1 and it should turn on. If not, check the mosfets next to the fan headers for damage.
see example here: https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Fan_mosfet
@Phaedrux The M106 doesn't works and now my always on fan works only when jumper is on 5V, mosfets don't seems damaged, and checked with a multimeter no voltage when jumper is on 12v
Can you post a photo of how you have the fans wired?
What kinds of fans are they and how are you trying to use them?
See here for more details on fans: https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans
@phaedrux
Red and black wire is a 12V small blower fan used for layer cooling
White and yellow is a 12V 40mm fan used to cool the hotendBut the problems comes very probably from the black fuse I found on documentation that it's used for Vin fans, and it's blown up...
So I probably messed up something... I'm not really sure maybe reversed polarity with dupont wires...
how can I get a replacement fuse ? -
The 1amp fuse can be found online or from a local car or motorcycle parts shop.
If you can't find a 1amp fuse a larger fuse can be used, but you also reduce the protection offered. Obviously something shorted out to blow it, so be sure your wiring is correct.
@phaedrux I found a fuse online, it's i the mail , I'll double check my wiring and install it. So I believe there is finally no more problem .Thanks a lot for the help !!
