4 motors on one axis homing
@o_lampe
in this case endstop detection will be considered at a stall detection from the first of the two motors if they do not stall simultaneously? Or do both motors need stall detection to trigger the endstop? -
@fcwilt
Heavy X axis with Z axis mounted on it.
taking into account the low cost of the steppers, and 6+3 driver on Duet3 + 3HC I decide to put 2 motors for 1 belt and thereby reduce the backlash and increase the torque. Which is especially important for high accelerations of a heavy head. And I plan to put a spindle in addition to the print head to be able to finish the surface after printing and drilling holes -
@dk said in 4 motors on one axis homing:
and drilling holes
You think there's enough bed adhesion to keep the part in place while drilling?
Don't get me wrong, I like the idea.
Maybe I'd use a quick release mount for the spindle and only attach it when needed. -
Stall homing resolved.
But I cant get Y to home properly. I add 2 endstop for each of Y rails and everything work great if I use only 2 Y motors, one for left rail and one for right rail. But my setup have two Y motors on both rails (4 total for Y).
M584 X0.2:1.2 Y0.0:0.3:0.4:1.0 Z0.1:1.1 ; set drive mapping
In this case first homing stops when the first endstop is triggered.
Is it possible to independently homing the right and left rails of the Y axis if there are 2 motors on right rail and 2 motors on left rail of Y axis? -
@dk https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_RepRapFirmware_Num_3
See M574 S4 for multi-motor load stall detection.
@phaedrux
Yes, S4 works well on Z - 2 motors on Z stopped individually. But for Y axis I use 2 optical endstop and so my only choice M574 S1
But because of 4 motors on Y, left and right rail do not stoped individually -
Ah ok. It's even easier with with endstops, you just need to specify all the endstop pins used for that axis in the M574 command.
Please post your full config.g
@phaedrux
Config fileG90 ; send absolute coordinates...
M550 P"Duet3" ; set printer name; Drives
M569 P0.0 S0 ; physical drive 0.0 goes forwards
M569 P0.4 S1 ; physical drive 0.5 goes forwards
M569 P0.3 S0 ; physical drive 0.3 goes forwards
M569 P1.0 S1 ; physical drive 1.0 goes forwards
M569 P1.1 S1 ; physical drive 1.1 goes forwards
M569 P1.2 S1 ; physical drive 1.2 goes forwards
M584 X0.2:1.2 Y0.0:0.3:1.0:0.4 Z0.1:1.1 ; set drive mapping
M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z400.00 ; set steps per mm
M566 X900.00 Y900.00 Z90.00 ; set maximum instantaneous speed changes (mm/min)
M203 X19000.00 Y19000.00 Z900.00 ; set maximum speeds (mm/min)
M201 X1200.00 Y1200.00 Z120.00 ; set accelerations (mm/s^2)
M906 X800 Y2200 Z1000 ; set motor currents (mA) and motor idle factor in per cent
M208 X300 Y660 Z110 S0 ; set axis maxima
M564 H0 ; allow move without homing; Endstops
M574 X1 S3 ; configure sensorless endstop for low end on X
M574 Y1 S1 P"0.io0.in+1.io0.in" ; configure active-low endstop for low end on Y via pin io0.in
M574 Z1 S4 ; configure sensorless endstop for low end on Z
M915 X Z R0 F0 ; configure sensorless homing for X and Z; Z-Probe
M558 P0 H5 F1200 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X50:250 Y50:650 S50 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
M563 P0 F-1 ; define tool 0
; homeall.g
; called to home all axes
;M400 ; Clear buffer
M913 X30 Z50 ; Drop motor current 30% for X 50% for Z
M400 ; Clear buffer
G91 ; relative positioning
G1 H2 Z5 F600 ; lift Z relative to current position
G1 H1 X-305 F6000 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 X5 F6000 ; go back 5 mm
G1 H1 X-15 F3000 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y-685 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 Y5 F5000 ; go back a few mm
G1 H1 Y-15 F600 ; move slowly to X and Y axis endstops once more (second pass)
G1 H1 Z-125 F600 ; move Z down stopping at the endstop
G90 ; absolute positioning
G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
G1 Z5 F500 ; lift Z relative to current position
M400 ; Clear buffer
M913 X100 Z100 ; motor current back to 100%
M400 ; Clear buffer -
It looks like you have your drives spread out all across the mainboard and expansion. Is there any way to get them grouped together or is that due to wiring runs?
M574 Z1 S4 ; configure sensorless endstop for low end on ZSo sensorless on X, endstops on Y, and sensorless on Z?
What kinematics type is this printer?
What kind of motors?
How much of your homing currently works? Are you able to home each axis individually? Please explain where each fails.
@phaedrux
Yes, this drivers spread due to wiring. I have 4 NEMA23 for Y (2 motors move one belt for left and right rail), 2 Nema17 34mm with lead screw for Z, 2 NEMA17 20mm for X.
Cartesian kinematic. Dual Y axis rails (its actually dual 16mm shafts on both sides of printer) moving two Z rails, which hold X axis.For now sensorless homing on X and sensorless on Z works find.
Endstops on Y also work, but not independently for two Y rails. if the axis is slightly shifted (I specifically moved one rail by 10 mm relative to the second), the homing is triggered when the first rail touches the endstop. And printer remains shifted Y axis by 10 mm.
If I disconnect 2 motors
(M584 X0.2:1.2 Y0.3:1.0 Z0.1:1.1 instead of M584 X0.2:1.2 Y0.0:0.3:0.4:1.0 Z0.1:1.1 ),
then the independent homing works as it should, both rails go to the endstop.
So, I want to achieve independent homing for two Y axis rails with four motors (2 motors for each rail) -
@phaedrux
But because of 4 motors on Y, left and right rail do not stoped individuallyThat's correct. The built-in multiple-endstop homing requires you to have the same number of endstops as axis motors.
Here are three possible solutions:
Connect two Y motors to each to two drivers, so that they look like single motors. As you are using Duet 3 which can drive motors with up to 6.3A peak, you can connect two motors in parallel to make a pair, and set the current to 4400 in M906 instead of 2200.
Alternatively, you can continue to use a separate driver per motor, and during homing split the Y axis into two axes (e.g. Y and U), just as we had to do in RRF2 when using multiple endstop switches. See https://duet3d.dozuki.com/Guide/Independent+Z+motors+and+endstop+switches+in+RRF2/18 but adapt the GCode commands for RRF3 (e.g. use endstop pin names in the M574 commands).
Pretend that you have 4 endstop switches. M574 will not allow you to use the same input more than once, so you would need to use 4 inputs and connect each endstop switch to 2 of them.
the first option looks the most interesting. This way I can get 2 more spare drivers for future upgrades!
Do you have wiring diagram for parallel stepper connection?
Should steppers wire length be the same? or 500mm difference in wires lengths does not effect synchronies of motor movements?
