    HELP...SSR With Heater Channel on 3CH daughterboard
    560
    • Jordan_Miller41undefined
      Jordan_Miller41
      So, I thought I understood how to set everything up correctly, but here I am.
      So reading some other threads, it sounded like you could use the "heater channel" for a hotend to trigger your SSR to turn on a bed or enclosure, or in my case, I need to do both independently.
      Here is a picture of what I have, it just keeps giving a heater fault when trying to turn on the bed heater, I've switched around polarity and I haven't been successful yet.
      Heater "1.out_1" (daughterboard) is being used to trigger the relay. I'm running 24V VIN.
      Here is the exact relay I am using: SSR
      I am using the same wiring setup as the diagram except that the input side of the SSR is on "1.out_1" as previously mentioned.
      Just need the guidance to get this online.
      • Jordan
      Alex.crundefined 1 Reply Last reply Reply Quote 0
      • Alex.crundefined
        Alex.cr @Jordan_Miller41
        @jordan_miller41
        Does the LED indicator on the SSR light up when you send the command to turn on your bed?
        Do you see any temp rise in DWC? Or does it fault immediately?
        What temp does your thermistor say in DWC at idle?
        Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
        Jordan_Miller41undefined 1 Reply Last reply Reply Quote 0
          Jordan_Miller41 @Alex.cr
          @alex-cr It faults right away. The temp it gives is 22.5C. Just double-checked again, it does not turn the light on.
          • Jordan
          • Alex.crundefined
            @jordan_miller41
            Post your config.g file. If you run M98 P"config.g" do you get any errors?
            I just had a bad experience with ignoring the errors coming out of it because I thought I knew better, cost me a couple days...
              @alex-cr I think your on to something, this makes sens sensor #0 and 3 not being configured, I was too ignoring them 🙂
              What do I need to do to fix it?
              ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Apr 19 2021 17:15:29 GMT-0400 (EDT)
              M550 P"Duet 3" ; set printer name
              M669 K1 ; select CoreXY mode
              M569 P0.4 S1 ; physical drive 0.4 goes forwards
              M584 X0.0 Y0.1 Z0.2 E0.3:0.4 ; set drive mapping
              M92 X80.00 Y80.00 Z800.00 E145.51:145.51 ; set steps per mm
              M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
              M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X400 Y400 Z440 S0 ; set axis maxima
              M574 X1 S1 P"io1.in" ; configure active-high endstop for low end on X via pin io1.in
              M574 Y2 S1 P"io0.in" ; configure active-high endstop for high end on Y via pin io0.in
              M558 P5 C"^io3.in" H15 F1200 T6000 ; set Z probe type to switch and the dive height + speeds
              M557 X15:400 Y50:400 S50 ; define mesh grid
              M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
              M950 H0 C"1.out1" T0 ; create bed heater output on 1.out1 and map it to sensor 0
              M308 S1 P"temp2" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin temp2
              M143 H1 S455 ; set temperature limit for heater 1 to 455C
              M308 S2 P"temp3" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin temp3
              M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2
              M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
              M143 H2 S280 ; set temperature limit for heater 2 to 280C
              M308 S3 P"temp1" Y"thermistor" T10000 B4723 C1.19622e-7 ; configure sensor 3 as thermistor on pin temp1
              M950 H3 C"1.out0" T3 ; create chamber heater output on 1.out0 and map it to sensor 3
              M307 H3 B1 S1.00 ; enable bang-bang mode for the chamber heater and set PWM limit
              M141 H3 ; map chamber to heater 3
              M143 H3 S90 ; set temperature limit for heater 3 to 90C
              M950 F0 C"!out4" Q25000 ; create fan 0 on pin !out4 and set its frequency
              M106 P0 C"FRONT PANEL" S1 H-1 ; set fan 0 name and value. Thermostatic control is turned off
              M950 F1 C"!out5" Q25000 ; create fan 1 on pin !out5 and set its frequency
              M106 P1 C"RAD 1 (TOP)" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
              M950 F2 C"!out6" Q25000 ; create fan 2 on pin !out6 and set its frequency
              M106 P2 C"RAD 2 (BOTTOM)" S1 H1 T45 ; set fan 2 name and value. Thermostatic control is turned on
              M950 F3 C"1.out6" Q500 ; create fan 3 on pin 1.out6 and set its frequency
              M106 P3 C"Water Pump" S1 H-1 ; set fan 3 name and value. Thermostatic control is turned on
              M950 F4 C"out7" Q500 ; create fan 4 on pin out7 and set its frequency
              M106 P4 C"E3D V6 Hotend" S0.5 H2 T45 ; set fan 4 name and value. Thermostatic control is turned on
              M563 P0 S"Mosquito Liquid" D0 H1 F-1 ; define tool 0
              M563 P1 S"E3D V6" D1 H2 F-1 ; define tool 1
              ; Custom settings
              M584 X0 Y1 Z3:4:5 E4 ; three Z motors connected to driver outputs 2, 5 and 6
              M671 X-25.298:200.199:427.12 Y2.021:430.231:20.21 S0.5 ; ball screws at front left, back middle and front right
              M308 S10 P"1.temp0" Y"thermistor" T10000 B3988 A"Coolant Cold" ; Configure coolant sensor cold side
              M308 S11 P"1.temp1" Y"thermistor" T10000 B3988 A"Coolant Hot" ; Configure coolant sensor hot side
              • Jordan
              • Alex.crundefined
                @jordan_miller41 said in HELP...SSR With Heater Channel on 3CH daughterboard:
                I think the problem might be that your temp sensor for this heater is defined as being plugged into the 6HC while your output is set on the 3HC. Is this supposed to be the case?
                Edit: I just read down further, can you move your coolant sensors over to the main board and your control thermistors over to the 3HC?
                I believe the firmware requires that temperature sensors that control heaters be plugged into the same board. It will need to be confirmed though.
                if your temp sensor is actually plugged into temp0 on the 3HC try changing the P command to the following:
                P"1.temp0"
                By the way it looks like a similar change will be needed for your chamber heater on H3.
                Edit: I just read down further, can you move your coolant sensors over to the main board and your heater control thermistors for H0 and H3 over to the 3HC?
                  @alex-cr Ahhhhh that makes sense, I will do that in the morning. I think that would have to be it, didn't even think of that. I'll report back tomorrow with hopefully good results!
                  • Jordan
                    dc42 administrators @Jordan_Miller41
                    @jordan_miller41 see the second bullet point at https://duet3d.dozuki.com/Wiki/Duet_3_firmware_configuration_limitations.
                    Jordan_Miller41undefined 2 Replies Last reply Reply Quote 0
                      Jordan_Miller41 @dc42
                      @dc42 thank you, that clears it up!
                      • Jordan
                        @dc42 So got the thermisters remapped, the SSR kicks on and started heating the bed up, then it just faulted again after heating the bed from 18C to 30C. Only stays on for about 30-45 seconds. Thoughts?
                        • Jordan
                        • Alex.crundefined
                          @jordan_miller41
                          Have you performed an M303 command to get the heating model updated?
                          BTW you may have to do this manually depending on what firmware version you are currently running.
                          Jordan_Miller41undefined 1 Reply Last reply Reply Quote 1
                            @alex-cr ok what if it is for bang-bang mode? So I have to tune the bed before it will heat all the way up?
                            • Jordan
                              PID tuning is recommended so that the firmware has an idea of the heaters performance (heat up and cool down time). In bang-bang it can be too slow for the default watchdog and it times out.
                                Jordan_Miller41 @Phaedrux
                                @phaedrux understood, so for an enclosure heater, is there a way to adjust the "watchdog" parameters? I don't know how long it will take to heat my enclosure and I don't want it to time out.
                                • Jordan
                                  Phaedrux Moderator @Jordan_Miller41
                                  Yes, PID tune the heater.
                                    @phaedrux ok
                                    • Jordan
