    Printing Problems
    My Duet controlled machine
    extruder firmware layer
    862
    • MauriceMundefined
      MauriceM
      Hello, I have a problem with my printer which I can not classify, so I thought I just ask here if anyone has seen the problem by chance before.
      I have a Voron V2 with eig well-built mechanics.
      The problem is this, when I want to print a lot of parts at once, the printer spins a little.
      It extrudes way too much material on the 20-30 layer causing a line in the print parts.
      But it only does this when I print more than 5 parts, before that everything is great.
      I wonder if it is the software of the printer or if it is a different problem.
      Unfortunately I am not sure.
      • cosmowaveundefined
        cosmowave
        Which slicer are you using? Do you have tried it with another slicer yet?
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        MauriceMundefined 1 Reply Last reply Reply Quote 0
        • MauriceMundefined
          MauriceM @cosmowave
          @cosmowave I use superslicer, and no i didnt tryed an other slicer.
          Im running 3 printers and the moment.
          All Vorons and for all im slicing with SuperSlicer, but only on printer does have this fault.
          But i could try it.
          cosmowaveundefined 1 Reply Last reply Reply Quote 0
            cosmowave @MauriceM
            @mauricem and it's allways layer 23 which makes problems?
            • MauriceMundefined
              MauriceM @cosmowave
              @cosmowave
              not that was just a bad example, but it is allways a very low layer.
              never at the top.
                cosmowave @MauriceM
                @mauricem when the same gcode is printing well on another machine, then it seems to be a mechanical or extruder problem of that printer.
                Eventually ther eis a problem with the extruder or the hotend. Sometimes the heatbed (bang-bang-mode) has an electric influence on other systems in the printer...
                • MauriceMundefined
                  MauriceM @cosmowave
                  @cosmowave ok that could be.
                  First i will try an other slicer, than i will test it with my other printers.
                  But they all build exactly the same, and the power off the bed should be the same. no matter how many parts i have on the bed.
                  Thats why im so confused.
                    cosmowave @MauriceM
                    @mauricem you're right, when it is depending on the number of parts on the printbed it's very strange....
                    How are the parts looking? Have they a very special shape? Do you have very much retractions while printing these parts?
                    • MauriceMundefined
                      MauriceM @cosmowave
                      @cosmowave No thats some really easy parts, expacially on that height, they are only some shafts.
                        cosmowave @MauriceM
                        @mauricem Can it be, that there is a problem with the z axle? you can check if it is running smoothly and all screws are tight.
                        • MauriceMundefined
                          MauriceM @cosmowave
                          @cosmowave i found the issue, somehow and i dont know why, it is a cooling issue, i think because of layertime ect.
                          But thanks for ur help. im glad that it is only that.
                            cosmowave @MauriceM
                            @mauricem Perfect!
                            Happy printing! 👍
