    [SOLVED] Paneldue firmware compile error
    PanelDue
    828
      jay_s_uk @64bit
      @64bit
      Download or git clone the dev branch of RRFLibraries into C:\Eclipse.
      64bitundefined 1 Reply Last reply Reply Quote 0
      • 64bitundefined
        64bit @jay_s_uk
        @jay_s_uk
        Already been done.
        Downloaded RRFLibraries-3.3-dev whatever its called.
        Renamed it to RRFLibraries
        Put it in Eclipse and even under the firmware tab.
        It wont come up in Eclipse when I try to "open project" either, so im going to look into that more.
          jay_s_uk @64bit
          @64bit the project explorer should look like this
          • 64bitundefined
            64bit @jay_s_uk
            @jay_s_uk
            Making progress I guess.
            Now Im stuck with no .bin being output.
            make --no-print-directory post-build
            Generating binary
            "/arm-none-eabi-objcopy" -O binary "C:/Eclipse/PanelDueFirmware/Release-v3-4.3/PanelDueFirmware-v3-4.3.elf" "C:/Eclipse/PanelDueFirmware/Release-v3-4.3/PanelDueFirmware-v3-4.3-nologo.bin" && cat "C:/Eclipse/PanelDueFirmware/Release-v3-4.3/PanelDueFirmware-v3-4.3-nologo.bin" "C:/Eclipse/PanelDueFirmware/SplashScreens/SplashScreen-Duet3D-480x272.bin" >"C:/Eclipse/PanelDueFirmware/Release-v3-4.3/PanelDueFirmware-v3-4.3.bin"
            c:/windows-build-tools/bin/sh: C:/arm-none-eabi-objcopy: not found
            jay_s_ukundefined 2 Replies Last reply Reply Quote 0
              jay_s_uk @64bit
              @64bit yea, i just got that error. will look into it and report back
                jay_s_uk @64bit
                @64bit what have you got in C:\windows-build-tools?
                I had 2 folders and had to tidy it up. works ok for me now.
                • 64bitundefined
                  64bit @jay_s_uk
                  @jay_s_uk
                  I found objcopy.exe in my GNU Embedded tools. So I ran the following from the cmd prompt
                  C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2020-q4-major\arm-none-eabi\bin>objcopy.exe -O binary "C:/Eclipse/PanelDueFirmware/Release-v3-4.3/PanelDueFirmware-v3-4.3.elf" "C:/Eclipse/PanelDueFirmware/Release-v3-4.3/PanelDueFirmware-v3-4.3-nologo.bin"
                  Output was a no logo bin that I have now flashed to the paneldue. after a reset it opened right up.
                  A bit of ass pain, but it worked.
                  • 64bitundefined
                    64bit @jay_s_uk
                    @jay_s_uk
                      jay_s_uk @64bit
                      @64bit
                      can you try going to Windows -> Preferences -> C/C++ -> Build -> Build Variables and click "Add..."
                      set the name to "ArmGccPath", then change to directory and navigate to C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2020-q4-major\arm-none-eabi\bin
                      Then apply and close eclipse. reopen it and try and build
                      • 64bitundefined
                        64bit @jay_s_uk
                        @jay_s_uk said in Paneldue firmware compile error:
                        Must be an issue in the makefile?
                        "C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2020-q4-major\arm-none-eabi\bin/arm-none-eabi-objcopy" -O binary "C:/Eclipse/PanelDueFirmware/Release-v3-4.3/PanelDueFirmware-v3-4.3.elf" "C:/Eclipse/PanelDueFirmware/Release-v3-4.3/PanelDueFirmware-v3-4.3-nologo.bin" && cat "C:/Eclipse/PanelDueFirmware/Release-v3-4.3/PanelDueFirmware-v3-4.3-nologo.bin" "C:/Eclipse/PanelDueFirmware/SplashScreens/SplashScreen-Duet3D-480x272.bin" >"C:/Eclipse/PanelDueFirmware/Release-v3-4.3/PanelDueFirmware-v3-4.3.bin"
                        c:/windows-build-tools/bin/sh: C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2020-q4-major\arm-none-eabi\bin/arm-none-eabi-objcopy: not found
                        make[1]: [makefile:94: post-build] Error 127 (ignored)
                          jay_s_uk @64bit
                          @64bit
                          It compiles ok for me here
                          64bitundefined 2 Replies Last reply Reply Quote 0
                          • 64bitundefined
                            64bit @jay_s_uk
                            @jay_s_uk
                            I dont understand where the forward slash is coming from.
                            I mean, I can keep just using the command line to run objcopy. I just wish it wasnt screwed up.
                            What version of the GNU Arm Embedded Toolchain are you using?
                            • 64bitundefined
                              64bit @jay_s_uk
                              @jay_s_uk
                              SOLVED
                              Generating binary
                              copied and renamed objcopy.exe to arm-none-eabi-objcopy.exe
                              File compiles properly now into both w/logo and no-logo files.
                              R006undefined 1 Reply Last reply Reply Quote 1
                              • R006undefined
                                R006 @64bit
                                @jay_s_uk i got the same error and try as @64bit mentioned in the post but its not working for me.
                                i an waiting your reply @jay_s_uk
                                • R006undefined R006 referenced this topic
