    Polar Printer Steps/Degree?
    2.9k
    • Phospherusundefined
      Phospherus @shadi
      @shadi
      For your M92 X100 Y14.33 Z401 E84
      • shadiundefined
        shadi @Phospherus
        This post is deleted!
        Phospherusundefined 2 Replies Last reply Reply Quote 0
          Phospherus @shadi
          @shadi
          Where is your X axis Endstop is it by the tower or at the end of arm?
          If you X homes to min and is near tower. Then you need to to home to the switch and in your homing file do a G92 X105 to set the X at the homing switch to X105. but you will have to change your M208 parameter.
          M208 X105 Y0 Z0 S1 ; set axis minima
          M208 X445 Y360 Z400 S0 ; set axis maxima
          Also like I said rotating bed or Y axis normally go clockwise. since you are rotating X you need it to go counterclockwise.
          shadiundefined 1 Reply Last reply Reply Quote 0
          • shadiundefined
            shadi @Phospherus
            @phospherus Yes it home at lower end that is right but i did not yet fixed the switch
            Phospherusundefined 1 Reply Last reply Reply Quote 0
              Phospherus @shadi
              @shadi
              The X arm itself does not need to be the nozzle itself needs to be perfectly centered.
                Phospherus @shadi
                @shadi
                OK then position by hand with motors off M84. Then once in position do a G92 X105 Y0 Z0 to set positions.
                shadiundefined 2 Replies Last reply Reply Quote 0
                • shadiundefined
                  shadi @Phospherus
                  @phospherus ok i will test and update you i really appreciate you help
                  • shadiundefined
                    shadi @Phospherus
                      Phospherus @shadi
                      @shadi
                      That was with the x axis at 105mm from center of z tower and you did G92 X105 to set position?
                      And how do you have your slicer setup?
                      • shadiundefined
                        shadi @Phospherus
                        @phospherus yes it was however slicer is cura with normal setup as if I slice for any Cartesian printer is there specific setup I just make the plate eclipse and make the origin is center so it is plate with origin
                          Phospherus @shadi
                          @shadi
                          I used simplify 3d so can not comment on Cura but In simplify I just leave it as Cartesian because Delta seems to mess things up. My diameter is 240 for bed so I set that for X and Y then do 120 offset to get nozzle in middle.
                          • shadiundefined
                            shadi @Phospherus
                            @phospherus I just want to know do you have the same design ? because if yes and working that means something missing in my config and it should work right ? how did you calculate X value can i know the formula ? is it possible to know how do you home your machine ?
                            As per the polar kinematics documentation homeradius.g and homebed.g should be present however when i rename homex.g and homey.g DWC is giving homex.g or homey.g not found
                            regards;
                              Phospherus @shadi
                              @shadi
                              No my design is not same with the tower in the middle but from what I can see the kinematics should be the same.
                              • shadiundefined
                                shadi @Phospherus
                                @phospherus is it possible to tell me which version of reprap firmware are you using because I think there is problem in the version I use because I noticed it behaves correctly sometimes and sometimes not
                                Phospherusundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                  Phospherus @shadi
                                  @shadi
                                  I am using the 3.2.2 stable. I tried version 3.3 beta 2 and Beta 3 and still have issues. 3.2.2 is working for me though.
                                  • shadiundefined
                                    shadi @Phospherus
                                      dc42 administrators @shadi
                                      @shadi said in Polar Printer Steps/Degree?:
                                      @shadi I believe this is caused by the same bug that I have just fixed for the issue reported at https://forum.duet3d.com/post/229256. The workaround is the same, i.e. send M669 with a T parameter (e.g. T0.2 to use the default segment length).
