    Polar Printer Steps/Degree?
    3.0k
    • shadiundefined
      shadi @Phospherus
      @phospherus said in Polar Printer Steps/Degree?:
      gain as soon as I have a chance. I did however get my BLtouch and mesh bed setup on 3.2.2 on the polar as a delta using radius and seems to work very well.
      @dc42 In my case actually Y plate is turntable and X and Z are both moving as they are located on the table, did you test the same and it works ? if possible to share the config.g that you have tested at ?polar-machine-example.png
      have you tested for this design ?
      • shadiundefined
        shadi @Phospherus
        This post is deleted!
        Phospherusundefined 1 Reply Last reply Reply Quote 0
        • Phospherusundefined
          Phospherus @shadi
          @shadi
          Ok on a polar printer the center of the turn bed or rotating plater is 0,0 for the X and Y axis. On your design with the z tower being in the middle and rotating you will have to measure from the center of the tower out to the closest position to the tower that the x axis can get to. I would measure from center of tower to max X position and home to the + instead of minus. But your lowest X position will be the distance from center of tower to the nozzle.
          Also on a polar with the bed rotating the y axis goes in the clockwise direction for plus. On your design the Z and X would need to go counter clockwise.
          As for steps per mm for the X. I need to know belt pulley teeth count on stepper and belt pitch to help with that.
          I hope I explained this well enough.
          shadiundefined 1 Reply Last reply Reply Quote 0
          • shadiundefined
            shadi @Phospherus
            Phospherusundefined 2 Replies Last reply Reply Quote 0
              Phospherus @shadi
              @shadi
              When looking as the Z,X Gantry it should rotate counterclockwise.
              Please post your config.
                Phospherus @shadi
                @shadi
                For your M92 X100 Y14.33 Z401 E84
                • shadiundefined
                  shadi @Phospherus
                    Phospherus @shadi
                    @shadi
                    Where is your X axis Endstop is it by the tower or at the end of arm?
                    If you X homes to min and is near tower. Then you need to to home to the switch and in your homing file do a G92 X105 to set the X at the homing switch to X105. but you will have to change your M208 parameter.
                    M208 X105 Y0 Z0 S1 ; set axis minima
                    M208 X445 Y360 Z400 S0 ; set axis maxima
                    Also like I said rotating bed or Y axis normally go clockwise. since you are rotating X you need it to go counterclockwise.
                    • shadiundefined
                      shadi @Phospherus
                      @phospherus Yes it home at lower end that is right but i did not yet fixed the switch
                        Phospherus @shadi
                        @shadi
                        The X arm itself does not need to be the nozzle itself needs to be perfectly centered.
                          Phospherus @shadi
                          @shadi
                          OK then position by hand with motors off M84. Then once in position do a G92 X105 Y0 Z0 to set positions.
                          shadiundefined 2 Replies Last reply Reply Quote 0
                          • shadiundefined
                            shadi @Phospherus
                            @phospherus ok i will test and update you i really appreciate you help
                            • shadiundefined
                              shadi @Phospherus
                                Phospherus @shadi
                                @shadi
                                That was with the x axis at 105mm from center of z tower and you did G92 X105 to set position?
                                And how do you have your slicer setup?
                                • shadiundefined
                                  shadi @Phospherus
                                  @phospherus yes it was however slicer is cura with normal setup as if I slice for any Cartesian printer is there specific setup I just make the plate eclipse and make the origin is center so it is plate with origin
                                    Phospherus @shadi
                                    @shadi
                                    I used simplify 3d so can not comment on Cura but In simplify I just leave it as Cartesian because Delta seems to mess things up. My diameter is 240 for bed so I set that for X and Y then do 120 offset to get nozzle in middle.
                                    • shadiundefined
                                      shadi @Phospherus
                                      @phospherus I just want to know do you have the same design ? because if yes and working that means something missing in my config and it should work right ? how did you calculate X value can i know the formula ? is it possible to know how do you home your machine ?
                                      As per the polar kinematics documentation homeradius.g and homebed.g should be present however when i rename homex.g and homey.g DWC is giving homex.g or homey.g not found
                                      regards;
                                        Phospherus @shadi
                                        @shadi
                                        No my design is not same with the tower in the middle but from what I can see the kinematics should be the same.
                                        • shadiundefined
                                          shadi @Phospherus
                                          @phospherus is it possible to tell me which version of reprap firmware are you using because I think there is problem in the version I use because I noticed it behaves correctly sometimes and sometimes not
                                          Phospherusundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                            Phospherus @shadi
                                            @shadi
                                            I am using the 3.2.2 stable. I tried version 3.3 beta 2 and Beta 3 and still have issues. 3.2.2 is working for me though.
