    Hot end fan switches off at the start of the print.
    961
    • GrahamExpundefined
      GrahamExp @GrahamExp
      @grahamexp So what happens now is that the hot end fan (fan 1) starts up at 45 degrees but as soon as the printing begins it switches off again. Part cooling fan is now fan 0.
      SIamundefined 1 Reply Last reply Reply Quote 0
      • SIamundefined
        SIam @GrahamExp
        @grahamexp please post the first 50- 100 lines from your generated g-code
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        GrahamExpundefined 1 Reply Last reply Reply Quote 0
          GrahamExp @SIam
          @siam ;FLAVOR:RepRap
          ;TIME:1471
          ;Filament used: 0.844173m
          ;Layer height: 0.25
          ;MINX:127.88
          ;MINY:109.761
          ;MINZ:0.3
          ;MAXX:173.172
          ;MAXY:190.237
          ;MAXZ:69.428
          ;ARCWELDERPROCESSED
          ;LINEARADVANCEPROCESSED
          ; Postprocessed by ArcWelder
          ; Copyright(C) 2020 - Brad Hochgesang
          ; resolution=0.05mm
          ; path_tolerance=1%
          ; max_radius=1000000.00mm
          ; firmware_compensation=True
          ; mm_per_arc_segment=1.00mm
          ; min_arc_segments=12
          ; default_xyz_precision=3
          ; default_e_precision=5
          ;Generated with Cura_SteamEngine 4.8.0
          T0
          M190 S70
          M104 S255
          M109 S255
          M82 ;absolute extrusion mode
          G28 ;Home
          G1 Z15.0 F6000 ;Move the platform down 15mm
          ;Prime the extruder
          G92 E0
          G1 F200 E3
          G92 E0
          M83 ;relative extrusion mode
          G1 F1500 E-2.5
          ;LAYER_COUNT:278
          M572 S0.550000 D0 ;added by LinearAdvanceSettingPlugin
          ;LAYER:0
          M107
          G0 F1800 X129.314 Y111.721 Z0.3
          ;TYPE:SKIRT
          G1 F1500 E2.57838
          G3 X131.478 Y110.170 I4.273 J3.677 E0.05677 F1800
          G3 X134.459 Y109.809 I2.190 J5.596 E0.06412
          G3 X148.452 Y112.224 I-9.081 J94.362 E0.30040
          G3 X167.834 Y128.297 I-8.557 J30.041 E0.54778
          G3 X173.150 Y151.443 I-42.633 J21.975 E0.50717
          G3 X166.571 Y173.960 I-48.325 J-1.900 E0.50082
          G3 X145.391 Y188.503 I-26.690 J-16.176 E0.55959
          G3 X134.082 Y190.219 I-20.282 J-95.543 E0.24187
          G3 X131.450 Y189.818 I-0.490 J-5.620 E0.05677
          G3 X129.295 Y188.255 I2.132 J-5.207 E0.05677
          G3 X128.096 Y185.878 I4.291 J-3.655 E0.05677
          G3 X127.968 Y182.725 I8.568 J-1.927 E0.06706
          G3 X128.417 Y181.251 I9.908 J2.213 E0.03259
          G2 X128.161 Y118.021 I-89.047 J-31.255 E1.36259
          G3 X127.893 Y115.782 I5.351 J-1.776 E0.04794
          G3 X128.567 Y112.834 I7.467 J0.156 E0.06441
          G3 X129.314 Y111.721 I4.978 J2.534 E0.02838
          G0 X129.721 Y111.906
          G3 X131.849 Y110.487 I3.872 J3.502 E0.05457
          G3 X134.415 Y110.235 I1.804 J5.177 E0.05495
          G3 X148.343 Y112.638 I-8.992 J93.687 E0.29899
          G3 X167.386 Y128.359 I-8.429 J29.604 E0.53701
          G3 X172.726 Y151.316 I-42.320 J21.944 E0.50335
          G3 X165.883 Y174.252 I-46.997 J-1.533 E0.51142
          G3 X145.303 Y188.084 I-26.019 J-16.486 E0.53936
          G3 X134.045 Y189.792 I-20.170 J-94.993 E0.24080
          G3 X131.520 Y189.383 I-0.456 J-5.186 E0.05458
          G3 X129.494 Y187.823 I2.074 J-4.789 E0.05456
          G3 X128.603 Y186.115 I4.064 J-3.206 E0.04092
          G3 X128.393 Y182.780 I7.886 J-2.171 E0.07113
          G3 X129.680 Y178.828 I75.446 J22.384 E0.08787
          G2 X128.567 Y117.886 I-90.315 J-28.832 E1.31137
          G3 X128.374 Y115.147 I5.612 J-1.772 E0.05851
          G3 X128.983 Y112.962 I5.422 J0.334 E0.04826
          G3 X129.721 Y111.906 I4.580 J2.415 E0.02728
          G1 F1500 E-2.5
          ;MESH:Canopy_1.stl
          G0 F1800 X137.542 Y183.534
          ;TYPE:WALL-OUTER
          G1 F1500 E2.57838
          G3 X139.669 Y180.068 I310.315 J188.047 E0.08596 F1800
          G3 X143.539 Y176.885 I8.004 J5.787 E0.10704
          G3 X145.915 Y176.082 I8.132 J20.146 E0.05305
          G2 X153.745 Y171.178 I-5.581 J-17.613 E0.19731
          G2 X158.010 Y164.600 I-15.846 J-14.946 E0.16657
          G2 X161.219 Y148.753 I-32.558 J-14.841 E0.34471
          G2 X156.708 Y132.780 I-36.464 J1.674 E0.35382
          G2 X149.723 Y125.622 I-17.042 J9.643 E0.21368
          G2 X144.322 Y123.436 I-11.154 J19.793 E0.12353
          G3 X140.198 Y120.599 I3.357 J-9.296 E0.10693
          G3 X139.204 Y119.229 I7.436 J-6.440 E0.03580
          G2 X137.548 Y116.476 I-260.902 J155.064 E0.06790
          G2 X133.733 Y116.029 I-12.269 J88.209 E0.08117
          G1 X133.774 Y115.625 E0.00858
          G3 X147.119 Y117.926 I-8.473 J88.991 E0.28216
          G3 X162.737 Y131.183 I-7.194 J24.303 E0.44567
          G3 X167.287 Y151.609 I-37.413 J19.054 E0.44692
          G3 X161.434 Y171.144 I-42.187 J-1.996 E0.43529
          G3 X144.646 Y182.677 I-21.406 J-13.174 E0.44308
          G3 X133.773 Y184.374 I-20.367 J-94.816 E0.23267
          G1 X133.733 Y183.971 E0.00856
          G2 X137.542 Y183.534 I-19.285 J-184.910 E0.07656
          G0 X137.562 Y183.501
          G0 X137.645 Y183.363
          G0 X138.092 Y183.43
          ;TYPE:SKIN
          G3 X140.001 Y180.322 I37.766 J21.057 E0.07709
          G3 X143.716 Y177.264 I7.678 J5.542 E0.10278
          G3 X146.040 Y176.481 I7.921 J19.670 E0.05188
          G2 X154.046 Y171.467 I-5.708 J-18.012 E0.20174
          G2 X158.392 Y164.770 I-16.139 J-15.232 E0.16964
          G2 X161.637 Y148.737 I-32.932 J-15.010 E0.34873
          G2 X157.071 Y132.573 I-36.871 J1.688 E0.35807
          G2 X149.936 Y125.262 I-17.402 J9.846 E0.21826
          G2 X144.463 Y123.042 I-11.377 J20.192 E0.12521
          G3 X140.511 Y120.321 I3.220 J-8.908 E0.10250
          G3 X139.552 Y118.998 I7.107 J-6.161 E0.03456
          G1 X138.092 Y116.57 E0.05987
          G3 X147.626 Y118.515 I-8.784 J67.395 E0.20581
          G3 X162.362 Y131.368 I-7.771 J23.783 E0.42455
          G3 X166.869 Y151.588 I-37.010 J18.862 E0.44243
          G3 X161.082 Y170.918 I-41.713 J-1.957 E0.43070
          G3 X144.511 Y182.279 I-21.068 J-12.964 E0.43715
          G3 X138.092 Y183.430 I-19.716 J-91.482 E0.13784
          G0 X138.664 Y182.85
          G1 X138.923 Y183.108 E0.00773
          G0 X139.447 Y183.028
          G1 X138.891 Y182.471 E0.01663
          G0 X139.119 Y182.094
          G1 X139.968 Y182.943 E0.02537
          G0 X140.486 Y182.856
          G1 X139.345 Y181.715 E0.0341
          G0 X139.572 Y181.337
          G1 X141.003 Y182.768 E0.04277
          G0 X141.515 Y182.674
          G1 X139.806 Y180.965 E0.05108
          G0 X140.047 Y180.601
          G1 X142.027 Y182.581 E0.05918
          G0 X142.535 Y182.483
          G1 X140.303 Y180.252 E0.06669
          G0 X140.57 Y179.914
          G1 X143.041 Y182.384 E0.07384
          G0 X143.545 Y182.283
          G1 X140.855 Y179.593 E0.0804
          G0 X141.149 Y179.281
          G1 X144.046 Y182.178 E0.08658
          G0 X144.543 Y182.07
          G1 X141.462 Y178.989 E0.09208
          G0 X141.782 Y178.704
          G1 X145.036 Y181.959 E0.09727
          G0 X145.53 Y181.847
          G1 X142.127 Y178.444 E0.10171
          G0 X142.476 Y178.188
          G1 X146.019 Y181.731 E0.10589
          G0 X146.501 Y181.608
          G1 X142.848 Y177.954 E0.10919
          G0 X143.228 Y177.729
          G1 X146.977 Y181.478 E0.11205
          G0 X147.44 Y181.336
          G1 X143.628 Y177.524 E0.11393
          G0 X144.046 Y177.336
          G1 X147.9 Y181.191 E0.1152
          G0 X148.349 Y181.034
          G1 X144.476 Y177.161 E0.11575
          G0 X144.932 Y177.012
          G1 X148.791 Y180.871 E0.11534
          G0 X149.228 Y180.703
          G1 X145.395 Y176.87 E0.11456
          G0 X145.863 Y176.732
          G1 X149.656 Y180.525 E0.11336
          G0 X150.079 Y180.343
          G1 X146.323 Y176.587 E0.11226
          G0 X146.774 Y176.433
          G1 X150.495 Y180.154 E0.11121
          G0 X150.902 Y179.956
          G1 X147.216 Y176.27 E0.11017
          G0 X147.648 Y176.097
          G1 X151.303 Y179.751 E0.10922
          G0 X151.697 Y179.54
          G1 X148.072 Y175.915 E0.10834
          G0 X148.486 Y175.723
          G1 X152.088 Y179.326 E0.10767
          G0 X152.472 Y179.104
          G1 X148.893 Y175.525 E0.10697
          G0 X149.293 Y175.32
          G1 X152.848 Y178.876 E0.10627
          G0 X153.22 Y178.642
          G1 X149.685 Y175.107 E0.10565
          G0 X150.067 Y174.884
          G1 X153.585 Y178.402 E0.10514
          G0 X153.945 Y178.156
          G1 X150.443 Y174.654 E0.10467
          G0 X150.808 Y174.414
          G1 X154.301 Y177.907 E0.1044
          G0 X154.649 Y177.65
          G1 X151.172 Y174.173 E0.10392
          G0 X151.523 Y173.919
          G1 X154.993 Y177.389 E0.10371
          G0 X155.331 Y177.121
          G1 X151.868 Y173.659 E0.10349
          G0 X152.213 Y173.398
          G1 X155.663 Y176.848 E0.10311
          G0 X155.99 Y176.57
          G1 X152.544 Y173.123 E0.10301
          G0 X152.869 Y172.843
          G1 X156.313 Y176.287 E0.10293
          G0 X156.629 Y175.998
          G1 X153.194 Y172.563 E0.10266
          G0 X153.504 Y172.268
          G1 X156.94 Y175.704 E0.10269
          G0 X157.247 Y175.406
          G1 X153.809 Y171.968 E0.10275
          G0 X154.115 Y171.668
          G1 X157.549 Y175.102 E0.10263
          G0 X157.845 Y174.793
          G1 X154.406 Y171.354 E0.10278
          G0 X154.694 Y171.037
          G1 X158.136 Y174.479 E0.10287
          G0 X158.422 Y174.159
          G1 X154.982 Y170.719 E0.10281
          G0 X155.253 Y170.385
          G1 X158.703 Y173.835 E0.10311
          G0 X158.978 Y173.505
          G1 X155.521 Y170.048 E0.10332
          G0 X155.789 Y169.71
          G1 X159.249 Y173.171 E0.10343
          G0 X159.516 Y172.832
          G1 X156.042 Y169.358 E0.10383
          G0 X156.293 Y169.004
          G1 X159.777 Y172.488 E0.10413
          G0 X160.03 Y172.135
          G1 X156.543 Y168.649 E0.1042
          G0 X156.774 Y168.275
          G1 X160.281 Y171.781 E0.1048
          G0 X160.526 Y171.421
          G1 X157.004 Y167.899 E0.10526
          G0 X157.235 Y167.524
          G1 X160.764 Y171.054 E0.10549
          G0 X160.999 Y170.683
          G1 X157.445 Y167.13 E0.10621
          G0 X157.655 Y166.735
          G1 X161.23 Y170.309 E0.10683
          G0 X161.452 Y169.926
          G1 X157.863 Y166.337 E0.10727
          G0 X158.058 Y165.926
          G1 X161.67 Y169.538 E0.10795
          G0 X161.883 Y169.147
          G1 X158.251 Y165.515 E0.10855
          G0 X158.446 Y165.104
          G1 X162.087 Y168.745 E0.10882
          G0 X162.287 Y168.34
          G1 X158.634 Y164.687 E0.10918
          G0 X158.814 Y164.261
          G1 X162.481 Y167.929 E0.10961
          G0 X162.676 Y167.519
          G1 X158.993 Y163.835 E0.11009
          G0 X159.173 Y163.41
          • SIamundefined
            SIam @GrahamExp
            @grahamexp said in Hot end fan switches off at the start of the print.:
            M107
            look at your start g code you have a m170 some wehre and this switch off your fan
              GrahamExp @SIam
              @siam M107 or M170? I see M107 not M170
              • SIamundefined
                SIam @GrahamExp
                @grahamexp
                I mean this:
                ;LAYER:0
                M107
                Somewhere in your slicer will add this and this switch your fan off
                M107: Fan Off
                Deprecated in RepRapFirmware. Use M106 S0 instead.
                Note that M107 will turn off the print cooling fan(s) associated with the current tool (see the F parameter in the M563 command).
                  GrahamExp @SIam
                  @siam I see it, so how do I stop this from happening?
                    @grahamexp OK but that is the current tool fan and it set to be using tool 0 the hot end fan is set to be fan 1 so it should then not be affected, right?
                    • SIamundefined
                      SIam @GrahamExp
                      @grahamexp mmmhh I understand this so that this is the hot end cooler
                        dc42 administrators @GrahamExp
                        @grahamexp that looks better. Now please post your complete config.g file.
                          GrahamExp @SIam
                          @siam yes corect I want it always on .. or at least on as soon as it reached 45 deg. It should not be affected by the g code at all in preference. like on the older duet 2 board you had those always on fan pins.
                            @grahamexp ; Configuration file for Duet 3 (firmware version 3)
                            ; generated by RepRapFirmware Configuration Tool v3.2.2 on Mon Feb 01 2021 21:18:26 GMT+0200 (South Africa Standard Time)
                            G90 ; Send absolute coordinates
                            M83 ; Relative extruder moves
                            M550 P"Viking 300" ; Set printer name to Viking 300
                            M669 K1 ; Select CoreXY mode
                            G21 ; Set to milimeters
                            M111 S0 ; Debugging off
                            M552 P192.168.0.176 S1 ; enable network and acquire dynamic address via DHCP
                            M586 P0 S1 ; enable HTTP
                            M586 P1 S0 ; disable FTP
                            M586 P2 S0 ; disable Telnet
                            M569 P0.2 S1 ; physical drive 0.2 goes backwards
                            M584 X0.1 Y0.0 Z0.2 E0.3 ; set drive mapping
                            M92 X80.00 Y80.00 Z3204 E1004.00 ; set steps per mm
                            M566 X900.00 Y900.00 Z60.00 E500 ; set maximum instantaneous speed changes (mm/min)
                            M203 X18000.00 Y18000.00 Z360.00 E3000.00 ; set maximum speeds (mm/min)
                            M201 X3000.00 Y3000.00 Z360.00 E3000.00 ; set accelerations (mm/s^2)
                            M906 X800 Y800 Z1000 E1200 ; set motor currents (mA) and motor idle factor in per cent
                            ;M84 S30 ; Set idle timeout
                            M208 X-5 Y0 Z0 S1 ; set axis minima
                            M208 X300 Y300 Z360 S0 ; set axis maxima
                            M574 X1 S3 ; configure sensorless endstop for high end on X
                            M574 Y2 S3 ; configure sensorless endstop for high end on Y
                            ;Stall Detection
                            M915 X Y S3 R0 ; Stall detection on the X and Y axis With sensitivity set by S and Action set by R ("Take3 No Action")
                            ;Pressure/Linear Advance
                            ;M572 D0 S0.75 ; Pressure/Linear advance enabled with D selecting tool and S selecting value.
                            M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
                            M558 P9 C"^io7.in" H5 F360 T6000 A1 B0.2 ; set Z probe type to bltouch and the dive height + speeds
                            G31 P500 X-71 Y-42 Z3.0632 ; set Z probe trigger value, offset and trigger height
                            M557 X15:215 Y15:195 S40 ; define mesh grid
                            M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                            M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                            M143 H1 S275 ; set temperature limit for heater 1 to 275C
                            M950 F0 C"out8" Q0 ; create fan 0 on pin out8 and set its frequency - Part Cooling Fan
                            M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency - Hotend Cooling Fan
                            M106 P1 S1 T45 H1 ; set fan 1 value. Thermostatic control is turned on
                            M563 P0 D0 H1 F0:1 ; define tool 0
                            M575 P1 S1 B57600 ; enable support for PanelDue - io_0
                              Phaedrux Moderator @GrahamExp
                              You've got both fan0 and fan1 assigned to tool0 as the part cooling fan.
                              Change F0:1 to be F0
                                GrahamExp @Phaedrux
                                @phaedrux problem solved. thank you for your help 🙂
