    Duet wifi S3D
    50
    12.6k
      dc42 administrators @CR-34T3R
      You may wish to add the following line at the end:
      curl "http://XXX.XXX.XXX.XXX/rr_disconnect"
      This will avoid RRF buffering up messages that S3D isn't going to fetch.
      • apakundefined
        apak
        I have try pathio alpha/beta versions and have Duet integration, to upload files, and they do not add any header to gcode file uploaded.
        • mwolterundefined
          mwolter
          Worked on this for a while and was able to resolve the issue where file names are truncated if the name contains a space.
          Basically all it does is replace spaces in the file name with %20, a simple form of URL Encode. It also uses --data-binary and does not add any extra text to the Gcode like the -F option does. Paste this into the 'Additional terminal commands for post processing' on the Scripts tab of Simplify 3d... don't forget to change the IP address. I'm sure there's a more elegant way but this works on a Mac.
          bash -c "echo 'http://xxx.xxx.xxx.xxx/rr_upload?name=gcodes/[output_filename].gcode' | sed 's/ /%20/g' | curl --data-binary '@[output_filepath]' $(</dev/stdin)";
          • Mogalundefined
            Mogal
            Hello, sry for bumping this thread, but just wanted to say thank you for this. Been wanting this 'feature' for awhile now, and just found this thread and got it working! WOOT!
            But I do get a error when starting the file. Is there a way to eliminate the error? Thanks!
            My script is as follows:
            curl -F "file=@[output_filepath]" "http://192.168.0.10/rr_upload?name=gcodes/[output_filename].gcode&time=YYY" ; uploads file to printer
            ; curl "http://192.168.0.10/rr_gcode?gcode=M32[output_filename].gcode" ; Starts the file printing
            curl "http://192.168.0.10/rr_disconnect" ; Not sure what this one does
              A Former User
              Searching the firmware source for "Bad command" seems to suggest the firmware is taking the HTTP header to be part of the g-code to process?
              Maybe try getting curl to use a minimum of headers, seem to recall DWC not using a fully http compliant parsing of the requests after having looked into something else.
              ref: https://stackoverflow.com/questions/31293181/how-can-i-remove-default-headers-that-curl-sends
              may be out of luck with adding -H 'Content-Disposition:' -H 'Content-Type:' but try it and see if things have changed the last 2 years or when that comment was from..
                A Former User
                Seems its the file uploading enforcing the Content-Type to be multipart, which breaks the parsing.
                workaround:
                curl --data-binary "@[output_filepath]" "http://10.10.0.169/rr_upload?name=gcodes/[output_filename].gcode&time=YYY"
                curl "http://10.10.0.169/rr_disconnect"
                which was mentioned in the post just above yours...
                etrigan63undefined 1 Reply Last reply Reply Quote 1
                • etrigan63undefined
                  etrigan63 @A Former User
                  @bearer That code works as long as there are no spaces in the name.
                  Carlos Echenique
                  3D Printers Guru
                    A Former User @etrigan63
                    @etrigan63 said in Duet wifi S3D:
                    no spaces
                    thats a limitation of the URL specification, replace spaces with %20 if you need them, but in general you will find life much simpler by using - or _ or any other delimiter instead of spaces in filenames.
                    as aworkaround you could try adding --data-urlencode to the curl commandline but I haven't tried it.
                    • orcundefined
                      orc
                      I made it easier
                      App:
                      https://mega.nz/file/ywgiCS5Y#kHK4-RvvnkdyTL-yI6dlYlC_4e3lTijv3ViF1e0QLiY
                      (windows exe file, didn't obfuscate so you can check that it's no more than an uploader)
                      You'd need .NET Framework 4.6.2 or newer
                      Command:
                      "C:\path\path\FileUploadProgress.exe" "Uploading print file..." "[output_filepath]" "http://duet_replicator.local/rr_upload?name=gcodes/[output_filename].gcode"
                      curl "http://duet_replicator.local/rr_disconnect"
                      Preview:
                      Comments: (for anyone without previous experience with this method)
                      You must be logged in to you web interface from a browser for that to work
                      Phaedruxundefined 1 Reply Last reply Reply Quote 2
                        Phaedrux Moderator @orc
                        @orc Perhaps you could make a dedicated post to share your uploader app to increase visibility?
