    WiFi Unreliable
    114
    7.0k
    • DessiVerseundefined
      DessiVerse
      @jay_s_uk I wouldn’t be able to run monitoring software like spaghetti detective though. So I wanted to try to get just the duet working so I can plug my pi into it for octopi. But, I still would need to access the duet panel now and then if I wanna edit any of the files.
        jay_s_uk @DessiVerse
        @dessiverse there are also some features of the firmware that are only available when printing from the sd card (i.e. not streamed from octoprint).
        You can see them here https://duet3d.dozuki.com/Wiki/Firmware_Overview?revisionid=HEAD#Section_Printing_over_USB_connection_Octoprint_Cura_Simplify3D_Etc
        DessiVerseundefined 1 Reply Last reply Reply Quote 0
          DessiVerse @jay_s_uk
          @jay_s_uk I'm aware of those. I normally print on the SD Card over Octoprint anyway, but I can't communicate with the sdcard using Octoprint with this board. Which is back to why I need WiFi working so I can upload to the SD card via the duet dashboard.
            DessiVerse
            SBC mode is no longer working. I assume that's due to the beta firmware that was installed. Can someone please help with this? My printer is now entirely unusable.
            Screen Shot 2021-04-28 at 6.07.15 PM.png Screen Shot 2021-04-28 at 6.07.00 PM.png
              To use the beta firmware on the duet and SBC mode the SBC would need to be updated to the beta as well.
              So either return the Duet back to 3.2.2 to match the version installed on the pi, or add the unstable repository to the pi and then update again.
              See here for more details on adding the unstable branch.
              https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation
                As for the slow wifi speeds it's a bit perplexing as the signal strength seems good and the SD card should be fine.
                I notice you mentioned you have some pis in close proximity on wifi that work ok. Does powering off those pis have any improvement? Perhaps interference?
                  DessiVerse
                  @phaedrux I’ve tried that with no luck. 😕 I’ve also tried in other areas with no luck as well
                    Can you try setting it up in Access Point mode where the duet creates a network which you then connect to and test the speeds that way?
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M589_Configure_access_point_parameters
                    DessiVerseundefined 2 Replies Last reply Reply Quote 0
                      DessiVerse @Phaedrux
                      @phaedrux I can try that, yeah give me a few minutes
                        @phaedrux said in WiFi Unreliable:
                        Hi so I tried this, and the SSID isn't broadcasting, I also tried a direct connection rather than just browsing for one. It also disconnected from my network so I can no longer connect.
                          Phaedrux Moderator @DessiVerse
                          @dessiverse said in WiFi Unreliable:
                          Sorry, but I'm not exactly clear on what you mean by this.
                          What command did you send to setup the access point mode?
                            @phaedrux I initially tried M589 with a custom SSID and password, but that didn't initially work so I tried M589 S"DuetSSID" P"password" I192.168.0.1 C1 from the example. It disconnected from my modem, but it wasn't broadcasting the SSID so I couldn't connect to it.
                              Did you try sending M552 S2 after that? That should enable the module in AP mode.
                                @phaedrux I'm trying this now, but the second I send M589 the duet goes offline and is unreachable. I'll have to try via USB.
                                • Stephen6309undefined
                                  Stephen6309 @DessiVerse
                                  @dessiverse This may not be your problem. On a previous firmware for my ASUS RT-AX56U, I had to reboot the router once in a while to get back my wifi connections to my printers. Duet 3 6HC with a PI 4 and Mini 5+.
                                    DessiVerse @Stephen6309
                                    @stephen6309 That's, concerning.
                                      @phaedrux Hello, finally got to test it, and using the Duet in AP mode there were 0 speed issues. Any ideas as to the causality of the original problem?
                                        So AP mode the speed is great, but when connecting through your router the speed is poor?
                                        That would tell me there might be something going on with your router settings maybe. What kind of wifi router are you using?
                                          @phaedrux It's the Xfinity Modem / Router combo. I don't think it's an issue with the router only because no devices on my network have any speed issues. Even 2.4GHz devices. I have a Pi 3 that runs on 2.4GHz mode that I was using with SBC and it had no issues with speed.
                                          EDIT: Is there any diagnosing things I can do to confirm if that is the case somehow?
                                          stuartofmtundefined 1 Reply Last reply Reply Quote 0
                                            I'm not saying the router has a problem in and of itself, other than it might not be playing nicely with the duet wifi module. Though any time there have been issues like this it's been with ISP provided gear. Off the shelf stuff usually works without issue.
                                            You mentioned a wifi repeater as well. What is it and how is it configured? Is the Duet using the repeater or direct to the router?
