    WiFi module not working on Duet 2 WiFi 1.04c
    489
    • pjkrugerundefined
      pjkruger
      Hi Everyone
      So I have recently bought a Duet 2 WiFi 1.04c board and everything seems to be working just fine, except the WiFi. I am planning to run it as an access point, for other electronics to connect to. All the steps outlined on the website were followed in detail (the M552 S0's, M589's etc), but I could never get the WiFi module enabled and/or in idle mode. Whenever I send the M122 command, the WiFi module is disabled for some reason unknown to me.
      Does anybody have advice? At this stage, the only other explanation would be a dead WiFi module (ESP-07s). Is there a way to test this using e.g. a voltmeter?
      Many thanks.
      PJ
      SIamundefined 1 Reply Last reply Reply Quote 0
      • SIamundefined
        SIam @pjkruger
        @pjkruger pls post the result of M122
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        pjkrugerundefined 1 Reply Last reply Reply Quote 0
        • pjkrugerundefined
          pjkruger @SIam
          @siam
          M122:
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
          Board ID: 08DLM-996RU-N8PS4-6J9D6-3SD6K-9UUBN
          Used output buffers: 5 of 24 (11 max)
          Static ram: 23460
          Dynamic ram: 72036 of which 0 recycled
          Never used RAM 16584, free system stack 190 words
          Tasks: NETWORK(ready,521) HEAT(blocked,366) MAIN(running,419) IDLE(ready,20)
          Owned mutexes: USB(MAIN)
          Last reset 00:00:50 ago, cause: power up
          Last software reset time unknown, reason: User, GCodes spinning, available RAM 16548, slot 0
          Error status: 0x00
          Aux0 errors 0,0,0
          MCU temperature: min 20.1, current 20.8, max 21.0
          Supply voltage: min 0.2, current 0.4, max 0.4, under voltage events: 0, over voltage events: 0, power good: no
          Driver 0: position 0, ok, SG min/max not available
          Driver 1: position 0, ok, SG min/max not available
          Driver 2: position 0, ok, SG min/max not available
          Driver 3: position 0, ok, SG min/max not available
          Driver 4: position 0, ok, SG min/max not available
          Driver 5: position 0
          Driver 6: position 0
          Driver 7: position 0
          Driver 8: position 0
          Driver 9: position 0
          Driver 10: position 0
          Driver 11: position 0
          Cache data hit count 67293480
          Slowest loop: 100.55ms; fastest: 0.14ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 3.1ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is ready with "M122" in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 0.22ms; fastest: 0.00ms
          HTTP sessions: 0 of 8
          • WiFi -
            Network state is starting2
            Failed messages: pending 0, notready 1, noresp 0
            ok
          M589: (With all the other S, P, I parameters):
          Error: M589: Failed to retrieve own SSID data: another SPI transfer is pending
          ok
          • SIamundefined
            SIam @pjkruger
            @pjkruger said in WiFi module not working on Duet 2 WiFi 1.04c:
            I'm not complete sure, but I think you have to install the DuetWiFiServer.bin from the RRF 3.2.2 to get wifi to work
              Please try sending M997 S1 to initiate the wifi firmware flash. It seems to have not gone through previously.
              • pjkrugerundefined
                pjkruger @Phaedrux
                @phaedrux @SIam
                I uploaded via SD card RRF 3.2.2 DuetWifiServer.bin to /sys and sent M997 S1, response as follows:
                M997 S1
                Trying to connect at 230400 baud: success
                Erasing 4096 bytes...
                Erasing 196608 bytes...
                Uploading file...
                5% complete
                10% complete
                15% complete
                20% complete
                25% complete
                30% complete
                35% complete
                40% complete
                45% complete
                50% complete
                55% complete
                60% complete
                65% complete
                70% complete
                75% complete
                80% complete
                85% complete
                90% complete
                95% complete
                Upload successful
                ok
                Disconnected, reconnected, sent the following:
                M552 S0
                ok
                M552
                WiFi module is being started
                ok
                M122
                Used output buffers: 5 of 24 (10 max)
                Static ram: 23460
                Never used RAM 16584, free system stack 192 words
                Tasks: NETWORK(ready,521) HEAT(blocked,366) MAIN(running,492) IDLE(ready,20)
                Last reset 00:00:44 ago, cause: power up
                Error status: 0x00
                Aux0 errors 0,0,0
                MCU temperature: min 16.4, current 18.7, max 19.1
                Supply voltage: min 0.3, current 0.5, max 0.7, under voltage events: 0, over voltage events: 0, power good: no
                Cache data hit count 60541246
                Slowest loop: 5.27ms; fastest: 0.14ms
                === Storage ===
                === MainDDARing ===
                === AuxDDARing ===
                Segments left: 0
                === Network ===
                Slowest loop: 1.02ms; fastest: 0.00ms
                • WiFi -
                  ok
                Still no luck.
                  How bout just sending m552 S1?
                    dc42 administrators @pjkruger
                    @pjkruger please try running M997 S1 again. Sometimes the firmware upload fails first time, and unfortunately the ESP flashing mechanism does not provide any error checking. After it reports successful completion, try M552 S0 again. If necessary, power the Duet down and up again.
                    If after that it still always reports "WiFi module is being started" when you send M552, and it's a genuine Duet, then I will approve a replacement under warranty.
                    • pjkrugerundefined
                      pjkruger @Phaedrux
                      @phaedrux
                      M552 S1
                      Turn off the current WiFi mode before selecting a new one
                      ok
                      M552 S-1
                      WiFi module stopped
                      ok
                      M552 S1
                      ok
                      M552
                      ok
                      M122
                      Used output buffers: 2 of 24 (11 max)
                      Static ram: 23460
                      Tasks: NETWORK(ready,519) HEAT(blocked,366) MAIN(running,427) IDLE(ready,20)
                      Last reset 00:01:36 ago, cause: power up
                      Error status: 0x00
                      Aux0 errors 0,0,0
                      MCU temperature: min 20.7, current 21.6, max 21.7
                      Supply voltage: min 0.5, current 0.5, max 0.7, under voltage events: 0, over voltage events: 0, power good: no
                      Cache data hit count 133944405
                      Slowest loop: 99.34ms; fastest: 0.14ms
                      === Storage ===
                      === MainDDARing ===
                      === AuxDDARing ===
                      Segments left: 0
                      === Network ===
                      Slowest loop: 0.19ms; fastest: 0.00ms
                      • WiFi -
                        ok
                      No Luck
                      • pjkrugerundefined
                        pjkruger @dc42
                        M997 S1
                        Uploading file...
                        5% complete
                        10% complete
                        15% complete
                        20% complete
                        25% complete
                        30% complete
                        35% complete
                        40% complete
                        45% complete
                        50% complete
                        55% complete
                        60% complete
                        65% complete
                        70% complete
                        75% complete
                        80% complete
                        85% complete
                        90% complete
                        95% complete
                        Upload successful
                        ok
                        Power off; on
                        M552 S0
                        ok
                        M552
                        ok
                        M122
                        Used output buffers: 4 of 24 (9 max)
                        Static ram: 23460
                        Tasks: NETWORK(ready,521) HEAT(blocked,366) MAIN(running,524) IDLE(ready,20)
                        Last reset 00:00:45 ago, cause: power up
                        Error status: 0x00
                        Aux0 errors 0,0,0
                        MCU temperature: min 21.2, current 23.6, max 23.9
                        Supply voltage: min 0.3, current 0.5, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
                        Cache data hit count 62597900
                        Slowest loop: 5.28ms; fastest: 0.14ms
                        === Storage ===
                        === MainDDARing ===
                        === AuxDDARing ===
                        Segments left: 0
                        === Network ===
                        • WiFi -
                          ok
                        Again seems to be no luck. I can confirm it is a genuine Duet, purchased from Da Vinci Labs in RSA (Graeme). You are most welcome to contact them to verify, they are aware of the situation and pointed me to this forum since they don't provide after-sale service.
                          Phaedrux Moderator @pjkruger
                          @pjkruger Please contact your vendor to initiate a warranty exchange. Include a link to this thread as authorization.
