End of print conditional position change?
Gcode meta commands
    Thalios
    Hello, I'm trying to make my life a touch easier and prevent errors like clicking the wrong button at the end of a print, so I was wondering if there's a way to do this:
    I want the Z to increase by 100 at the end of a print, but not if it will go past the limit (305).
    Is it possible to add a end gcode in the slicer like:
    if Z is between 0 and 200, add 100 to Z
    If Z is between 201 and 249, Move Z to 300
    If Z is 250 or more, don't move Z
    Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
    Heavily modified Ender 3 Pro (Duet 3 6HC)
    Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
    CR-10S Pro V2 (Duet 3 Mini 5+)
    and a bunch of SLA printers..
    undefined 1 Reply Last reply 29 Apr 2021, 21:31 Reply Quote 0
      engikeneer @Thalios
      @thalios if you've set up your machine limits it will respect them anyway
      Try moving to z=300, then jogging it 100mm via DWC. It will still end up at 305mm in your case. Simply add a relative motion to your end gcode.
      Alternatively you could add some conditional gcode to stop.g to do something more clever?
      i3 clone with a bunch of mods
      undefined 1 Reply Last reply 29 Apr 2021, 21:32 Reply Quote 1
        Thalios @engikeneer
        @engikeneer That's not really what I want to do. Yes it is set properly in the Duet, but I want it to do different things as per my example depending on where it's at. I don't want a 25mm print to send the bed all the way down to 305 for nothing.
        undefined 1 Reply Last reply 29 Apr 2021, 22:06 Reply Quote 0
          OwenD @Thalios
          @thalios
          Do as @engikeneer suggested and put your conditional code in stop.g
          use the object model to get the current Z height.
            Thalios
            I was thinking something like this:
            {if Z< 200} G1 Z+100 F10000
            {elsif Z>= 200} G1 Z300 F10000
            {endif}
            I just cannot find infos on wether these commands are valid..
            I guess i'll just try it hehe
            undefined 1 Reply Last reply 29 Apr 2021, 22:26 Reply Quote 0
              OwenD @Thalios
              @thalios said in End of print conditional position change?:
              {endif}
              The wiki section on IF statements is here
              https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands#Section_Conditional_construct
              There are lots of examples in the meta commands section of the forum that should help you construct what you want.
                Thalios
                Wow I was approaching this totally the wrong way...
                All I have to do, as per your recommandations, is to set in relative mode, and add 100 to Z...
                I was WAYYYYYYY overthinking this...
                Thanks guys
                7 out of 7
