    Z Babystepping
    • phcellaundefined
      phcella
      I'm facing a annoying problem, and I don't know how to solve.
      I have a IR Z-probe sensor, and I calibrate the the triggered height on every point. Then I run G32, but sometimes the nozzle is a bit high from bed and I decrease the z baby step, but the nozzle doesn't go down. Why does this happen?
      jens55undefined Topherundefined 2 Replies Last reply Reply Quote 0
      • jens55undefined
        jens55 @phcella
        @phcella, the nozzle can not go below the point you designated as your minimum Z position. Usually that is z=zero. If the nozzle is a bit high though and Z is already set to zero then it can't go lower.
        In my config.sys:
        M208 X-10 Y0 Z-0.5 S1 ; Set axis minima
        M208 X530 Y495 Z480 S0 ; Set axis maxima
        Note that I allow z to go to -0.5 which allows me to step a bit lower.
        • Topherundefined
          Topher @phcella
          @jens55 said in Z Babystepping:
          In my config.sys:
          ^ This is what I do too. Another option you can do while a print is running is to enter M564 S0 in the console before you try to set your baby steps below zero. Record your final baby step value when your first layer is looking good and then add that to your Probe's Z offset so your future prints don't need adjustment.
