    how to control router on/off
    21
    1.9k
    • HalifaxAlexundefined
      HalifaxAlex @dc42
      @dc42 how does one configure a fan output to respond to M3 and M5? Can that be used in conjunction with using a heater output to also respond to M3 and M5? RRF 2.
        droftarts administrators @HalifaxAlex
        @halifaxalex You set the spindle output pin in the M453 command that switches the Duet to CNC mode: https://duet3d.dozuki.com/Wiki/Gcode#Section_M453_in_RepRapFirmware_1_x_and_2_x
        Then you can use M3, M4 and M5: https://duet3d.dozuki.com/Wiki/Gcode#Section_M3_Spindle_On_Clockwise_CNC_specific_Laser_on_Laser_specific
        You can map up to four spindles in RRF. Use M453 S parameter for each one. You should be able to use fan and heater outputs; refer to the following document for pin numbers as you're using RRF2 (update to 2.05.1 for bug fixes if still on an earlier version). Don't forget to disable the corresponding heater (using M307) or fan (using M106) first.
        https://duet3d.dozuki.com/Wiki/Using_servos_and_controlling_unused_IO_pins#Section_Logical_pin_numbers
        I don't think you can run the fan output 'in conjunction' with a heater output, and have them both respond to the same M3/4/5 command. You need to have a separate M3/4/5 command for each spindle if you wanted them both running at the same time. But as M3/4/5 only turn the spindle on and off, I don't think this is a problem.
        See this for general guidance for setting up a CNC machine: https://duet3d.dozuki.com/Wiki/Configuring_RepRapFirmware_for_a_CNC_machine
        Tyzundefined 1 Reply Last reply Reply Quote 0
        • Tyzundefined
          Tyz @droftarts
          @droftarts I've had a look through some of this and the links you have provided, I can see how to output the PWM signal and configure it using M453 but cant see how to configure it to make M3/4/5 as well to control the ON/OFF of an output pin of my choosing. It would also be useful to configure other M codes to switch outputs for say a vacuum or air mist compressor.
            dc42 administrators @Tyz
            @tyz said in how to control router on/off:
            You can do that using RRF3 but not with RRF2.
            For any M-code that RRF does not implement at all, you can create a macro file that is executed when you send that code. For example, if you want to implement NIST code M8 (flood coolant on), create a file called M8.g in the /sys folder, and inside that file put the commands that you want to execute in response to M8.
            • Tyzundefined
              Tyz @dc42
              @dc42 Thank you, I had seen that I could create files for the unsupported M codes in the /sys folder. It does however seem very lacking for support of M3/4/5 codes when they've been implemented in to RepRap but don't actually do anything like switching a pin/port on/off to actually control a spindle. The only way to do this now is to modify a post processor to use the non standard commands for a spindle such as M7/8/9 which are normally used for coolant/air mist or M10/11 which are normally used for CNC axis clamping.
              Thank you.
                jay_s_uk @Tyz
                @tyz they do turn on the router/spindle if you run RRF3.
                • Tyzundefined
                  Tyz @jay_s_uk
                  @jay_s_uk I know, but that's no use to me as my Duet from Ooznest doesn't have RRF3 on it.
                    jay_s_uk @Tyz
                    @tyz but its fairly easy to upgrade and there is now a CNC version of DWC for RRF3
                    • Tyzundefined
                      Tyz @jay_s_uk
                      @jay_s_uk It may be if you know what your doing, but the configuration on this is done by Ooznest and I don't know what else would have to be reconfigured as a result of differences between RRF2 & RRF3, some commands are different and others have the functionality moved to a different M code.
                        I think Oozenest is working on an update for RRF3. May want to check with them to see where they are at with that.
