    X turned down, replacig with E?
    Using Duet Controllers
    815
    • SIamundefined
      SIam @Pertti
      @pertti what kind of printer you have ?
      Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
      Duet WiFi 1.02 or later + DueX5
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
      Duet WiFi Server: 1.26
      Duet Web Control 3.4.0beta4 (2021-09-27)
      Perttiundefined 1 Reply Last reply Reply Quote 0
      • Perttiundefined
        Pertti @SIam
        @siam It´s a rebuilt Leapfrog creatr xl. Bed moving up and down, horizontal X and 2*Y axis.
        Pertti
        “A winner is just a loser who tried one more time.”
        George M. Moore, Jr.
        • Perttiundefined
          Pertti @Pertti
          Some parts are missing, sorry.
          Pertti
            Post your full config.g please.
            • Perttiundefined
              Pertti @Phaedrux
              @phaedrux
              0:/sys/config.g
              ;0:/sys/config.g
              ; Leaprog 200804
              ; TITAN AERO
              ; Tässä versiossa y=z akselissa
              ; generated by RepRapFirmware Configuration Tool v2.1.5 on Sat Jan 11 2020 15:38:33 GMT+0200 (Itä-Euroopan normaaliaika)
              ; General preferences ;M303 H2 S240 ;Auto tuning Heater2
              G90                                             ; send absolute coordinates... M143
              M83                                             ; ...but relative extruder moves
              M550 P"Leapfrog-Duet"                              ; set printer name
              M552 S1                                         ; enable network
              M586 P0 S1                                      ; enable HTTP
              M586 P1 S0                                      ; disable FTP
              M586 P2 S0                                      ; disable Telnet
              	; Drives dualextruder
              M569 P0 S0                                      ; physical drive 0 goes forwards  X
              M569 P1 S0                                      ; physical drive 1 goes backwards Y muutetto S0  210509
              M569 P2 S1                                      ; physical drive 2 goes backwards Z
              M569 P3 S1                                      ; physical drive 3 goes backwards E0
              M569 P4 S0                                      ; physical drive 4 goes forwards E1
              				;M584 X4 Y1 Z2 E3 		; X is now port 4  drive mapping vaihdettu E-> X
              	M584 X0 Y1 Z2 E3:4                              ; set drive mapping
                    				;M584 X0 Z1 Y2 E3:4                              ; set drive mapping vaihdettu z-y
              M350 X16 Y16 Z16 E16:16 I1                      ; configure microstepping with interpolation
              M92 X400.00 Y66.67 Z654.02 E144.00:144.00 	;dualextruder set steps per mm	M92 X66.67 Y66.67 Z654.02 E137.00:137.00
              	;M92 X66.67 Y66.67 Z654.02 E837.00:93.00 ;titan aero; set steps per mm
              M566 X900.00 Y900.00 Z12.00 E120.00:120.00       ; set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z20.00 E250.00:250.00      ; set accelerations (mm/s^2)
              ;M906 X800 Y1600 Z1600 E800:800 I30              ; set motor currents (mA) and motor idle factor in per cent
              M906 X800 Y800 Z1600 E800:800 I30              ; set motor currents (mA) and motor idle factor in per cent
              M84 S30                                         ; Set idle timeout
              M208 X0 Y0 Z0 S1
              M208 X270 Y300 Z200 S0                          ; set axis maxima
              M574 Z0 S1                                      ; set active low and disabled endstops M574 Z0 S0
              M574 X1 Y1 S1                                   ; set active high endstops
              M558 P0 H5 F120 T6000                           ; disable Z probe but set dive height, probe speed and travel speed
              M557 X15:200 Y15:195 S20                        ; define mesh grid
              	;M305 P0 T100000 B4138 R4700                     ; set thermistor + ADC parameters for heater 0
              	;M143 H0 S120                                    ; set temperature limit for heater 0 to 120C
              	;M305 P1 T100 B3950 R4700                        ; set thermistor + ADC parameters for heater 1
              	;M143 H1 S280                                    ; set temperature limit for heater 1 to 280C
              	;M305 P2 T100 B3950 R4700                   	 ; set thermistor + ADC parameters for heater 2
              	;M143 H2 S280
              M305 P1 T100000  B3950 R4700 ; set thermistor + ADC parameters for heater 1 ,T was 100000
              ;M305 P1 B4725 C7.060000e-8 ; titan aero
              M143 H1 S290 ; set temperature limit for heater 1 to 280C
              M305 P2 T100000  B3950 R4700 ; set thermistor + ADC parameters for heater 2 ,T was 100000
              M143 H2 S290 ; set temperature limit for heater 2 to 280C
              M307 H1 A455.9 C183.2 D17.7 S1.00 V24.1 B0
              M307 H2 A499.7 C172.7 D10.4 S1.00 V24.1 B0
              M570 H1 P4 T25 s1
              M570 H2 P10 T25
              M570 S120
              ;M106 P0 S0.5 I0 F500 H1 T45
              ;M106 P1 T45 H1
              ;M106 P0 S0 I0 F500 H-1                          ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
              ;M106 P1 S1 I0 F500 H-1                          ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
              ;M106 P2 S1 I0 F500 H-1                          ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
              M106 P1 T45 B0.1 H1 ; enable thermostatic mode for fan 1
              M106 P0 T45 B0.1 H1 ; enable thermostatic mode for fan 2
              M563 P0 D0 H1 F0                                ; define tool 0
              G10 P0 X0 Y0 Z0                                 ; set tool 0 axis offsets
              G10 P1 R160 S0                                  ; set initial tool 0 active and standby temperatures to 0C
              M563 P1 D1 H2 F0                                ; define tool 1
              G10 P1 X24.3 Y1.0 Z0                              ; set tool 1 axis offsets  oli G10 P1 X22.4 Y6.4 Z0
              G10 P2 R160 S0 					; set initial tool 1 active and standby temperatures to 0C
              ;M563 P0 D0 H1 ; tool 0 uses extruder 0, heater 1 (and fan 0)
              Pertti
                Can you send M98 P"config.g" and report any errors?
                Also please provide the results of M122.
                • Perttiundefined
                  Pertti @Phaedrux
                  Leapfrog 210509 requests.txt
                  Here´s the answers, pasting them here resulted spam.
                  Pertti
                  SIamundefined 1 Reply Last reply Reply Quote 1
                  • SIamundefined
                    SIam @Pertti
                    @pertti check this config.g I hope i have found all issues if not please post the result of M98 P"config.g" again
                    ;0:/sys/config.g
                    ; Leaprog 200804
                    ; TITAN AERO
                    ;M584 X0 Y1 Z2 E3:4                              ; set drive mapping
                    M92 X400.00 Y66.67 Z654.02 E144.00 	;dualextruder set steps per mm	M92 X66.67 Y66.67 Z654.02 E137.00:137.00
                    M566 X900.00 Y900.00 Z12.00 E120.00         ; set maximum instantaneous speed changes (mm/min)
                    M203 X6000.00 Y6000.00 Z180.00 E1200.00     ; set maximum speeds (mm/min)
                    M201 X500.00 Y500.00 Z20.00 E250.00         ; set accelerations (mm/s^2)
                    M208 X0 Y0 Z0 S1
                    	;M143 H2 S280
                    M570 H1 P4 T25 s1
                    M570 H2 P10 T25
                    M570 S120
                    ;M106 P1 T45 H1
                    ;M563 P1 D1 H2 F0                                ; define tool 1
                    ;G10 P1 X24.3 Y1.0 Z0                              ; set tool 1 axis offsets  oli G10 P1 X22.4 Y6.4 Z0
                    ;G10 P2 R160 S0 					; set initial tool 1 active and standby temperatures to 0C
                    T0
                    • Perttiundefined
                      Pertti @SIam
                      @siam said in X turned down, replacig with E?:
                      M98 P"config.g"
                      9.5.2021 klo 22.44.31 M98 P"config.g"
                      HTTP is enabled on port 80
                      FTP is disabled
                      TELNET is disabled
                      Error: GCodes: Attempt to read a GCode unsigned array that is too long: M350 X16 Y16 Z16 E16:16 I1
                      Error: GCodes: Attempt to read a GCode float array that is too long: M906 X800 Y800 Z1600 E800:800 I30
                      Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 480C.
                      Warning: Heater 2 appears to be over-powered. If left on at full power, its temperature is predicted to reach 524C.
                      Error: G10: Attempt to set/report offsets and temperatures for non-existent tool: 1
                      Pertti
                      SIamundefined 1 Reply Last reply Reply Quote 0
                      • SIamundefined
                        SIam @Pertti
                        @pertti
                        in Line 31 M350 X16 Y16 Z16 E16:16 I1 Remove :16
                        in line 44 M906 X800 Y800 Z1600 E800:800 I30 Remove :800
                        in line 89 G10 P1 R160 S0 i think P1 should be P0
                        • Perttiundefined
                          Pertti @SIam
                          @siam Thank´s to all of You, great response. I think I must go to sleep now, hope to survive tomorrow.
                          Pertti
                          • Perttiundefined
                            Pertti @Pertti
                            Now working!. I think the problem was this: mapping the y-steppers to drive 2 and z stepper to drive 1. In addition, the z motor is bigger and needs more amps to move.
                            The drive 0 was hotter than it´s neighbours allthough not in use. Maybe some damage?
                            Pertti
