Solved How to set WiFi permanent?
@tecno have you tried doing exactly what I said? What does M587 report after you power off and on again?
@dc42 said in How to set WiFi permanent?:
Failed to retrieve etc.....
@tecno try reflashing the firmware using M997 S1
Still the same issue
@tecno did re-flashing the WiFi firmware succeed? What WiFi firmware version does M122 report?
It could be that the wifi module has developed a fault.
Well now I can get nowhere.
I got it sort of working, did run some G28 and got all sorted out.
Suddenly I can not use my browsers to open Duet Web Control.
Same now with Yat and Pronterface!WinSCP is OK so with FTP I can see folders, open folders to see files but then I can not go back to root.
So what is going on here here???
ps. I have never heard so quiet printer before, this board is doing it well.
I can login with Telnet and run G28
M122
RepRapFirmware for Duet 3 Mini 5+ version 3.2-beta3.2+1 running on Duet 3 Mini5p lus WiFi (standalone mode)
Board ID: 4MUA7-X196U-D65J0-40KM8-4N03Z-HJR3D
Used output buffers: 1 of 40 (1 max)
Static ram: 97472
Dynamic ram: 133200 of which 664 recycled
Never used RAM 29784, free system stack 122 words
Tasks: NETWORK(ready,414) HEAT(blocked,222) CanReceiv(blocked,967) CanSender(blo cked,357) CanClock(blocked,363) TMC(blocked,65) MAIN(running,448) IDLE(ready,20) AIN(blocked,264)
Owned mutexes:
Last reset 00:05:48 ago, cause: power up
Last software reset at 2021-05-10 17:38, reason: User, GCodes spinning, availabl e RAM 29784, slot 0
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00430000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
Error status: 0x00
Supply voltage: min 0.0, current 24.4, max 24.5, under voltage events: 0, over v oltage events: 0, power good: yes
Driver 0: position 16000, standstill, SG min/max 0/0, read errors 0, write error s 0, ifcnt 9, reads 49635, writes 9, timeouts 0, DMA errors 0
Driver 1: position 16000, standstill, SG min/max 0/36, read errors 0, write erro rs 0, ifcnt 12, reads 49632, writes 12, timeouts 0, DMA errors 0
Driver 2: position 0, standstill, SG min/max 0/8, read errors 0, write errors 0, ifcnt 12, reads 49587, writes 12, timeouts 44, DMA errors 0, failedOp 0x6f
Driver 3: position 0, standstill, SG min/max 0/14, read errors 0, write errors 0 , ifcnt 12, reads 49494, writes 12, timeouts 137, DMA errors 0, failedOp 0x06
Driver 4: position 0, standstill, SG min/max 0/14, read errors 0, write errors 0 , ifcnt 12, reads 49632, writes 12, timeouts 0, DMA errors 0
Driver 5: position 0, assumed not present
Driver 6: position 0, assumed not present
Slowest loop: 4.85ms; fastest: 0.12ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.3ms, write time 0.0ms, max retries 0
Hiccups: 0(0), FreeDm: 169, MinFreeDm: 167, MaxWait: 196250ms
=== MainDDARing ===
Scheduled moves 6, completed moves 6, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
=== AuxDDARing ===
Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
Bed heaters = 0 -1, chamberHeaters = -1 -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 45.05ms; fastest: 0.00ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(2), 1 sessions
HTTP sessions: 0 of 8- WiFi -
Network state is active
WiFi firmware version 1.25beta0
WiFi MAC address f4:cf:a2:6f:bd:d8
WiFi Vcc 3.37, reset reason Power up
WiFi flash size 2097152, free heap 20976
WiFi IP address 192.168.1.88
WiFi signal strength -43dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
Socket states: 2 0 0 0 0 0 0 0
=== CAN ===
Messages sent 0, send timeouts 0, longest wait 0ms for type 0, free CAN buffers 15
Hope this helps to get a fix to my new problem.
Cheers
Bengt - WiFi -
@tecno, what happens when you try to load Duet Web Control, by entering the Duet's IP address in your web browser?
@tecno said in How to set WiFi permanent?:
WiFi firmware version 1.25beta0Please update your firmware using these steps:
https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Duet_3_Mini_5_WiFi_EthernetUsing this file: https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet3Firmware_Mini5plus.uf2
Then on your SD card in your PC, replace the contents of the /www/ folder with the contents of this zip file:
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/DuetWebControl-SD.zipThen place this bin file in the /sys/ folder on the SD card.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/DuetWiFiServer.binThen reconnect via usb or telnet terminal and send M997 S1 to reflash the wifi server.
Next time you run M122 you should see the firmware listed as 3.2.2 and the wifi server listed as 1.25. The DWC should also be at 3.2.2 if you check the version in the web browser.
Future firmware updates will be much more straightforward by simply uploading the full firmware zip file to the system tab in DWC.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
@dc42 Good morning, nothing just a blank page . Not safe
@phaedrux Good morning, will do as listed by you, Thank you.
Back on-line with DWC. Thank you !
Now step by step check that heaters, fans are working.
Cheers from Sweden
Bengt -
Cheers from Sweden
BengtDoes it remember the WiFi access point details through a power cycle now?
@dc42 Yes it does.
Have some issues with fans and heaters, where do I start a thread?
@tecno you can start a new thread in this category. I will mark this as solved.
