Designing a PWM to Analog mini board for fans
139
12.4k
    ZipZap @Egon.Net
    @egon-net
    Sounds all swell to me.
    I'm still in on beta-testing, i would like an assembled board (because of a missing hotair-gun...).
    For the final version, i would like eight (8) non-assembled kits.
    Most important guide -> Triffid Hunter's Calibration Guide
    HyperCube EVO (derivate) in 250x250x300 - enclosed for ABS - Duet2WiFi - custom watercooling
      marcelorider
      Hey, happy to see it is working fine 🙂
      I'm in for the beta testing, shot you a PM, let me know something as soon as you can to get my hands on it.
      You also need to include or build info regarding the jumpers to make it easier for people like myself 😄
      undefined 1 Reply Last reply 18 Apr 2021, 13:18 Reply Quote 0
        Egon.Net @marcelorider
        To all betatesters: How is it going? Any comments yet?
        undefined 1 Reply Last reply 19 Apr 2021, 20:44 Reply Quote 0
          ZipZap @Egon.Net
          @egon-net
          Still testing, should be ready tomorrow or wednesday.
          undefined 1 Reply Last reply 22 Apr 2021, 06:59 Reply Quote 1
            ZipZap @ZipZap
            Bummer.
            I have another circuit (@Egon-Net for the big fan), which should have a ripple around 30mV.
            It shows me a ripple of 28V... i think my oscilloscope is not working right.
            I have a replacement in delivery, so i should be able to make all my desired measurements around the weekend. Sorry for the delay.
            /Julien
            undefined 1 Reply Last reply 30 Apr 2021, 14:34 Reply Quote 0
              Egon.Net @ZipZap
              Well, I just mounted 8 PWM beta boards in my printer, two for each tool (one cold end, one part cooling)
              I already connected 4 of them, and they work beautifully. I finally can control my stubborn fans! I'll make some more endurance test (to check temperatures in the long run) and wait for the betatesters to report, but there should be no problem for a final board run.
              Still interested?
              undefined 1 Reply Last reply 15 May 2021, 10:52 Reply Quote 1
                Egon.Net @Egon.Net
                Everything ready for the next batch of final boards! 😄
                Everyone who asked me for boards is already contacted for this batch. There are 23 boards finally requested, so I'll probably do a 25-board batch. Does anyone else need one before I place the orders to part suppliers?
                I can also supply a STL/STEP file with the board and a basic box just in case you need 🙂
                undefined undefined 2 Replies Last reply 15 May 2021, 13:46 Reply Quote 0
                  NexxCat @Egon.Net
                  @egon-net Out of interest. What would the cost be per board, delivered to the UK? Do you think they could be assembled with a fine tipped soldering iron, or only hot air?
                  undefined undefined 2 Replies Last reply 15 May 2021, 14:57 Reply Quote 0
                    Egon.Net @NexxCat
                    @nexxcat said in Designing a PWM to Analog mini board for fans:
                    Regarding cost, this is what I thought:
                    • Just a bare board: 4€/piece
                    • DIY kit (without headers/jumpers): 8€/kit
                    • Fully assembled and tested (with optional headers/jumpers): 15€/piece
                    • Shipping costs to UK: 5€
                    Regarding building the board with a fine soldering iron... It could be done since every part has its legs exposed and parts are not that small (SOIC8 & 0805 SMD), but it would be much more difficult.
                    undefined 1 Reply Last reply 15 May 2021, 15:53 Reply Quote 0
                      NexxCat @Egon.Net
                      @egon-net Thanks 🙂 I'll hold off for now then, but great work on the product!
                      undefined 1 Reply Last reply 15 May 2021, 16:15 Reply Quote 0
                        Egon.Net @Egon.Net
                        This is the new board:
                        It's a bit bigger so now the capacitor is included and the diode and the led are in top side. Also a bit more of space surrounding the in/out connectors.
                        BTW, I think it's the last board I make with Ultiboard. I have tested Kicad and its support for footprints is way better (I can directly import them from Mouser!)
                        undefined 1 Reply Last reply 16 May 2021, 06:12 Reply Quote 0
                          Egon.Net @NexxCat
                          Thanks!
                            zapta @NexxCat
                            You can practice with one of those Aliexpress kits https://www.aliexpress.com/item/1005002070994262.html . It's not that difficult once you get used to it, especially SOIC and 0805 packages which are relatively on the large side.
                              zapta @Egon.Net
                              @egon-net said in Designing a PWM to Analog mini board for fans:
                              Most likely Kicad will give you nicer 3D renderings. 😉
                              Sometime people also post hard to find models on sites such as grabcad or gitbub.
                              undefined 1 Reply Last reply 16 May 2021, 07:48 Reply Quote 0
                                Egon.Net @zapta
                                @zapta said in Designing a PWM to Analog mini board for fans:
                                In fact, Ultiboard renders are VERY ugly xDD. In 1998, when I started using it, it was like "wooha!". But now it's 2021, and it's the very same render 😆
                                It's just that I can go from Multisim to Ultiboard comfortably, and Multisim has a powerful analog spice simulator which I use a lot. I'm trying to transition to TINA TI + KiCad. I wish KiCad had a good spice simulator!
                                undefined 1 Reply Last reply 16 May 2021, 16:13 Reply Quote 0
                                  zapta @Egon.Net
                                  If paying for a subscription is an option for you, take a look at https://www.circuitlab.com/ . It has a more modern front end, works in a browser and has a cleaner user interface, and has nice feature such as sharing your schematic and simulation with others.
                                  Most of my projects are digital so in the rare cases I need a simulator I use https://en.wikipedia.org/wiki/LTspice (free, powerful, dated user interface like most circuit simulators).
                                  undefined 1 Reply Last reply 16 May 2021, 17:03 Reply Quote 0
                                    Egon.Net @zapta
                                    I'm trying to get used to TINA TI because it has most of TI spice models and it's fairly accurate (I do a lot of analog designs). Its transient analysis is the most accurate I've found to date. But thanks for the suggestions! I'll have a look 🙂
                                    undefined 1 Reply Last reply 17 May 2021, 17:55 Reply Quote 0
                                      Egon.Net @Egon.Net
                                      25 board batch on its way!
                                      • Parts ordered to Mouser ✔
                                      • Boards ordered to JLCPCB ✔
                                      Waiting...
                                      undefined 1 Reply Last reply 24 May 2021, 10:27 Reply Quote 1
                                        zapta
                                        Do fan manufacturer provide graphs of CFM vs voltage? Is this something that can easily be measured?
                                        Now that you have good control of the fan, would be interesting to know for example what 50% voltage means in cooling terms.
                                        undefined 1 Reply Last reply 18 May 2021, 10:20 Reply Quote 0
                                          Egon.Net @zapta
                                          I don't even thing that the manufacturer expects you to run the fan at other voltage than nominal... If I had some way to measure air flow I could perform some measurements, something like displacement of a suspended weight or the like.
